Enable Sleep Mode
Users can configure Active Mode, Idle Mode, and Sleep Mode of the system by using the pwr_mgmt_mode_set() function.
* @brief Set the specified sleep mode. When the setting is completed, the system will
* automatically enter the specified sleep mode through the strategy.
* @param[in] pm_mode : sleep level
* @retval : void
void pwr_mgmt_mode_set(pwr_mgmt_mode_t pm_mode);
Path: SDK_Folder\components\sdk
The parameter pm_mode of pwr_mgmt_mode_set() function is used to set Sleep Mode of the system.
| Value of pm_mode | Description |
PMR_MGMT_ACTIVE_MODE |
The system goes into Active Mode and remains in this state, and runs at full speed. |
PMR_MGMT_IDLE_MODE |
The system is permitted to go into Idle Mode and switch between Active Mode and Idle Mode.
PMR_MGMT_SLEEP_MODE |
The system is permitted to go into Sleep Mode and switch between Active Mode, Idle Mode, and Sleep Mode according to the sleep policy.
Configure Active Mode
Set the value of pm_mode of pwr_mgmt_mode_set() function to PMR_MGMT_ACTIVE_MODE, to keep the system in Active Mode. Unused memory blocks are configured automatically during system initialization. Users can also control the power supply and clocks of unused memory blocks, to reduce power consumption in Active Mode.
Configure Idle Mode
Set the value of pm_mode of pwr_mgmt_mode_set() function to PMR_MGMT_IDLE_MODE, so as to allow the system to switch between Active Mode and Idle Mode, depending on whether any task is to be processed. In the main() function of the example project, the pwr_mgmt_schedule() function automatically disables corresponding modules according to the sleep policy. For example, if no Bluetooth task is to be processed, the ble_core_sleep() function will power off the Bluetooth Subsystem, and enable the MCU Subsystem to automatically go into Idle Mode after it completes current tasks.
Configure Sleep Mode
Generally, the warm boot model of the system shall by applied in the Sleep Mode.
- Sleep Mode
Set the value of pm_mode of pwr_mgmt_mode_set() function to PMR_MGMT_SLEEP_MODE, so as to enable the system to switch between Active Mode, Idle Mode, and Sleep Mode according to the sleep policy. In the main() function of the example project, the pwr_mgmt_schedule() function automatically powers all the power domains off (except for Always-on Domain), and sets part of RAM to Retention RAM to lower power consumption according to the sleep policy.
- Warm boot
The driver interface supports recovery from warm boot, and the warm boot process requires no user involvement.
Path: SDK_Folder\toolchain\gr55xx\source\
