Documentation > GR5xx APP Driver User Manual/ Overview/ APP_DRV Configurations Copy URL
Users can set the SoC series that APP_DRV supports, and the priority of peripherals to be woken up from sleep, by modifying macro definitions in app_drv_config.h. Details about the macro definitions are provided in the table below.
Table 2 Macro definitions in app_drv_config.h
Macro Value Description
APP_DRIVER_GR551X
Support GR551x series.
APP_DRIVER_GR5525X
0x1
Support GR5x25 series.
APP_DRIVER_GR5526X
0x2
Support GR5526 series.
APP_DRIVER_GR5332X
0x3
Support GR533x series.
APP_DRIVER_GR5405 0x3 Support GR5405 SoCs.
APP_DRIVER_ADC_WAKEUP_PRIORITY
WAKEUP_PRIORITY_HIGH
Set the wake-up priority of ADC to high.
APP_DRIVER_AES_WAKEUP_PRIORITY
WAKEUP_PRIORITY_MID
Set the wake-up priority of AES to middle.
APP_DRIVER_COMP_WAKEUP_PRIORITY
WAKEUP_PRIORITY_LOW
Set the wake-up priority of COMP to low.
APP_DRIVER_DUAL_TIM_WAKEUP_PRIORITY
WAKEUP_PRIORITY_MID
Set the wake-up priority of DUAL_TIM to middle.
APP_DRIVER_DMA_WAKEUP_PRIORITY
Set the wake-up priority of DMA to high.
APP_DRIVER_UART_WAKEUP_PRIORITY
Set the wake-up priority of UART to high.
APP_DRIVER_HMAC_WAKEUP_PRIORITY
WAKEUP_PRIORITY_MID
Set the wake-up priority of HMAC to middle.
APP_DRIVER_I2C_WAKEUP_PRIORITY
Set the wake-up priority of I2C to high.
APP_DRIVER_I2S_WAKEUP_PRIORITY
Set the wake-up priority of I2S to high.
APP_DRIVER_QSPI_WAKEUP_PRIORITY
Set the wake-up priority of QSPI to high.
APP_DRIVER_RNG_WAKEUP_PRIORITY
WAKEUP_PRIORITY_MID
Set the wake-up priority of RNG to middle.
APP_DRIVER_SPI_WAKEUP_PRIORITY
Set the wake-up priority of SPI to high.
APP_DRIVER_TIM_WAKEUP_PRIORITY
WAKEUP_PRIORITY_MID
Set the wake-up priority of TIM to middle.
APP_DRIVER_PWM_WAKEUP_PRIORITY
WAKEUP_PRIORITY_MID
Set the wake-up priority of PWM to middle.
APP_DRIVER_ISO7816_WAKEUP_PRIORITY
Set the wake-up priority of ISO7816 to high.
APP_DRIVER_PKC_WAKEUP_PRIORITY
Set the wake-up priority of PKC to high.
APP_DRIVER_DSPI_WAKEUP_PRIORITY
Set the wake-up priority of DSPI to high.
APP_DRIVER_PDM_WAKEUP_PRIORITY
Set the wake-up priority of PDM to high.
SOC_GPIO_PINS_MAX
Defined based on the available pins of an SoC
Set the number of GPIO pins.
SOC_AON_PINS_MAX
Set the number of AON_GPIO pins.
Configuring Supported SoC Series
APP_DRV currently supports the following SoC series. Macro definitions and more details are provided below.
Table 3 Supported SoC series
APP_DRIVER_GR551X
GR551x
APP_DRIVER_GR5525X
0x1
GR5x25
APP_DRIVER_GR5526X
0x2
GR5526
APP_DRIVER_GR5332X
0x3
GR533x
APP_DRIVER_GR5405 0x3 GR5405
Users can choose the SoC series in use. For example, a GR551x SoC is represented by SOC_GR5515, which is defined in custom_config.h.
Table 4 Choosing the SoC series
SoC Series Macro
SOC_GR5515
APP_DRIVER_GR551X
SOC_GR5x25
APP_DRIVER_GR5525X
SOC_GR5526
APP_DRIVER_GR5526X
SOC_GR533x
APP_DRIVER_GR5332X
SOC_GR5405 APP_DRIVER_GR5405
Wake-up Priority Configuration
When the system is woken up from sleep, peripherals will be woken up according to the set priority.
wakeup_priority_t
The priority to wake up peripherals is enumerated as below.
Table 5 wakeup_priority_t
Member Description
WAKEUP_PRIORITY_LOW = 1
Low wake-up priority
WAKEUP_PRIORITY_MID = 2
Middle wake-up priority
WAKEUP_PRIORITY_HIGH = 3
High wake-up priority
Users can configure the priority to wake up each peripheral as needed. For example, to set the wake-up priority of the ADC module, users can make the configuration as below.
#ifndef APP_DRIVER_ADC_WAKEUP_PRIORITY
#define APP_DRIVER_ADC_WAKEUP_PRIORITY              WAKEUP_PRIORITY_HIGH  /**< ADC Wakeup
        priority High */
#endif
