GR551x Fault Trace Module aims to help developers identify problems during Bluetooth application development. When GR551x firmware fails to operate normally, GR551x Fault Trace Module can write fault trace data to the Non-Volatile Data Storage (NVDS) in Flash, and export the fault trace data from NVDS, so as to restore the failure scenario and help identify problems.
GR551x Fault Trace Module can write fault trace data to NVDS in the following two scenarios:
- When a HardFault occurs, the Fault Trace Module can write the current values of the internal registers to the NVDS.
- When Assert faults occur, the Fault Trace Module can write the function names, the number of code lines, parameter names, and other relevant information to the NVDS.
| Name | Description |
GR551x Developer Guide |
GR551x Bluetooth Low Energy Stack User Guide |
Introduces the layers and basic layer functionalities of a GR551x Bluetooth LE Protocol Stack, and how applications interact with the protocol stack using APIs on the stack. |
J-Link/J-Trace User Guide |
Provides J-Link operational instructions. Available at https://www.segger.com/downloads/jlink/UM08001_JLink.pdf . |
Keil User Guide |
Bluetooth Core Spec |
Bluetooth GATT Spec |
Provides details about Bluetooth profiles and services. Available at https://www.bluetooth.com/specifications/gatt |
GProgrammer User Manual |
Lists GProgrammer operational instructions including downloading firmware to and encrypting firmware on GR551x SoCs. |
