The Direct Test Mode (DTM) is a standard mechanism defined by Bluetooth Special Interest Group (Bluetooth SIG) to test the radio frequency (RF) performance of Bluetooth devices for all Bluetooth channels. In general, DTM is used in application validation and product line tests, enabling RF engineers to effortlessly verify and optimize Bluetooth RF performances. Tested RF factors include:
- Transmission power and receiver sensitivity
- Frequency offset and drift
- Modulation characteristics
- Packet error rate
The DTM test on GR551x SoCs is based on UART physical interfaces and a Bluetooth tester. The Bluetooth tester controls GR551x RF physical layer (PHY) by using Host Controller Interface commands (HCI CMD) to implement test procedures.
Name | Description |
GR551x Developer Guide | Introduces the software/hardware and quick start guide of GR551x SoCs. |
Keil User Guide |
RF PHY Bluetooth Test Suite TS |
Introduces RF PHY test specifications. For Core-Test Requirements, see http://bluetooth.com/specifications/qualification-test-requirements/. |
