Generating Firmware
After building a Bluetooth LE application, you can directly click Build on the Keil toolbar to build a project. After the project is built, the following firmware files are generated in Keil_5\Listings and Keil_5\Objects respectively in the project directory. Both of the firmware files can be downloaded to a GR551x SoC via GProgrammer. For details, see GProgrammer User Manual. The ble_app_example.hex file can be downloaded to a GR551x SoC via Keil MDK.
| Name | Description |
| ble_app_example.bin | Binary application firmware; can be downloaded to an SoC through GProgrammer |
| ble_app_example.hex | Hexadecimal application firmware; can be downloaded to an SoC through GProgrammer or Keil MDK |
