Import and Export
GProgrammer allows users to export all parameter data (Parameter Name, Description, Length, and Value) to a local JSON configuration file as well as import local JSON configuration files to GProgrammer.
Tip:
- Parameters in the imported JSON files replace all those listed in the Parameters pane.
- Export modified parameter data to a local JSON file to prevent repeated modification.
- Export is unavailable when parameters in unfinished state exist.
- All data displayed in the Chip Configuration interface can be exported by clicking Export.
