文档中心 > GR5526 Datasheet/ Peripherals/ Security Interfaces/ Public Key Cryptography (PKC) Copy URL
Public Key Cryptography (PKC) algorithm, also known as asymmetric key algorithm, uses a pair of keys: a public key and a private key. The security of the private key should be ensured. The public key can be published. Data encrypted with the public key can only be decrypted with the private key, and vice versa. The public key algorithm does not need an online key server, and the key distribution protocol is simple, which greatly simplifies the key management. In addition to the encryption function, the public key algorithm provides key exchange function and digital signature function.
  • Compliance with FIPS 186-4 standard
  • Supports Scalar multiplication for P-256 elliptic curve
  • Supports diverse modular operations:
    • Montgomery modular multiplication for a configurable 256–2048 bits’ length
    • Partial Montgomery Inversion for a configurable 256–2048 bits’ length
    • Modular addition for a configurable 256–2048 bits’ length
    • Modular subtraction for a configurable 256–2048 bits’ length
    • Modular comparison for a configurable 256–2048 bits’ length
    • Modular left-shift operation for a configurable 256–2048 bits’ length
    • Big integer multiplication for a configurable 256–1024 bits’ length
    • Big integer addition for a configurable 256–2048 bits’ length
    • Hardware dummy multiplication
  • Supports random clocking gating.
  • Protects register read/write operations (registers cannot be read or written in the DISABLE module state).
  • Supports interrupt and query.
Standard
表 690 PKC module standard
FIPS PUB 186-4
Digital Signature Standard (DSS) (Compliant with P-256)
SEC 2
Recommended Elliptic Curve Domain Parameters
Module Overview
The PKC controller module completes the basic underlying modular arithmetic and the FIPS standard 256-point ECC point multiplication in the public key algorithm. GR5526 embeds the PKC module in order to realize hardware acceleration of calculation.
图 137 PKC module in the system
PKC_TOP includes PKC_CORE, PKC_REG, RAND_CLK_GATE, and SP_RAM. PKC_CORE includes PKC_ENGINE and PKC_CTRL sub modules, in which PKC_ENGINE completes the basic underlying modular operations (modular multiplication, modular inversion, modular addition, modular subtraction, modular comparison, modular shift, big integer multiplication, big integer addition, and dummy multiplication) in the public key algorithm.
The ECC point multiplication only supports P-256 curve, such as secp256r1 and secp256k1. The public key algorithm needs a software library which can be open source or user-defined for implementation.
Usage
The CTRL register is used to start and reset the PKC module. The STAT register is used to indicate the status of the PKC module. The INT_EN register is used to configure the interrupt mode, and the INT_STAT register is used to indicate the interrupt status.
  • Point Multiplication: MCU writes the following parameters to SP_RAM that is a memory area of the PKC module. The parameters include the 256-bit random number k, order n, prime P, base point G, R2mod P, and the initial infinity point Q0. CFG0 to CFG12 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Modular Multiplication: MCU writes operand a, operand b, and prime p to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG0 and SW_CFG1 registers are used to configure the location pointers. The CFG13 register is used to configure the modular multiplication constant if the lowest 32-bit of prime p is not 0xFFFFFFFF. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Modular Inversion: MCU writes operand a, modulo p, x1 initial value 1, and x2 initial value 0 to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG4 and SW_CFG5 registers are used to configure the location pointers. The SW_CFG6 register is configured to save the intermediate result of modular inversion operation. The calculation can be started by using the CTRL register. MCU will read the modular inversion x1 from the SP_RAM and read the SW_CFG8 register to get the modular inversion k. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Modular Subtraction and Modular Addition: MCU writes operand a, operand b, and prime p to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG2 and SW_CFG3 registers are used to configure the location pointers. The calculation can be started with the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Modular Comparison and Modular Shift: MCU writes operand a and prime p to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG0 and SW_CFG1 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Big Integer Multiplication: MCU writes operand a and operand b to SP_RAM. The SW_CFG7 register is used to configure the operand word length. The maximum configurable length of the big number multiplication is 1024 bits. SW_CFG10 and SW_CFG11 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Big Integer Addition: MCU writes operand a and operand b to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG11 and SW_CFG12 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
  • Dummy Multiplication: The SW_CFG9 register is used to configure the random seed of dummy multiplication. The dummy multiplication can be started by using the CTRL register. Subsequently, modular addition or big integer addition is performed. The result of the modular addition or the big integer addition can be obtained.
  • Random Clock Gating: The SW_CFG13 register is used to configure the random seed of random clock gating. The random clock gating can be enabled by using the CTRL register. Subsequently, PKC operation can be performed.
CTRL
  • Name: PKC Controller Register
  • Description: This register acts as a global enable/disable for PKC.
  • Base Address: 0x40014000
  • Offset: 0x0
表 691 PKC Controller Register
31:9
8
RST
Write 0 and then write 1 to this bit to force the PKC core to reset.
7:5
4
SW_CTRL
Only used in software mode.
  • 0x0: Disable software controller.
  • 0x1: Enable software controller.
3:2
START
Only used in hardware mode. After MCU configures all parameters; write 0 and then write 1 to this bit, and the PKC starts to work.
EN
PKC core enable bit
  • 0x0: Disable PKC.
  • 0x1: Enable PKC.
CFG0
  • Name: PKC Configuration 0 Register
  • Description: This register acts as a configuration for PKC.
  • Offset: 0x4
  • Reset Value: 0x00100000
表 692 PKC Configuration 0 Register
31:25
24:16
R_POINT
0x10
R point in sp_ram
15:9
8:0
K_POINT
K point in sp_ram
CFG1
  • Name: PKC Configuration 1 Register
  • Offset: 0x8
  • Reset Value: 0x00280020
表 693 PKC Configuration 1 Register
31:25
24:16
R2_POINT
0x28
R^2 point in sp_ram
15:9
8:0
P_POINT
0x20
P point in sp_ram
CFG2
  • Name: PKC Configuration 2 Register
  • Offset: 0xC
  • Reset Value: 0x00380030
表 694 PKC Configuration 2 Register
31:25
24:16
GY_POINT
0x38
Gy point in sp_ram
15:9
8:0
GX_POINT
0x30
Gx point in sp_ram
CFG3
  • Name: PKC Configuration 3 Register
  • Offset: 0x10
  • Reset Value: 0x00480040
表 695 PKC Configuration 3 Register
31:25
24:16
R0X_POINT
0x48
R0x point in sp_ram
15:9
8:0
GZ_POINT
0x40
Gz point in sp_ram
CFG4
  • Name: PKC Configuration 4 Register
  • Offset: 0x14
  • Reset Value: 0x00580050
表 696 PKC Configuration 4 Register
31:25
24:16
R0Z_POINT
0x58
R0z point in sp_ram
15:9
8:0
R0Y_POINT
0x50
R0y point in sp_ram
CFG5
  • Name: PKC Configuration 5 Register
  • Offset: 0x18
  • Reset Value: 0x00680060
表 697 PKC Configuration 5 Register
31:25
24:16
R1Y_POINT
0x68
R1y point in sp_ram
15:9
8:0
R1X_POINT
0x60
R1x point in sp_ram
CFG6
  • Name: PKC Configuration 6 Register
  • Offset: 0x1C
  • Reset Value: 0x00780070
表 698 PKC Configuration 6 Register
31:25
24:16
TEMP1_POINT
0x78
Tmp1 point in sp_ram
15:9
8:0
R1Z_POINT
0x70
R1Z point in sp_ram
CFG7
  • Name: PKC Configuration 7 Register
  • Offset: 0x20
  • Reset Value: 0x00880080
表 699 PKC Configuration 7 Register
31:25
24:16
TEMP3_POINT
0x88
TMP3 point in sp_ram
15:9
8:0
TEMP2_POINT
0x80
TMP2 point in sp_ram
CFG8
  • Name: PKC Configuration 8 Register
  • Offset: 0x24
  • Reset Value: 0x00980090
表 700 PKC Configuration 8 Register
31:25
24:16
TEMP5_POINT
0x98
TMP5 point in sp_ram
15:9
8:0
TEMP4_POINT
0x90
TMP4 point in sp_ram
CFG9
  • Name: PKC Configuration 9 Register
  • Offset: 0x28
  • Reset Value: 0x00A800A0
表 701 PKC Configuration 9 Register
31:25
24:16
CONT1_POINT
0xA8
Constant 1 point in sp_ram
15:9
8:0
TEMP6_POINT
0xA0
TMP6 point in sp_ram
CFG10
  • Name: PKC Configuration 10 Register
  • Offset: 0x2C
  • Reset Value: 0x00B800B0
表 702 PKC Configuration 10 Register
31:25
24:16
X2_POINT
0xB8
X2 point in sp_ram
15:9
8:0
X1_POINT
0xB0
X1 point in sp_ram
CFG11
  • Name: PKC Configuration 11 Register
  • Offset: 0x30
  • Reset Value: 0x00C800C0
表 703 PKC Configuration 11 Register
31:25
24:16
KT_POINT
0xC8
Software computes 2^256 mod p and writes to sp_ram.
15:9
8:0
MIT_POINT
0xC0
MI point in sp_ram
CFG12
  • Name: PKC Configuration 12 Register
  • Offset: 0x34
  • Reset Value: 0x00D800D0
表 704 PKC Configuration 12 Register
31:25
24:16
B_POINT
0xD8
Curve parameter b in Montgomery field
15:9
8:0
A_POINT
0xD0
Curve parameter a in Montgomery field
CFG13
  • Name: PKC Configuration 13 Register
  • Offset: 0x38
  • Reset Value: 0x00000001
表 705 PKC Configuration 13 Register
31:0
CONSTQ
0x1
Constant used in Montgomery multiplication
SW_CTRL
  • Name: PKC Software Controller Register
  • Description: This register acts as a controller for software operation.
  • Offset: 0x40
表 706 PKC Software Controller Register
31:10
9
RCG_EN
Enable random clock gating.
  • 0x0: Disable
  • 0x1: Enable
8
DM_EN
Enable dummy multiplication.
  • 0x0: Disable
  • 0x1: Enable
7
Reserved bit
6:4
MODE
  • 0x0: Montgomery multiplication
  • 0x1: Mod inversion
  • 0x2: Mod addition
  • 0x3: Mod subtraction
  • 0x4: Mod comparison
  • 0x5: Mod shift
  • 0x6: Big integer multiplication
  • 0x7: Bit integer addition
3:1
START
Only used in software mode. MCU writes 0 to this bit and then writes 1 to this bit to start the PKC.
SW_CFG0
  • Name: PKC Software Configuration 0 Register
  • Description: This register acts as a configuration for PKC in software mode.
  • Offset: 0x44
  • Reset Value: 0x00080000
表 707 PKC Software Configuration 0 Register
31:25
24:16
MMB_POINT
0x8
Modular multiplication B point in sp_ram
15:9
8:0
MMA_POINT
Modular multiplication A point in sp_ram
SW_CFG1
  • Name: PKC Software Configuration 1 Register
  • Offset: 0x48
  • Reset Value: 0x00180010
表 708 PKC Software Configuration 1 Register
31:25
24:16
MMC_POINT
0x18
Modular multiplication C point in sp_ram
15:9
8:0
MMP_POINT
0x10
Modular multiplication P point in sp_ram
SW_CFG2
  • Name: PKC Software Configuration 2 Register
  • Offset: 0x4C
表 709 PKC Software Configuration 2 Register
31:25
24:16
MASB_POINT
0x28
Modular addition/subtraction B point in sp_ram
15:9
8:0
MASA_POINT
0x20
Modular addition/subtraction A point in sp_ram
SW_CFG3
  • Name: PKC Software Configuration 3 Register
  • Offset: 0x50
表 710 PKC Software Configuration 3 Register
31:25
24:16
MASC_POINT
0x38
Modular addition/subtraction C point in sp_ram
15:9
8:0
MASP_POINT
0x30
Modular addition/subtraction P point in sp_ram
SW_CFG4
  • Name: PKC Software Configuration 4 Register
  • Offset: 0x54
表 711 PKC Software Configuration 4 Register
31:25
24:16
MIV_POINT
0x48
Modular inversion V point in sp_ram
15:9
8:0
MIU_POINT
0x40
Modular inversion U point in sp_ram
SW_CFG5
  • Name: PKC Software Configuration 5 Register
  • Offset: 0x58
表 712 PKC Software Configuration 5 Register
31:25
24:16
MIX2_POINT
0x58
Modular inversion X2 point in sp_ram
15:9
8:0
MIT_POINT
0x50
Modular inversion X1 point in sp_ram
SW_CFG6
  • Name: PKC Software Configuration 6 Register
  • Offset: 0x5C
  • Reset Value: 0x00000060
表 713 PKC Software Configuration 6 Register
31:9
8:0
MITP
0x60
Modular inversion TEMP point in sp_ram
SW_CFG7
  • Name: PKC Software Configuration 7 Register
  • Offset: 0x60
  • Reset Value: 0x00000007
表 714 PKC Software Configuration 7 Register
31:6
5:0
LEN
0x7
Operator word length configuration in software mode:
  • 0x07: 256 bits
  • 0x08: 288 bits
  • 0x3F: 2048 bits
In hardware mode, this register is fixed to 0x07.
SW_CFG8
  • Name: PKC Software Configuration 8 Register
  • Offset: 0x64
表 715 PKC Software Configuration 8 Register
31:13
12:0
MIK_OUT
K out in modular inversion operation
SW_CFG9
  • Name: PKC Software Configuration 9 Register
  • Offset: 0x68
  • Reset Value: 0xAABBCCDD
表 716 PKC Software Configuration 9 Register
31:0
RDMS
0xAABBCCDD
Random dummy multiplication seed
SW_CFG10
  • Name: PKC Software Configuration 10 Register
  • Offset: 0x6C
表 717 PKC Software Configuration 10 Register
31:25
24:16
BMB_POINT
0x78
Big multiplication B point in sp_ram
15:9
8:0
BMA_POINT
0x70
Big multiplication A point in sp_ram
SW_CFG11
  • Name: PKC Software Configuration 11 Register
  • Offset: 0x70
表 718 PKC Software Configuration 11 Register
31:25
24:16
BAA_POINT
0x88
Big addition A point in sp_ram
15:9
8:0
BMC_POINT
0x80
Big multiplication C point in sp_ram
SW_CFG12
  • Name: PKC Software Configuration 12 Register
  • Offset: 0x74
表 719 PKC Software Configuration 12 Register
31:25
24:16
BAC_POINT
0x98
Big addition C point in sp_ram
15:9
8:0
BAB_POINT
0x90
Big addition B point in sp_ram
SW_CFG13
  • Name: PKC Software Configuration 13 Register
  • Offset: 0x78
  • Reset Value: 0x11223344
表 720 PKC Software Configuration 13 Register
31:0
RCG_SEED
0x11223344
Random clock gating seed
INT_STAT
  • Name: PKC Interrupt Status Register
  • Description: This is a read-only register used to indicate the interrupt status of PKC.
  • Offset: 0x80
表 721 PKC Interrupt Status Register
31:3
2
BIAO_INT_FLAG
WC
PKC big integer add overflow flag.
Write 1 to clear.
ERR_INT_EN
WC
PKC error interrupt flag.
Write 1 to clear.
CPLT_INT_FLAG
WC
PKC complete interrupt flag.
Write 1 to clear.
INT_EN
  • Name: PKC Interrupt Enable Register
  • Description: This register enables or disables all interrupts generated by the PKC.
  • Offset: 0x84
表 722 PKC Interrupt Enable Register
31:3
2
BIAO_INT_EN
PKC big integer add overflow interrupt enable
ERR_INT_EN
PKC error interrupt enable
CPLT_INT_EN
PKC complete interrupt enable
STAT
  • Name: PKC Status Register
  • Description: This is a read-only register used to indicate the status of PKC.
  • Offset: 0x88
表 723 PKC Status Register
31:1
BUSY
PKC busy status
