Features
    • TX power: Up to 15 dBm
    • RX sensitivity: -99 dBm @ 1 Mbps
      • 6.7 mA TX current @ 0 dBm output power (DC-DC supply, 64 MHz system clock)
      • 87 mA TX current @ 15 dBm output power (SYS_LDO supply, 64 MHz system clock)
      • 5.7 mA RX current @ 1 Mbps (DC-DC supply, 64 MHz system clock)
    • Up to eight simultaneous connections
  • Arm® Cortex®-M4F 32-bit micro-processor with floating point support:
    • 39 µA/MHz CoreMark running from Flash @ 3.3 V, 64 MHz from HFRC
  • On-chip memory
    • ROM for chip bootloader, system drivers, and Bluetooth LE Protocol Stack code
    • 96 RAM for data and instruction code, with retention capabilities in sleep mode
    • 512 KB Flash for code, system parameter configuration, and user data
  • Digital peripherals
    • 1 x general-purpose DMA engine with five channels and 16 handshaking interfaces
  • Analog peripherals
    • 1 x 13-bit Sense ADC with a sampling rate of 1 Msps, supporting up to five external I/O channels and three internal signal channels
  • Flexible serial peripherals with arbitrary mapping on all digital I/Os
    • 2 x UART modules up to 2 Mbps with flow control and IrDA features, supporting LIN protocol adaption
    • 2 x I2C modules for peripheral communication, up to 1 MHz, operating as either Master or Slave
  • Security
    • AES 128-bit security module (ECB, CBC)
  • I/O peripherals
    • 24 multiplexed I/O pins in total
      • Nine general-purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors
      • Eight always-on I/O (AON I/O) pins, supporting wakeup from sleep mode
      • Seven mixed signal I/O (MSIO) pins, configurable to be digital/analog signal interfaces
  • Timers
    • 2 x 3-channel PWMs with edge-aligned mode and center-aligned mode
    • 1 x real-time counter
  • Power management
    • On-chip DC-DC/SYS_LDO to provide RF analog voltage and supply CORE_LDO
    • Supply voltage: 2.3 V−3.6 V
    • I/O voltage: 2.3 V−3.6 V
  • Low-power consumption
    • Sleep mode: 3.3 µA (Typical) at 3.3 V VBAT input, with 48 KB SRAM retention on, wakeup sources from AON I/Os, and LFXO_32K running
    • Ultra deep sleep mode: 2.6 µA (Typical), with no memory data in retention and wakeup sources from SLP Timer or AON I/Os
  • Operating temperature range
    • -40°C to 105°C
  • Qualification
    • AEC-Q100 Grade 2
  • Packages
    • Wettable flank-plated QFN40: 6.0 x 6.0 x 0.75 mm, 0.5 mm pitch
