文档中心 > GR5526 Datasheet/ Peripherals/ I/O/ Always-On I/O Copy URL
Always-On I/O
A GR5526 SoC has eight individually configurable AON_GPIOs that can be applied by peripherals or digital input/output.
For all AON_GPIOs,
  • The I/O default state is input mode with pull-down.
  • Can be configured as being triggered by high level, low level, rising edge, falling edge, or both edges
  • Can work as wake-up sources from deep sleep.
  • Can generate slow-speed clocks.
  • Can work as digital GPIOs for input/output.
  • Can be multiplexed for different peripherals.
AON_PAD_CTRL0
  • Name: Always-on Pad Control Register
  • Description: This register contains the AON_GPIO configurations.
  • Base Address: 0x4000A000
  • Offset: 0x1E8
表 166 AON_PAD_CTRL_0 Register
31:16
15:8
AON_R_TYPE
Always-on PAD resistor type
  • 0x0: Pull down.
  • 0x1: Pull up.
7:0
AON_RE_N
Always-on PAD resister enable
  • 0x0: Enable AONx resistor.
  • 0x1: Disable AONx resistor.
AON_PAD_CTRL1
  • Description: This register contains the input and output data.
  • Offset: 0x1EC
  • Reset Value: 0x000000FF
表 167 AON_PAD_CTRL_1 Register
31:24
23:16
AON_INPUT_VAL
AON pad input value (valid when oe_n = 1)
  • 0x0: input AONx low.
  • 0x1: input AONx high.
15:8
AON_OUT_VAL
AON PAD output value (valid when oe_n = 0)
  • 0x0: Drive AONx low.
  • 0x1: Drive AONx high.
7:0
AON_O_N
0xFF
Always-on pad output enable (active low)
  • 0x0: Enable AONx output.
  • 0x1: Disable AONx output.
AON_PAD_CLK
  • Name: Always-on PAD output clock controls register
  • Description: This register controls inner clock output from AON_GPIO_4.
  • Offset: 0x1F0
表 168 AON_PAD_CLK Register
31:5
4:2
CLK_OUT_SEL
Clock out selection
  • 0x00: RNG_OSC (RNG Osc 32 kHz Clock)
  • 0x01: HFXO_32K (HFXO 32 kHz derived from HFXO_32 MHz Clock)
  • 0x02: LFRC_32K (LFRC 32 kHz Clock)[Z1]
  • 0x03: LFXO_32K (LF_XO 32 kHz Clock)
CLK_OUT_EN
Enable clock out via AON GPIO 4.
  • 0x0: Disable selected clock out via AON GPIO 4.
  • 0x1: Enable selected clock out via AON GPIO 4.
AON_PAD_MCU_OVR
  • Description: This register controls the MCU domain setting of always-on pads.
  • Offset: 0x1F4
表 169 AON_PAD_MCU_OVR Register
31:17
23:16
AON_PAD_MCU_OVR
Use the settings from MCU domain; only valid when MCU domain is ON
  • 0x0: Disable AONx digital setting.
  • 0x1: Enable AONx digital setting.
15:0
The electrical parameters for the AON_GPIO_0–AON_GPIO_7 are as follows:
表 170 GPIO electrical specifications
VIH
Input high voltage
VDDIO x 0.7
VDDIO
V
VIL
Input low voltage
VSSIO
VDDIO x 0.3
V
VOH,L
Output high voltage, 4 mA, VDDIO ≥ 1.7 V
VDDIO – 0.4
VDDIO
V
VOH,M
Output high voltage, 4 mA, VDDIO ≥ 2.5 V
VDDIO – 0.4
VDDIO
V
VOH,H
Output high voltage, 4 mA, VDDIO ≥ 3 V
VDDIO – 0.4
VDDIO
V
VOL,L
Output low voltage, 4 mA, VDDIO ≥ 1.7 V
VSS
VSS + 0.4
V
VOL,M
Output low voltage, 4 mA, VDDIO ≥ 2.5 V
VSS
VSS + 0.4
V
VOL,H
Output low voltage, 4 mA, VDDIO ≥ 3 V
VSS
VSS + 0.4
V
IOL,L
Current at VSS+0.4 V, output set low, VDDIO ≥1.7 V
4
mA
IOL,M
Current at VSS+0.4 V, output set low, VDDIO ≥ 2.5 V
5
mA
IOH,L
Current at VDD-0.4 V, output set high, VDDIO ≥ 1.7 V
4
mA
IOH,M
Current at VDD-0.4 V, output set high, VDD ≥ 2.5 V
5
mA
tRF,15pF
Rise/Fall time, 10%–90%, 15 pF load
5
8
ns
tRF,25pF
Rise/Fall time, 10%–90%, 25 pF load
6
13
ns
RPU
Pull-up resistance
70
120
150
kΩ
RPD
Pull-down resistance
70
120
150
kΩ
CPAD
Pad capacitance
5
pF
