Features
    • TX power:
      • Up to 6 dBm on GR5331
      • Up to 15 dBm on GR5332
    • RX sensitivity:
      • -97.5 dBm @ 1 Mbps on GR5331
      • -99 dBm @ 1 Mbps on GR5332
    • Power consumption at 3.3 V VBAT input on GR5331:
      • 3.8 mA TX current @ 0 dBm output power (DC-DC supply, 16 MHz system clock)
      • 4.7 mA RX current @ 1 Mbps (DC-DC supply, 16 MHz system clock)
    • Power consumption at 3.3 V VBAT input on GR5332:
      • 5.9 mA TX current @ 0 dBm output power (DC-DC supply, 16 MHz system clock)
      • 86.3 mA TX current @ 15 dBm output power (SYS_LDO supply, 64 MHz system clock)
      • 4.9 mA RX current @ 1 Mbps (DC-DC supply, 16 MHz system clock)
  • Arm® Cortex®-M4F 32-bit micro-processor with floating point support:
    • 32 µA/MHz CoreMark running from Flash @ 3.3 V, 64 MHz from HFRC
  • On-chip memory
    • 96 KB RAM data memory with retention capabilities
    • ROM for boot and partial Bluetooth LE Protocol Stack code
    • 512 KB internal Flash
  • Digital peripherals
    • 1 x general-purpose DMA engine with five channels and 16 handshaking interfaces
  • Analog peripherals
    • 1 x 13-bit Sense ADC with a sampling rate of 1 Msps, supporting up to eight external I/O channels and three internal signal channels
  • Flexible serial peripherals with arbitrary mapping on all digital I/Os
    • 2 x UART modules up to 2 Mbps with flow control and IrDA features
    • 2 x I2C modules for peripheral communication, up to 1 MHz, operating as either Master or Slave
  • Security
    • AES 128-bit security module (ECB, CBC)
  • I/O peripherals
    • Up to 32 multiplexed I/O pins in total
      • Up to 14 general-purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors
      • Up to 10 mixed signal I/O (MSIO) pins, configurable to be digital/analog signal interfaces
  • Timers
    • 2 x 3-channel PWMs with edge-aligned mode and center-aligned mode
    • 1 x real-time counter
  • Power management
    • On-chip DC-DC/SYS_LDO to provide RF analog voltage and supply CORE_LDO
    • Supply voltage: 2.0 V–3.63 V
    • I/O voltage: 1.8 V–3.6 V
  • Low-power consumption
    • Sleep mode: 2.6 µA (Typical) at 3.3 V VBAT input, with 48 KB SRAM retention on, wakeup sources from AON I/Os, and LFXO_32K running
    • Ultra deep sleep mode: 1.9 µA (Typical), with no memory data in retention and wakeup sources from SLP Timer or AON I/Os
  • Operating temperature range
    • GR5331: -40°C to 85°C
    • GR5332: -40°C to 105°C
  • Packages
    • QFN32: 4.0 x 4.0 x 0.75 mm, 0.4 mm pitch
    • QFN48: 6.0 x 6.0 x 0.75 mm, 0.4 mm pitch
