Product Overview
The Goodix GR533x series is a Bluetooth Low Energy (Bluetooth LE) 5.3 System-on-Chip (SoC), suitable for IoT applications, supporting Bluetooth mesh networking protocols.
Based on Arm® Cortex®-M4F CPU core running at 64 MHz, the GR533x integrates a 2.4 GHz RF transceiver, Bluetooth LE 5.3 protocol stack, 512 KB on-chip Flash memory, 96 KB system SRAM, and a rich set of peripherals. It provides excellent RF performance, with a maximum of +15 dBm TX power, -99 dBm RX sensitivity and a maximum of 114 dB link budget in Bluetooth LE 1 Mbps mode.
With two main power supply schemes (DC-DC and system LDO), the GR533x offers flexible options to achieve a balance between low power consumption and economical BOM.
GR533x devices are offered in both QFN32 and QFN48 packages. The following table lists the detailed package configurations.
| Part Number |
GR5331AENI |
GR5331CENI |
GR5332AENE |
GR5332CENE |
| CPU |
Cortex®-M4F |
Cortex®-M4F |
Cortex®-M4F |
Cortex®-M4F |
| RAM |
96 KB |
96 KB |
96 KB |
96 KB |
| SiP Flash |
512 KB |
512 KB |
512 KB |
512 KB |
| TX power |
Up to 6 dBm |
Up to 6 dBm |
Up to 15 dBm |
Up to 15 dBm |
| RX sensitivity |
-97.5 dBm @ 1 Mbps |
-99 dBm @ 1 Mbps |
-99 dBm @ 1 Mbps |
| Consumption |
3.8 mA TX @ 0 dBm 4.7 mA RX @ 1 Mbps |
5.9 mA TX @ 0 dBm 4.9 mA RX @ 1 Mbps |
| I/O number |
16 |
32 |
16 |
32 |
| Operating temperature |
-40°C to 85°C |
-40°C to 85°C |
-40°C to 105°C |
-40°C to 105°C |
| Package (mm) |
QFN32 (4 x 4 x 0.75) |
QFN48 (6 x 6 x 0.75) |
