The GR5331 Starter Kit (SK) is a hardware development platform based on GR533x System-on-Chips (SoCs) (supporting Bluetooth 5.3). It contains a Starter Kit Board (SK Board), design documents, and a user guide. This helps users quickly develop product prototype and verify related functions/performance, shortening product development and go-to-market periods.
The figure below shows the photo of a SK Board:
By default, no application firmware has been pre-downloaded to a SK Board. It is recommended to compile the example projects provided in GR533x Software Development Kit (SDK) to generate firmware and then download the firmware to a SK Board for debugging/testing.
Before you get started, it is recommended to refer to the following documents.
| Name | Description |
| GR533x Developer Guide | Introduces the software/hardware and quick start guide of GR533x SoCs. |
| J-Link/J-Trace User Guide | Provides J-Link operational instructions. Available at http://www.segger.com/downloads/jlink/UM08001_JLink.pdf. |
| GR533x-QFN48-SK-BASIC-RevB | Offers SK Board schematic diagrams. |
Features
- A single-mode Bluetooth LE SoC that supports Bluetooth 5.3
- SEGGER J-Link OB that supports debugging
- Multiple power supply modes and battery level detection
- JLINK_USB connector and UART_USB connector
- Multi-functional buttons and LEDs
- Interface for 1.44-inch color thin film transistor (TFT) LCD
- I/O interface for standard 2.54 mm pin connector
- I/O communication level supported: 3.0 V
