Features
    • Supported data rates: 1 Mbps, 2 Mbps, and Long Range (500 kbps, 125kbps)
    • TX power: -20 dBm to +7 dBm
    • -96 dBm sensitivity (in 1 Mbps mode)
    • -99 dBm sensitivity (in Long Range 500 kbps mode)
    • -102 dBm sensitivity (in Long Range 125 kbps mode)
    • TX current: 5.6 mA @ 0 dBm, 1 Mbps
    • RX current: 4.8 mA @ 1 Mbps
    • Serial Wire Debug (SWD) with 6 breakpoints, two watchpoints, and a debug timestamp counter
    • 51 µA/MHz execution from Flash @ 3.3 V, 64 MHz
  • On-chip memory
    • 256 KB SRAM with retention capabilities (four 8 KB SRAM blocks and seven 32 KB SRAM blocks) for GR5515 series SoCs, and 128 KB SRAM with retention capabilities (four 8 KB SRAM blocks and three 32 KB SRAM blocks) for the GR5513 SoC
    • 1 MB internal QSPI Flash for GR5515 series SoCs and 512 KB internal QSPI Flash for the GR5513 SoC (exceptions: GR5515I0NDA requiring external QSPI Flash and GR5515IENDU requiring 512 KB embedded Flash)
  • Digital peripherals
    • One general-purpose DMA engine with 8 channels and 16 handshaking interfaces
  • Analog peripherals
    • One 13-bit Sense ADC with the sampling rate of 1 Msps. It supports up to five external I/O channels and three internal signal channels
  • Flexible serial peripherals
    • 2 x UART modules up to 4 Mbps, with all modules supporting flow control and only UART0 supporting DMA
    • 2 x I2C modules for peripheral communication, up to 2 MHz
    • 1x SPI master interface and 1 x SPI slave interface for host communication, up to 32 MHz
    • 2 x I2S interfaces (1 I2S master interface + 1 I2S slave interface)
    • ISO7816 interface
  • Security
      • Secure boot
  • I/O peripherals
    • 39 I/O pins in total
      • 26 general-purpose I/O (GPIO) pins
      • 5 mixed signal I/O (MSIO) pins, configurable to be digital/analog signal interface
  • Timer
    • 1 x real-time counter (RTC), can be used as Calendar
    • 1 x AON watchdog timer, working in both system sleep and active status
  • Power management
    • Programmable thresholds for brownout detection (BoD reset and BoD interrupt)
    • Supply voltage: 2.2 V to 3.8 V. The supply voltage of GR5515I0NDA (when the external Flash of GR5515I0NDA is supplied by high voltage) shall equal the working voltage of the external QSPI Flash
    • I/O voltage: 1.8 V to 3.3 V (Typical) (for GR5515I0NDA/GR5515IENDU/GR5513BENDU Flash using high voltage, the VIO_LDO_OUT shall be connected to VBATL in schematic circuit.)
  • Low-power consumption modes
    • Deep sleep mode: 2.7 µA (Typical), with full 256 KB SRAM retention
    • Ultra deep sleep mode: 1.8 µA (Typical), no SRAM retention
    • Off mode: 0.15 uA (Typical), nothing on except VBAT, and chip in reset mode
  • Packages
    • QFN56: 7 mm x 7 mm, 0.40 mm pitch
    • BGA68: 5.3 mm x 5.3 mm, 0.50 mm pitch
    • BGA55: 3.5 mm x 3.5 mm, 0.40 mm pitch
    • QFN40: 5 mm x 5 mm, 0.40 mm pitch
