FreeRTOS is an excellent embedded real-time operating system for microcontrollers. Being light-weighted, distributed freely under MIT open-source License, and built with an emphasis on portability, tailorability, and flexible scheduling policy, it requires low RAM/ROM consumption and supports management of task, time, semaphore, message queue, and memory.
This document introduces the FreeRTOS porting example in the GR551x SDK, including usage of the example and descriptions of major source code.
| Name | Description |
GR551x Developer Guide |
Keil User Guide |
FreeRTOS Documentation |
Provides guidance on using FreeRTOS. Available at https://www.freertos.org/Documentation/RTOS_book.html. |
