Documentation > GR5525 Datasheet/ Product Overview Copy URL
Product Overview
The Goodix GR5525 series is a single-mode, low-power Bluetooth 5.3 System-on-Chip (SoC). It can be configured as a Broadcaster, an Observer, a Central, and a Peripheral and supports the combination of all the above roles, making it an ideal choice for Internet of Things (IoT) and smart wearable devices.
Based on Arm® Cortex®-M4F CPU core running at 96 MHz, the GR5525 integrates a 2.4 GHz RF transceiver, Bluetooth LE 5.3 protocol stack, on-chip programmable Flash memory, 256 KB system SRAM, and a rich set of peripherals, enhanced I2C/UART port number for sensor applications, as well as expanded I/O function. The GR5525 MCU enhances QSPI interface to support external RAM (PSRAM) to accommodate display while still leaving plenty of space for wearable schemes.
Table 1 GR5525 series
Part Number GR5525RGNI GR5525IENI (NRND) GR5525I0NI
CPU Cortex®-M4F Cortex®-M4F Cortex®-M4F
RAM 256 KB 256 KB 256 KB
SiP Flash 1 MB 512 KB N/A
I/O number 50 39 39
I/O voltage 1.8 V–3.6 V 1.8 V–3.6 V In line with Flash voltage
Package (mm)
QFN68 (7.0 x 7.0 x 0.85)
QFN56 (7.0 x 7.0 x 0.75)
GR5525IENI is not recommended for new designs (NRND).
