Features
    • Supported data rates: 1 Mbps, 2 Mbps, Long Range 500 kbps, Long Range 125 kbps
    • TX power: -20 dBm to +7 dBm
    • -97 dBm sensitivity (in 1 Mbps mode)
    • -99.5 dBm sensitivity (in Long Range 500 kbps mode)
    • -103 dBm sensitivity (in Long Range 125 kbps mode)
    • TX current: 3.05 mA @ 0 dBm, 1 Mbps
    • RX current: 3.9 mA @ 1 Mbps
    • Maximum frequency: 64 MHz
    • Power consumption: 30 µA/MHz
  • Memory
    • 256 KB RAM with retention (four 8 KB RAM blocks and seven 32 KB RAM blocks) for GR5515 series SoCs, and 128 KB RAM with retention (four 8 KB RAM blocks and three 32 KB RAM blocks) for the GR5513 SoC.
    • 1 MB Flash for GR5515 series SoCs (The GR5515I0ND SoC uses external QSPI Flash with various model options.) and 512 KB Flash for the GR5513 SoC.
  • Power management
    • On-chip DC-DC Converter
    • Supply voltage: 1.7 V to 3.8 V (The supply voltage of the GR5515I0ND SoC is equal to the working voltage of external SPI Flash.)
    • I/O voltage: 1.8 V to 3.3 V (Typical) (On GR5515I0ND, VDDIO0 is bonded to VIO_LDO_OUT internally and I/O LDO is set to off mode in the application firmware by default, so VIO_LDO_OUT shall be connected to VBATL.)
    • OFF mode: 0.15 µA (Typical); nothing is on except VBAT, chip in reset mode
    • Ultra deep sleep mode: 0.65 µA (Typical); I/O LDO off, no memory retention. Wake-up on an external GPIO or an internal Timer.
    • Sleep mode: 1.3 µA (Typical); Bluetooth LE link alive, I/O LDO off, supporting AON_RTC, AON GPIO and Bluetooth LE Event, memory retention and wake-up on an external GPIO or an internal Timer.
  • Peripherals
    • 2 x SPI interfaces (1 SPI Master Interface with 2 slave CS pins + 1 SPI Slave Interface), up to 32 MHz
    • 2 x I2C interfaces at 100 kHz, 400 kHz, 1 MHz, 2 MHz
    • 2 x I2S interfaces (1 I2S Master Interface + 1 I2S Slave Interface)
    • 2 x UART interfaces, one with DMA channel.
    • 13-bit ADC, up to 1 Msps, 8 channels (5 external test channels and 3 internal signal channels), supporting both single-ended and differential inputs
    • ISO 7816 interface
    • 6-channel PWM
    • 4 x Hardware timers
    • 1 x AON hardware timer
    • 2 x Watchdog timers(1 System Watchdog Timer and 1 Always-on watchdog timer)
    • Calendar timer
    • Wake-up comparator
    • Up to 39 multiplexed GPIO pins
  • Security
      • Keyed Hash Message Authentication Code (HMAC)
      • PKC
      • TRNG
      • Secure boot
      • Encrypted firmware runs directly from Flash
  • Packages
    • QFN56: 7 mm x 7 mm
    • BGA68: 5.3 mm x 5.3 mm
    • BGA55: 3.5 mm x 3.5 mm
    • QFN40: 5 mm x 5 mm
