Documentation > GR551x Datasheet Brief / GR551x Overview Copy URL
GR551x Overview
Table 1 GR551x series
GR551x Series GR5515IGND GR5515IENDU GR5515I0ND GR5515I0NDA GR5515RGBD GR5515GGBD GR5513BEND GR5513BENDU
CPU Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F Cortex®-M4F
RAM 256 KB 256 KB 256 KB 256 KB 256 KB 256 KB 128 KB 128 KB
Flash 1 MB 512 KB N/A N/A 1 MB 1 MB 512 KB 512 KB
Package (mm)
QFN56 (7 x 7 x 0.75)
BGA68 (5.3 x 5.3 x 0.88)
BGA55 (3.5 x 3.5 x 0.60)
QFN40 (5 x 5 x 0.75)
I/O Number 39 39 39 39 39 29 22 22
  • GR5515RGBD is not recommended for new designs.
  • GR5515IENDU and GR5513BENDU are embedded with wide-voltage Flash, with Flash power supply from 1.65 V to 3.6 V.
  • GR5515I0ND supports external high-voltage Flash (typical: 3.3 V); GR5515I0NDA supports external wide-voltage Flash (range: 1.65 V–3.6 V).
