Features
- Bluetooth LE 5.3
          transceiver
 - TX power: –20 dBm to +7 dBm
 - RX
              sensitivity
- –97 dBm sensitivity @ 1 Mbps mode
 - –93 dBm sensitivity @ 2 Mbps mode
 - –101 dBm sensitivity @ Long Range 500 kbps mode
 - –103 dBm sensitivity @ Long Range 125 kbps mode
 - Power
            consumption at 3.3 V VBAT input:
- 6.3 mA TX current @ 0 dBm output power (64 MHz system clock)
 - 5.3 mA RX current @ 1 Mbps (64 MHz system clock)
 - Arm®
          Cortex®-M4F 32-bit micro-processor with floating point support
- Up to 96 MHz clock frequency
 - 56 µA/MHz CoreMark running from Flash @ 3.3 V, 64 MHz from HFXO
 - On-chip memory
- 256 KB RAM data memory with retention capabilities
 - 8 KB cache RAM instruction memory with retention capabilities
 - Stack ROM (including boot ROM and Bluetooth LE Stack)
 - Flash for code, system parameter configuration, and user data (GR5525I0NI: external Flash, GR5525IENI: 512 KB, GR5525RGNI: 1 MB)
 - Digital peripherals
- 2 x general-purpose DMA engines with six channels and up to 16 programmable request/trigger sources
 - Analog peripherals
- 1 x 13-bit Sense ADC with sampling rate of 1 Msps, supporting up to eight external I/O channels and three internal signal channels
 - Flexible serial
          peripherals
- 4 x UART modules up to 2 Mbps with flow control and IrDA features
 - 4 x I2C modules for peripheral communication, up to 3.4 MHz, operating as either Master or Slave
 - 2 x I2S interfaces (1 x I2S master interface and 1 x I2S slave interface)
 - PDM interface with hardware sampling rate converter
 - 1 x Dual-lane SPI (DSPI) interface for display, with MIPI DBI Type-C support
 - 3 x Quad SPI (QSPI) interfaces, up to 48 MHz; supporting direct access via memory mapping when connecting with external NOR Flash
 - Security
- Complete secure
            computing engine:
- AES 128-bit/192-bit/256-bit symmetric encryption (ECB, CBC)
 - Hash-based Message Authentication Code (HMAC-SHA256)
 - Public key cryptography (PKC)
 - Comprehensive
            security operation mechanism:
- Secure boot
 - Encrypted firmware running directly from Flash
 - Complete secure
            computing engine:
 - I/O peripherals
- Up to 50
            multiplexed I/O pins in total
- Up to 34 general-purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors
 - Up to eight always-on I/O (AON I/O) pins, supporting wakeup from sleep mode
 - Up to eight mixed signal I/O (MSIO) pins, configurable to be digital/analog signal interfaces
 - Up to 50
 - Timers
 - 2 x 3-channel PWMs with edge-aligned and center-aligned modes
 - 2 x real-time counters (1 x Calendar, 1 x real-time counter)
 - Power management
- On-chip DC-DC to provide RF analog voltage and supply core LDO
 - Supply voltage: 2.4 V–3.8 V
 - I/O voltage: 1.8 V–3.6 V
 - Low-power consumption
- Sleep mode: 7.3 µA (Typical) at 3.3 V VBAT input, wakeup sources from always-on domain, and LFXO_32K running
 - Ultra deep sleep mode: 5.0 µA (Typical), with no memory data in retention and wakeup sources from SLP Timer or AON I/Os
Operating temperature range: –40°C to +85°C
 - Packages
- QFN68: 7.0 x 7.0 x 0.85 mm, 0.35 mm pitch
 - QFN56: 7.0 x 7.0 x 0.75 mm, 0.4 mm pitch
