The GR5526 Starter Kit (GR5526 SK) is a development platform based on GR5526 System-on-Chips (SoCs) (supporting Bluetooth 5.3). It contains a GR5526 Starter Kit Board (GR5526 SK Board), design documents, and a user guide. This helps users quickly develop product prototype and verify related functions/performance, shortening product development and go-to-market periods.
The figure below shows the photo of a GR5526 SK Board:
By default, display application firmware has been programmed to a GR5526 SK Board. You can view demo graphics by connecting a GR5526 SK Board to a display daughter board. You can also generate firmware by compiling other application example projects provided in a GR5526 Software Development Kit (SDK) and then download the firmware to a GR5526 SK Board for debugging/testing.
Before you get started, it is recommended to refer to the following documents.
| Name | Description |
| GR5526 Developer Guide |
Introduces the software/hardware and quick start guide of GR5526 SoCs. |
| J-Link/J-Trace User Guide |
| GR5526-SK-BASIC-RevC |
Offers GR5526 SK Board schematic diagrams. |
| GProgrammer User Manual | Lists GProgrammer operational instructions including downloading firmware to and encrypting firmware on GR5526 SoCs. |
Features
- A single-mode Bluetooth Low Energy (Bluetooth LE) SoC that supports Bluetooth 5.3
- Multi-functional buttons and LEDs
- SEGGER J-Link OB that supports debugging
- UART-to-USB connector
- USB Type-C connector
- 1.39-inch circular color AMOLED touch display (454 x 454 dpi)
- On-board I2S Audio module
- Two on-board Pulse Density Modulation (PDM) digital microphones
- On-board QSPI Flash and PSRAM, with reserved interfaces for external Flash and PSRAM
- On-board AoA/AoD multi-antenna interface
- On-board adjustable boost circuit
- Battery level detection
- Reserved standard 2.54 mm jumper pin I/O interface
