Product Overview
The Goodix GR5525 series is a single-mode, low-power Bluetooth 5.3 System-on-Chip (SoC). It can be configured as a Broadcaster, an Observer, a Central, and a Peripheral and supports the combination of all the above roles, making it an ideal choice for Internet of Things (IoT) and smart wearable devices.
Based on Arm® Cortex®-M4F CPU core running at 96 MHz, the GR5525 integrates a 2.4 GHz RF transceiver, Bluetooth LE 5.3 protocol stack, on-chip programmable Flash memory, 256 KB system SRAM, and a rich set of peripherals, enhanced I2C/UART port number for sensor applications, as well as expanded I/O function. The GR5525 MCU enhances QSPI interface to support external RAM (PSRAM) to accommodate display while still leaving plenty of space for wearable schemes.
| Part Number | GR5525RGNI | GR5525IENI (NRND) | GR5525I0NI |
| CPU | Cortex®-M4F | Cortex®-M4F | Cortex®-M4F |
| RAM | 256 KB | 256 KB | 256 KB |
| SiP Flash | 1 MB | 512 KB | N/A |
| I/O number | 50 | 39 | 39 |
| I/O voltage | 1.8 V–3.6 V | 1.8 V–3.6 V | In line with Flash voltage |
| Package (mm) |
QFN68 (7.0 x 7.0 x 0.75) |
QFN56 (7.0 x 7.0 x 0.75) |
GR5525IENI is not recommended for new designs (NRND).
