SoC Selection
Start GProgrammer. Prior to other operations, you are required to choose the SoC model on your target board and click OK.
Tip:
By default, GProgrammer opens the SoC selection interface when being started.
On the SoC selection interface, the left pane lists Products and Kits options, and the right pane shows the available choices. You can select an SoC by defining its Part Number, Series, Core, Memory, Package, or Peripheral.
Tip:
Peripherals listed on the SoC selection interface are only part of the peripherals of an SoC. For details of all peripherals, see the datasheet corresponding to SoC series.
