Documentation > GR5525 Datasheet/ Product Overview Copy URL
Product Overview
The Goodix GR5525 series is a single-mode, low-power Bluetooth 5.3 System-on-Chip (SoC). It can be configured as a Broadcaster, an Observer, a Central, and a Peripheral and supports the combination of all the above roles, making it an ideal choice for Internet of Things (IoT) and smart wearable devices. In addition, it supports Bluetooth Low Energy (Bluetooth LE) direction finding: angle of arrival (AoA) and angle of departure (AoD).
Based on Arm® Cortex®-M4F CPU core running at 96 MHz, the GR5525 integrates a 2.4 GHz RF transceiver, Bluetooth LE 5.3 protocol stack, on-chip programmable Flash memory, 256 KB system SRAM, and a rich set of peripherals, enhanced I2C/UART port number for sensor applications, as well as expanded I/O functionality. The GR5525 MCU enhances QSPI interface to support external RAM (PSRAM) to accommodate display overhead while still leaving plenty of space for wearable schemes.
Table 1 GR5525 series
Part Number GR5525RGNI GR5525IGNI GR5525IENI GR5525I0NI
CPU Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F
RAM 256 KB 256 KB 256 KB 256 KB
SiP Flash 1 MB 1 MB 512 KB N/A
I/O number 50 39 39 39
I/O voltage 1.8 V–3.6 V 1.8 V–3.6 V 1.8 V–3.6 V In line with Flash voltage
Package (mm)
QFN68 (7.0 x 7.0 x 0.85)
QFN56 (7.0 x 7.0 x 0.75)
