Features
    • AoA and AoD direction finding
    • TX power: –20 dBm to +7 dBm
    • RX sensitivity
      • –97 dBm sensitivity @ 1 Mbps mode
      • –93 dBm sensitivity @ 2 Mbps mode
      • –101 dBm sensitivity @ Long Range 500 kbps mode
      • –103 dBm sensitivity @ Long Range 125 kbps mode
  • On-chip memory
    • 1 MB internal QSPI Flash (512 KB for GR5525IENI, and external Flash for GR5525I0NI)
  • Digital peripherals
  • Analog peripherals
  • Flexible serial peripherals
  • Security
      • Secure boot
  • I/O peripherals
  • Timers
  • Power management
    • Supply voltage: 2.4 V–3.8 V
    • I/O voltage: 1.8 V–3.6 V
  • Low-power consumption
  • Operating temperature range: –40°C to +85°C
  • Packages
