Wakeup Sources
Wakeup sources can wake GR551x SoCs up from low power modes, including from Idle Mode to Active Mode, or from Sleep Mode to Active Mode.
Idle Mode: ARM processors go into Idle Mode and remain the state after executing a WFE or WFI command. Wakeup sources from Idle Mode to Active Mode are:
  • Reset
  • NVIC Event
  • Debug Event
Sleep Mode: When the system is in Sleep Mode, only the modules located in Always-on Domain can wake up the system and enable it to enter the warm boot process. Wakeup sources from Sleep Mode to Active Mode are:
  • Bluetooth LE Timer
  • Sleep Timer
  • Real Time Calendar
  • AON GPIO
  • LPCOMP
  • Reset
Users can call the following API in an SDK to configure wakeup sources:
void pwr_mgmt_wakeup_source_setup(uint32_t wakeup_source);
For more information about configuration of wakeup sources, see GR551x Datasheet.
