603160.SH
Log In
603160.SH
Block Diagram
Figure 1 shows the block diagram of GR551x.
Figure 1 GR551x block diagram
  • Bluetooth Subsystem
    • A 2.4 GHz transceiver and a digital communication core that supports Bluetooth LE 5.1.
  • MCU Subsystem
    • An ARM® Cortex®-M4F with all the required memories and peripherals.
    • Security cores that can be used for application security and to secure boot implementation.
  • Power Management Unit (PMU) Subsystem
    • All the required power management modules to supply sufficient power to both internal modules and external peripherals.
    • Modules required for ultra-low-power operation in standby mode. Sleep clock (Sleep Osc.), wakeup GPIOs (Wake up), low-power comparator (LP Comp.), and power state controller (Power Sequencer) are used to control the state of different modules.
Share the page to your moments
Open WeChat and use 'scan QR Code' to share the page to your moments.
