Channel_x_Registers
SARx
- Name: Source Address for Channel x
- Description: The starting source address is programmed by software before the DMA channel is enabled, or by an LLI update before the start of the DMA transfer. While the DMA transfer is in progress, this register is updated to reflect the source address of the current AHB transfer.
You must program the SAR address to be aligned to CTLx.SRC_TR_WIDTH.
- Base Address: 0x40013000
- Offset: 0x0 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:0 |
SRC_ADDR |
Current Source Address of DMA transfer. Updated after each source transfer. The SRC_ADDR_INC field in the CTRL_CHx register determines whether the address increments, decrements, or is left unchanged on every source transfer through the block transfer. Volatile: true |
DARx
- Name: Destination Address Register for Channel x
- Description: The starting destination address is programmed by software before the DMA channel is enabled, or by an LLI update before the start of the DMA transfer. While the DMA transfer is in progress, this register is updated to reflect the destination address of the current AHB transfer.
You must program the DAR to be aligned to CTLx.DST_TR_WIDTH.
- Offset: 0x8 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:0 |
DEST_ADDR |
Current Destination address of DMA transfer. Updated after each destination transfer. The DEST_ADDR_INC field in the CTRL_CHx register determines whether the address increments, decrements, or is left unchanged on every destination transfer throughout the block transfer. Volatile: true |
LLPx
- Name: Linked List Pointer Register for Channel x
- Description: The LLP
register has two functions:
- The logical result of the equation LLP.LOC !=0 is used to set up the type of DMA transfer: single or multi-block. If LLP.LOC is set to 0x0, transfers using linked lists are not enabled. This register must be programmed prior to enabling the channel in order to set up the transfer type.
- LLP.LOC != 0 contains the pointer to the next LLI for block chaining using linked lists. The LLPx register can also point to the address where write back of the control and source/destination status information occurs after block completion.
- Offset: 0x10 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:2 |
LOC |
Starting Address In Memory of next LLI if block chaining is enabled. Note that the two LSBs of the starting address are not stored because the address is assumed to be aligned to a 32-bit boundary. LLI accesses are always 32-bit accesses (Hsize = 2) aligned to 32-bit boundaries and cannot be changed or programmed to anything other than 32-bit. Volatile: true |
1:0 |
Reserved field |
CTLx
- Name: Control Register for Channel x
- Description: This register contains fields that control the DMA transfer. The CTLx register is part of the block descriptor (linked list item - LLI) when block chaining is enabled. It can be varied on a block-by-block basis within a DMA transfer when block chaining is enabled. If status write-back is enabled, the upper word of the control register, CTLx[63:32], is written to the control register location of the LLI in system memory at the end of the block transfer.
You need to program this register prior to enabling the channel.
- Offset: 0x18 + x*0x58
- Reset Value: 0x0000000200304801
63:45 |
Reserved field Volatile: true |
44 |
DONE |
Done bit. If status write-back is enabled, the upper word of the control register, CTRL_CHx[63:32], is written to the control register location of the LLI in system memory at the end of the block transfer with the done bit set. Software can poll the LLI CTRL_CHx.DONE bit to see when a block transfer completes. The LLI CTRL_CHx.DONE bit should be cleared when the linked lists are set up in memory prior to enabling the channel. LLI accesses are always 32-bit accesses (Hsize = 2) aligned to 32-bit boundaries and cannot be changed or programmed to anything other than 32-bit. Volatile: true |
43:32 |
BLOCK_XFE_SIZE |
0x2 |
Block Transfer Size. When the DMA is the flow controller, users write this field before the channel is enabled in order to indicate the block size. The number programmed into BLOCK_XFE_SIZE indicates the total number of single transactions to perform for every block transfer; a single transaction is mapped to a single AMBA beat. Width: The width of single transaction is determined by CTRL_CHx.SRC_XFE_WIDTH. Once the transfer starts, the read-back value is the total number of data items already read from the source peripheral, regardless of what the flow controller is. When the source or destination peripheral is assigned as the flow controller, the maximum block size that can be read back saturates at 0xFFF, but the actual block size can be greater. Volatile: true |
31:29 |
Rsvd_1_CTRL |
28 |
LLP_SRC_EN |
Block chaining is enabled on the source side only if the LLP_SRC_EN field is high and LLPx.LOC is non-zero. Value:
Volatile: true |
27 |
LLP_DST_EN |
Block chaining is enabled on the destination side only if LLP_DST_EN field is high and LLPx.LOC is non-zero. Value:
Volatile: true |
26:23 |
Rsvd |
22:20 |
XFE_TYPE_FC |
0x3 |
Transfer Type and Flow Control. Flow control can be assigned to the DMA, the source peripheral, or the destination peripheral. Value:
Volatile: true |
19 |
Rsvd_CTRL |
18 |
DST_SCATTER_EN |
Destination scatter enable. Scatter on the destination side is applicable only when the CTLx.DINC bit indicates an incrementing or decrementing address control. Value:
Volatile: true |
17 |
SRC_GATHER_EN |
Source gather enable. Gather on the source side is applicable only when the CTLx.DINC bit indicates an incrementing or decrementing address control. Value:
Volatile: true |
16:14 |
SRC_MSIZE |
0x1 |
Source burst transaction length. Number of data items, each of width CTRL_CHx.SRC_XFE_WIDTH, to be read from the source every time a burst transferred request is made from either the corresponding hardware or software handshaking interface. Note: This value is not related to the AHB bus master HBURST bus. Value:
Volatile: true |
13:11 |
DEST_MSIZE |
0x1 |
Destination burst transaction length. Number of data items, each of width CTRL_CHx.DEST_XFE_WIDTH, to be written to the destination every time a destination burst transaction request is made from either the corresponding hardware or software handshaking interface. Note: This value is not related to the AHB bus master HBURST bus. Value:
Volatile: true |
10:9 |
SRC_ADDR_INC |
Source address increment. Indicates whether to increment or decrement the source address on every source transfer. If the device is fetching data from a source peripheral FIFO with a fixed address, set this field to "No change". Value:
Volatile: true |
8:7 |
DEST_ADDR_INC |
Destination address increment. Indicates whether to increment or decrement the destination address on every destination transfer. If your device is writing data to a destination peripheral FIFO with a fixed address, set this field to "No Change". Value:
Volatile: true |
6:4 |
SRC_XFE_WIDTH |
Source Transfer Width. Mapped to AHB bus Hsize. For a non-memory peripheral, typically the peripheral (source) FIFO width. Value:
Volatile: true |
3:1 |
DEST_XFE_WIDTH |
Destination Transfer Width. Mapped to AHB bus Hsize. For a non-memory peripheral, typically the peripheral (destination) FIFO width. Value: • 0x0: Destination transfer width is 8 bits. • 0x1: Destination transfer width is 16 bits. • 0x2: Destination transfer width is 32 bits. Volatile: true |
0 |
INT_EN |
0x1 |
Interrupt Enable Bit. If set, all interrupt-generating sources are enabled. Functions as a global mask bit for all interrupts for the channel; raw interrupt registers still assert if CTRL_CHx.INT_EN = 0. Value:
Volatile: true |
SSTATx
- Name: Source Status Register for Channel x
- Description: After each block transfer completes, hardware can retrieve the source status information from the address pointed to by the contents of the SSTATARx register. This status information is then stored in the SSTATx register and written out to the SSTATx register location of the LLI before the start of the next block. For conditions under which the source status information is fetched, it can be varied on a block-by-block basis within a DMA transfer when block chaining is enabled. If status write-back is enabled, the upper word of the control register, CTLx[63:32], is written to the control register location of the LLI in system memory at the end of the block transfer.
This register is a temporary placeholder for the source status information on its way to the SSTATx register location of the LLI. The source status information should be retrieved by software from the SSTATx register location of the LLI, and not by a read of this register over the DMA controller slave interface.
- Offset: 0x20 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:0 |
SSTAT |
Source status information retrieved by hardware from the address pointed to by the contents of the STATARx register Volatile: true |
DSTATx
- Name: Destination Status Register for Channel x
- Description: After each block transfer completes, hardware can retrieve the destination status information from the address pointed to by the contents of the DSTATARx register. This status information is then stored in the DSTATx register and written out to the DSTATx register location of the LLI before the start of the next block.
This register is a temporary placeholder for the destination status information on its way to the DSTATx register location of the LLI. The destination status information should be retrieved by software from the DSTATx register location of the LLI, and not by a read of this register over the DMAC controller slave interface.
- Offset: 0x28 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:0 |
DSTAT |
Destination status information retrieved by hardware from the address pointed to by the contents of the DSTATARx register Volatile: true |
SSTATARx
- Name: Source Status Address Register for Channel x
- Description: After completion of each block transfer, hardware can retrieve the source status information from the user-defined address to which the contents of the SSTATARx register point. Users can select any location in system memory that would provide a 32-bit value to indicate the status of the source transfer.
- Offset: 0x30 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:0 |
SSTATAR |
Pointer from where hardware can fetch the source status information which is registered in the SSTATx register and written out to the SSTATx register location of the LLI before the start of the next block. |
DSTATARx
- Name: Destination Status Address Register for Channel x
- Description: After completion of each block transfer, hardware can retrieve the destination status information from the user-defined address to which the contents of the DSTATARx register point. Users can select any location in system memory that would provide a 32-bit value to indicate the status of the destination transfer.
- Offset: 0x38 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:0 |
DSTATAR |
Pointer from where hardware can fetch the destination status information which is registered in the DSTATx register and written out to the DSTATx register location of the LLI before the start of the next block. |
CFGx
- Name: Configuration Register for Channel x
- Description: This register contains fields that configure the DMA transfer. The channel configuration register remains fixed for all blocks of a multi-block transfer.
- Offset: 0x40 + x*0x58
- Reset Value: 0x0000000400000e00 + (x*0x20)
63:47 |
Reserved field |
46:43 |
DEST_PER |
Destination hardware interface. Assigns a hardware handshaking interface to the destination of channel x if the CFG_CHx.HSG_SEL_DEST field is 0; otherwise, this field is ignored. The channel can communicate with the destination peripheral connected to that interface through the assigned hardware handshaking interface. Note: For correct DMA operation, only one peripheral (source or destination) should be assigned to the same handshaking interface. |
42:39 |
SRC_PER |
Source hardware interface. Assigns a hardware handshaking interface to the source of channel x if the CFG_CHx.HSG_SEL_SRC field is 0; otherwise, this field is ignored. The channel can then communicate with the source peripheral connected to that interface through the assigned hardware handshaking interface. Note: For correct DMA operation, only one peripheral (source or destination) should be assigned to the same handshaking interface. |
38 |
SS_UPD_EN |
Source status update enable. Source status information is fetched only from the location pointed to by the SSTATARx register, stored in the SSTATx register and written out to the SSTATx location of the LLI, if SS_UPD_EN is high. Value:
37 |
DS_UPD_EN |
Destination status update enable. Destination status information is fetched only from the location pointed to by the DSTATARx register, stored in the DSTATx register and written out to the DSTATx location of the LLI, if DS_UPD_EN is high. Value:
36:34 |
PROT_CTRL |
Protection control bits used to drive the AHB HPROT[3:1] bus. The AMBA specification recommends that the default of HPROT indicate a non-cached, non-buffered, and privileged data access. The reset value is used to indicate such an access. HPROT[0] is tied high because all transfers are data accesses, as there are no opcode fetches. There is a one-to-one mapping of these register bits to the HPROT[3:1] master interface signals. Mapping of HPROT bus is as follows:
33 |
FIFO_MODE |
FIFO mode select. Determines how much space or data needs to be available in the FIFO before a burst transaction request is serviced. Value:
32 |
FLOW_CTRL_MODE |
Flow control mode. Determines when source transaction requests are serviced when the destination peripheral is the flow controller. Value:
31 |
RELOAD_DEST |
Automatic destination reload. The DARx register can be automatically reloaded from its initial value at the end of every block for multi-block transfers. A new block transfer is then initiated. Value:
30 |
RELOAD_SRC |
Automatic source reload. The SARx register can be automatically reloaded from its initial value at the end of every block for multi-block transfers. A new block transfer is then initiated. Value:
29:20 |
Rsvd_CFG |
Reserved field |
19 |
SRC_HSG_POL |
Source handshaking interface polarity. Value:
18 |
DEST_HSG_POL |
Destination handshaking interface polarity. Value:
17:12 |
Rsvd_CFG |
Reserved field |
11 |
HSG_SEL_SRC |
Selects software or hardware handshaking interface for source. This register selects which of the handshaking interfaces - hardware or software - is active for source requests on this channel. If the source peripheral is memory, this bit is ignored. Value:
10 |
HSG_SEL_DEST |
Selects a software or hardware handshaking interface for destination. This register selects which of the handshaking interfaces - hardware or software - is active for destination requests on this channel. If the destination peripheral is memory, this bit is ignored. Value:
9 |
FIFO_EMPTY |
Channel FIFO status. Indicates if there is data left in the channel FIFO. It can be used in conjunction with CFGx to cleanly disable a channel. Value:
8 |
CH_SUSP |
Channel suspend. Suspends all DMA data transfers from the source until this bit is cleared. There is no guarantee that the current transaction will complete. It can also be used in conjunction with CFGx to cleanly disable a channel without losing any data. Value:
7:5 |
CH_PRIOR |
Channel priority. A priority of 7 is the highest priority and 0 is the lowest. This field must be programmed within the range of 0 to 3. A programmed value beyond this range will cause erroneous behavior. Value:
4:0 |
Reserved field |
SGRx
- Name: Source Gather Register for Channel x
- Description: The
Source Gather Register contains two fields.
- Source gather count field (SGRx.SGC): Specifies the number of contiguous source transfers of CTLx.SRC_TR_WIDTH between successive gather intervals. This is defined as a gather boundary.
- Source gather interval field (SGRx.SGI): Specifies the source address increment/decrement in multiples of CTLx.SRC_TR_WIDTH on a gather boundary when gather mode is enabled for the source transfer.
- Offset: 0x48 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:20 |
SGC |
Source gather count. |
19:0 |
SGI |
Source gather interval. |
DSRx
- Name: Destination Scatter Register for Channel x
- Description: The Destination Status Register contains two fields.
- Destination scatter count field (DSRx.DSC): Specifies the number of contiguous destination transfers of CTLx.DST_TR_WIDTH between successive scatter boundaries.
- Destination scatter interval field (DSRx.DSI): Specifies the destination address increment/decrement in multiples of CTLx.DST_TR_WIDTH on a scatter boundary when scatter mode is enabled for the destination transfer.
- Offset: 0x50 + x*0x58
- Reset Value: 0x0
63:32 |
Reserved field |
31:20 |
DSC |
Destination scatter count. |
19:0 |
DSI |
Destination scatter interval. |
Interrupt_Registers
INT_RSTAT_TC
- Name: Raw Status for Transfer Complete Interrupt
- Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_TC[2] is the Channel 2 raw transfer complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_TC register.
Write access is available to this register or software for testing purposes only. Under normal operation, writes to this register are not recommended.
- Offset: 0x2c0
- Reset Value: 0x0
63:8 |
Rsvd_INT_RSTAT_TC |
Reserved field |
7:0 |
RAW |
Raw status for transfer complete interrupt Value:
INT_RSTAT_BTC
- Name: Raw Status for Block Transfer Complete Interrupt
- Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_BTC[2] is the Channel 2 raw block complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the CLR_BLK register.
- Offset: 0x2c8
- Reset Value: 0x0
63:8 |
RSVD_INT_RSTAT_BTC |
Reserved field |
7:0 |
RAW |
Raw Status for Block Transfer Complete Interrupt Value:
INT_RSTAT_STC
- Name: Raw Status for Source Transaction Complete Interrupt
- Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_STC[2] is the Channel 2 raw source transaction complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_STC register.
Write access is available to this register or software testing purposes only. Under normal operation, writes to this register are not recommended.
- Offset: 0x2D0
- Reset Value: 0x0
63:8 |
RSVD_INT_RSTAT_STC |
Reserved field |
7:0 |
RAW |
Raw status for source transaction complete interrupt Value:
INT_RSTAT_DTC
- Name: Raw Status for Destination Transaction Complete Interrupt
- Description: Interrupt events are stored in this Raw Interrupt Status register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_DTC[2] is the Channel 2 raw destination transaction complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_DTC register.
- Offset: 0x2d8
- Reset Value: 0x0
63:8 |
RSVD_INT_RSTAT_DTC |
Reserved field |
7:0 |
RAW |
Raw status for destination transaction complete interrupt Value:
INT_RSTAT_ERR
- Name: Raw Status for Error Interrupt
- Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_ERR[2] is the Channel 2 raw error interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_ERR register.
- Offset: 0x2E0
- Reset Value: 0x0
63:8 |
RSVD_INT_RSTAT_ERR |
Reserved field |
7:0 |
RAW |
Raw Status for Error Interrupt Value:
INT_STAT_TC
- Name: Status for Transfer Complete Interrupt
- Description: Channel DMA transfer complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_TC [2] is the Channel 2 source DMA transfer complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
- Offset: 0x2E8
- Reset Value: 0x0
63:8 |
RSVD_INT_STAT_TC |
Reserved field |
7:0 |
STAT |
Status for transfer complete interrupt Value:
INT_STAT_BTC
- Name: Status for Block Transfer Complete Interrupt
- Description: Channel block complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_BTC[2] is the Channel 2 block complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
- Offset: 0x2F0
- Reset Value: 0x0
63:8 |
RSVD_INT_STAT_BTC |
Reserved field |
7:0 |
STAT |
Status for block transfer complete interrupt Value:
INT_STAT_STC
- Name: Status for Source Transaction Complete Interrupt
- Description: Channel source transaction complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_STC[2] is the Channel 2 source transaction complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
- Offset: 0x2F8
- Reset Value: 0x0
63:8 |
RSVD_INT_STAT_STC |
Reserved field |
7:0 |
STAT |
Status for source transaction complete interrupt Value:
INT_STAT_DTC
- Name: Status for Destination Transaction Complete Interrupt
- Description: Channel destination transaction complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_DTC[2] is the Channel 2 status destination transaction complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
- Offset: 0x300
- Reset Value: 0x0
63:8 |
RSVD_INT_STAT_DTC |
Reserved field |
7:0 |
STAT |
Status for destination transaction complete interrupt Value:
INT_STAT_ERR
- Name: Status for Error Interrupt
- Description: Channel error interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_ERR[2] is the Channel 2 status error interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
- Offset: 0x308
- Reset Value: 0x0
63:8 |
RSVD_INT_STAT_ERR |
Reserved field |
7:0 |
STAT |
Status for error interrupt Value:
INT_MASK_TC
- Name: MASK for Transfer Complete Interrupt
- Description: The contents of the raw status register INT_RSTAT_TC are masked with the contents of the mask register INT_MASK_TC. This register has a bit allocated to each channel; for example, INT_MASK_TC[2] is the mask bit for the Channel 2 transfer complete interrupt. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_TC register writes a 1 into INT_MASK_TC[0], while INT_MASK_TC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_TC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
- Offset: 0x310
- Reset Value: 0x0
63:16 |
RSVD_INT_MASK_TC |
Reserved field |
15:8 |
INT_MASK_WE |
W |
Interrupt Mask Write Enable Value:
7:0 |
INT_MASK |
Mask for Transfer Complete Interrupt Value:
INT_MASK_BTC
- Name: Mask for Block Transfer Complete Interrupt
- Description: The contents of the raw status register INT_RSTAT_BTC are masked with the contents of the mask register INT_MASK_BTC. This register has a bit allocated to each channel; for example, INT_MASK_BTC[2] is the mask bit for the Channel 2 block complete interrupt. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_BTC register writes a 1 into INT_MASK_BTC[0], while INT_MASK_BTC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_BTC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
- Offset: 0x318
- Reset Value: 0x0
63:16 |
RSVD_INT_MASK_BTC |
Reserved field |
15:8 |
INT_MASK_WE |
W |
7:0 |
INT_MASK |
Mask for Block Transfer Complete Interrupt Value:
INT_MASK_STC
- Name: MASK for Source Transaction Complete Interrupt
- Description: The contents of the raw status register INT_RSTAT_STC are masked with the contents of the mask register INT_MASK_STC. This register has a bit allocated to each channel; for example, INT_MASK_STC[2] is the mask bit for the Channel 2 source transaction complete interrupt. When the source peripheral of DMA channel i is memory, then the source transaction complete interrupt, INT_MASK_STC[i], must be masked to prevent an erroneous triggering of an interrupt on the int_combined signal. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_STC register writes a 1 into INT_MASK_STC[0], while INT_MASK_STC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_STC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
- Offset: 0x320
- Reset Value: 0x0
63:16 |
RSVD_INT_MASK_STC |
Reserved field |
15:8 |
INT_MASK_WE |
W |
7:0 |
INT_MASK |
Mask for Source Transaction Complete Interrupt Value:
INT_MASK_DTC
- Name: Mask for Destination Transaction Complete Interrupt
- Description: The contents of the raw status register INT_RSTAT_DTC are masked with the contents of the mask register INT_MASK_DTC. This register has a bit allocated to each channel; for example, INT_MASK_DTC[2] is the mask bit for the Channel 2 destination transaction complete interrupt. When the destination peripheral of DMA channel i is memory, then the destination transaction complete interrupt, INT_MASK_DTC[i], must be masked to prevent an erroneous triggering of an interrupt on the int_combined(_n) signal. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_DTC register writes a 1 into INT_MASK_DTC[0], while INT_MASK_DTC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_DTC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
- Offset: 0x328
- Reset Value: 0x0
63:16 |
RSVD_INT_MASK_DTC |
Reserved field |
15:8 |
INT_MASK_WE |
W |
7:0 |
INT_MASK |
Mask for Destination Transaction Complete Interrupt Value:
INT_MASK_ERR
- Name: Mask for Error Interrupt
- Description: The contents of the raw status register INT_RSTAT_ERR are masked with the contents of the mask register INT_MASK_ERR. This register has a bit allocated to each channel; for example, INT_MASK_ERR[2] is the mask bit for the Channel 2 error interrupt. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_ERR register writes a 1 into INT_MASK_ERR[0], while INT_MASK_ERR[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_ERR[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the Status registers and int_port signals.
- Offset: 0x330
- Reset Value: 0x0
63:16 |
RSVD_INT_MASK_ERR |
Reserved field |
15:8 |
INT_MASK_WE |
W |
7:0 |
INT_MASK |
Mask for Error Interrupt Value:
INT_CLR_TC
- Name: Clear for Transfer Complete Interrupt
- Description: Each bit in the INT_RSTAT_TC and INT_STAT_TC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_TC[2] is the clear bit for the Channel 2 transfer done interrupt. Writing a 0 has no effect. This register is not readable.
- Offset: 0x338
- Reset Value: 0x0
63:8 |
RSVD_INT_CLR_TC |
W |
Reserved field |
7:0 |
CLR |
W |
Clear for Transfer Complete Interrupt Value:
INT_CLR_BTC
- Name: Clear for Block Transfer Complete Interrupt
- Description: Each bit in the INT_RSTAT_BTC and INT_STAT_BTC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_BTC[2] is the clear bit for the Channel 2 block done interrupt. Writing a 0 has no effect. This register is not readable.
- Offset: 0x340
- Reset Value: 0x0
63:8 |
RSVD_INT_CLR_BTC |
W |
Reserved field |
7:0 |
CLR |
W |
Clear for Block Transfer Complete Interrupt |
INT_CLR_STC
- Name: Clear for Source Transaction Complete Interrupt
- Description: Each bit in the INT_RSTAT_STC and INT_STAT_STC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_STC[2] is the clear bit for the Channel 2 source transaction done interrupt. Writing a 0 has no effect. This register is not readable.
- Offset: 0x348
- Reset Value: 0x0
63:8 |
RSVD_INT_CLR_STC |
W |
Reserved field |
7:0 |
CLR |
W |
Clear for Source Transaction Complete Interrupt Value:
INT_CLR_DTC
- Name: Clear for Destination Transaction Complete Interrupt
- Description: Each bit in the INT_RSTAT_DTC and INT_STAT_DTC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_DTC[2] is the clear bit for the Channel 2 destination transaction done interrupt. Writing a 0 has no effect. This register is not readable.
- Offset: 0x350
- Reset Value: 0x0
63:8 |
RSVD_INT_CLR_DTC |
W |
Reserved field |
7:0 |
CLR |
W |
Clear for Destination Transaction Complete Interrupt Value:
INT_CLR_ERR
- Name: Clear for Error Interrupt
- Description: Each bit in the INT_RSTAT_ERR and INT_STAT_ERR is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_ERR[2] is the clear bit for the Channel 2 error interrupt. Writing a 0 has no effect. This register is not readable.
- Offset: 0x358
- Reset Value: 0x0
63:8 |
RSVD_INT_CLR_ERR |
W |
Reserved field |
7:0 |
CLR |
W |
Clear for Error Interrupt Value:
INT_STAT_ET
- Name: Status for Each Interrupt Type
- Description: The contents of each of the five status registers INT_STAT_TC, INT_STAT_BTC, INT_STAT_STC, INT_STAT_DTC, and INT_STAT_ERR are ORed to produce a single bit for each interrupt type in the combined status register (INT_STAT_ET). This register is read-only.
- Offset: 0x360
- Reset Value: 0x0
63:5 |
RSVD_INT_STAT_ET |
Reserved field |
4 |
ERR |
OR of the contents of INT_STAT_ERR Value:
3 |
DEST_XFE_CPLT |
OR of the contents of INT_STAT_DTC Value:
2 |
SRC_XFE_CPLT |
OR of the contents of INT_STAT_STC Value:
1 |
BLK_XFE_CPLT |
OR of the contents of INT_STAT_BTC register Value:
0 |
XFE_CPLT |
OR of the contents of INT_STAT_TC register Value:
Software_Handshake_Registers
REQ_SST
- Name: Source Software Transaction Request Register
- Description: A bit is assigned for each channel in this register. REQ_SST[n] is ignored when software handshaking is not enabled for the source of channel n. A channel SRC_REQ bit is written only if the corresponding channel write enable bit in the SRC_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register. For example, writing hex 0101 writes a 1 into REQ_SST[0], while REQ_SST[7:1] remains unchanged. Writing hex 00xx leaves REQ_SST[7:0] unchanged. This allows software to set a bit in the REQ_SST register without performing a read-modified write operation.
- Offset: 0x368
- Reset Value: 0x0
63:16 |
Rsvd_1_REQ_SST |
Reserved field |
15:8 |
SRC_REQ_WE |
Source Software Transaction Request write enable Value:
7:0 |
SRC_REQ |
Source Software Transaction Request Value:
REQ_DST
- Name: Destination Software Transaction Request Register
- Description: A bit is assigned for each channel in this register. REQ_DST[n] is ignored when software handshaking is not enabled for the source of channel n. A channel DEST bit is written only if the corresponding channel write enable bit in the DEST_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
- Offset: 0x370
- Reset Value: 0x0
63:16 |
Rsvd_1_REQ_DST |
Reserved field |
15:8 |
DEST_REQ_WE |
Destination Software Transaction Request write enable Value:
7:0 |
DEST_REQ |
Destination Software Transaction Request Value:
REQ_SGL_ST
- Name: Source Single Transaction Request Register
- Description: A bit is assigned for each channel in this register. REQ_SGL_ST is ignored when software handshaking is not enabled for the source of channel n. A channel SRC_SGL_REQ bit is written only if the corresponding channel write enable bit in the SRC_SGL_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
- Offset: 0x378
- Reset Value: 0x0
63:16 |
Rsvd_1_REQ_SGL_ST |
Reserved field |
15:8 |
SRC_SGL_REQ_WE |
Source Single Transaction Request write enable Value:
7:0 |
SRC_SGL_REQ |
Source Single Transaction Request Value:
REQ_SGL_DT
- Name: Destination Single Transaction Request Register
- Description: A bit is assigned for each channel in this register. REQ_SGL_DT is ignored when software handshaking is not enabled for the destination of channel n. A channel DEST_SGL_REQ bit is written only if the corresponding channel write enable bit in the DST_SGL_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
- Base Address: 0x4A0013000
- Offset: 0x380
- Reset Value: 0x0
63:16 |
Rsvd_1_REQ_SGL_DT |
Reserved field |
11:8 |
DST_SGL_REQ_WE |
Destination Single Transaction Request write enable Value:
7:0 |
DEST_SGL_REQ |
Destination Single Transaction Request Value:
REQ_LST_ST
- Name: Source Last Transaction Request Register
- Description: A bit is assigned for each channel in this register. REQ_LST_ST is ignored when software handshaking is not enabled for the source of channel n, or when the source of channel n is not a flow controller. A channel LST_SRC bit is written only if the corresponding channel write enable bit in the LST_SRC_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
- Offset: 0x388
- Reset Value: 0x0
63:16 |
Rsvd_1_REQ_LST_ST |
Reserved field |
15:8 |
LST_SRC_WE |
Source Last Transaction Request write enable Value:
7:0 |
LST_SRC |
Source Last Transaction Request register Value:
REQ_LST_DT
- Name: Destination Last Transaction Request Register
- Description: A bit is assigned for each channel in this register. REQ_LST_DT is ignored when software handshaking is not enabled for the destination of channel n or when the destination of channel n is not a flow controller. A channel LST_DEST bit is written only if the corresponding channel write enable bit in the LST_DEST_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
- Offset: 0x390
- Reset Value: 0x0
63:16 |
Rsvd_1_REQ_LST_DT |
Reserved field |
15:8 |
LST_DEST_WE |
Destination Last Transaction Request write enable Value:
7:0 |
LST_DEST |
Destination Last Transaction Request Value:
Miscellaneous_Registers
CFG
- Name: DMA Configuration Register
- Description: This register is used to enable the DMA, which must be done before any channel activity. If the global channel enable bit is cleared while any channel is still active, CFG.DMA_EN still returns 1 to indicate that there are channels still active until hardware has terminated all activities on all channels, at which point the CFG.DMA_EN bit returns 0.
- Offset: 0x398
- Reset Value: 0x0
63:1 |
RSVD_CFG |
Reserved field |
0 |
DMA_EN |
DMA Enable bit. Value:
CH_EN
- Name: DMA Channel Enable Register
- Description: This is the DMA Channel Enable Register. If software needs to set up a new channel, it can read this register in order to find out which channels are currently inactive; it can then enable an inactive channel with the required priority. All bits of this register are cleared to 0 when the global DMA channel enable bit, CFG[0], is 0. When the global channel enable bit is 0, a write to the CH_EN register is ignored and a read will always read back 0. The channel enable bit, CH_EN.CH_EN, is written only if the corresponding channel write enable bit, CH_EN.CH_EN_WE, is asserted on the same AHB write transfer. For example, writing hex 01x1 writes a 1 into CH_EN[0], while CH_EN[7:1] remains unchanged. Writing hex 00xx leaves CH_EN[7:0] unchanged. Note that a read-modified write is not required.
- Offset: 0x3a0
- Reset Value: 0x0
63:16 |
Rsvd_1_CH_EN |
Reserved field |
15:8 |
CH_EN_WE |
W |
Channel enable register |
7:0 |
CH_EN |
Channel Enable. The CH_EN.CH_EN bit is automatically cleared by hardware to disable the channel after the last AMBA transfer of the DMA transfer to the destination has completed. Software can therefore poll this bit to determine when this channel is free for a new DMA transfer. Value:
