603160.SH
Log In
603160.SH
The Second Boot example performs the functions of device firmware update (DFU), checking validity, jumping to, and running application firmware, as well as secure signature verification over Bluetooth Low Energy (Bluetooth LE) transmission and second boot of firmware, providing users with flexible, reliable, and secure Over-the-Air (OTA) functions.
  • Background dual-bank DFU by copying the firmware: Update the firmware by copying the firmware from one bank to another through OTA over Bluetooth LE transmission.
  • Checking validity, jumping to, and running application firmware: Compare the application firmware information with the information in APP Image Info. Jump to and run the application firmware (ble_tem_dfu.bin is used as an example in this document) if the information from the two sources matches.
  • Secure verification: Sign the firmware to protect it against tampering and achieve non-repudiation. The Second Boot example verifies the signature before update.
Table 1 Reference documents
Name Description
GR551x Developer Guide
Introduces GR551x Software Development Kit (SDK) and how to develop and debug applications based on the SDK.
GR551x DFU Application Note
Introduces the principles and methods of Device Firmware Update for GR551x System-on-Chips (SoCs).
GR551x OTA Example Application
Introduces how to implement Over The Air for GR551x firmware on GRToolbox.
GProgrammer User Manual
Lists GProgrammer operational instructions, including downloading firmware to and encrypting firmware on GR551x SoCs.
GR551x Firmware Encryption Application Note
Introduces how to encrypt data and firmware of GR551x SoCs.
J-Link/J-Trace User Guide
Provides J-Link operational instructions. Available at http://www.segger.com/downloads/jlink/UM08001_JLink.pdf.
Keil User Guide
Offers detailed Keil operational instructions. Available at https://www.keil.com/support/man/docs/uv4/.
Share the page to your moments
Open WeChat and use 'scan QR Code' to share the page to your moments.
