GR5332 RF Transceiver
The system block diagram of a GR5332 RF transceiver is shown as follows:
- On the receiver side:
- After the antenna receives an RF signal, the receiver digitizes the signal in a path: Low noise amplifier (LNA) > Mixer > Baseband (BB) amplifier > analog-to-digital converter (ADC).
- The digitized signals are sent to the digital frontend (DFE) for demodulation.
- The digital frontend provides Automatic Gain Control (AGC) feedback signals to adjust the gain of the LNA and BB amplifier to maximize the signal-to-noise ratio (SNR) at the demodulation.
- On the transmitter side:
- The digital signal from the DFE is transmitted to a simplex phase-locked loop (SXPLL) for Gaussian Frequency Shift Keying (GFSK) modulation.
- The modulated carrier wave is delivered to a PA (HPA or SPA) through buffer for power amplification, with amplification factor configurable by the digital gain settings.
- The modulated carrier wave after power amplification is transmitted to the antenna, which then radiates the amplified carrier wave through electromagnetic waves.
Note:- If an HPA is adopted, the modulated carrier wave needs a single-ended to differential (S2D) conversion before power amplification.
- The SXPLL reference clock is provided by the external 32 MHz crystal oscillator.
- Power supply
- The main band gap and HPA in the GR5332 SoC are supplied by VBAT_RF.
- VDD_RF is the RF input power supply, which powers the VDD_RF, VDD_AMS, and VDD_VCO modules. VDD_RF supplies the RF analog circuits, VDD_AMS supplies the clock module and the receiver baseband module, and VDD_VCO supplies SXPLL.
