文档中心 > GR5526 Datasheet/ MCU Core/ Interrupt Copy URL
Interrupt
In addition to supporting 16 system exceptions within the ARM® Cortex®-M4F, the GR5526 series also supports 66 external interrupts with 256 programmable priority levels. In some cases, a single peripheral may be able to generate multiple different interrupts (such as BOD/BLE). Most interrupts are connected directly to the NVIC, but all wakeup sources on the always-on domain are connected to the Power State Controller (PSC) outside of the ARM® Cortex®-M4F, allowing the interrupt sources to wake up the ARM® Cortex®-M4F core from the deep sleep mode. In most cases, developers do not need to change the interrupt source.
The Cortex®-M4F allows developers to assign various interrupts to different priority levels based on the application requirements. In order to maintain the stability of Bluetooth connection, it is recommended that the priority of Bluetooth interrupt should be configured to be the highest. In most cases, developers do not need to change priority levels, and the GR5526 SoCs have been configured with default priorities to meet most application requirements.
One additional feature of the Cortex®-M4F interrupt architecture is the ability to relocate the vector table to different addresses. The software can move the vector table into SRAM and reassign the interrupt service routine entry addresses on demand, but it should be noted that the remapping start address of the interrupt vector table should be aligned with 0x200. For example, the vector table base address should be set as 0x00000000, 0x00000200, or 0x00000400.
All non-programmable and programmable interrupts including those that can wake the MCU up from deep sleep mode are shown in 表 8 and 表 9. The width of interrupt priority control register is 8 bits, in which bit7 to bit4 are used for preemption priority and bit3 to bit0 are used for subpriority.
表 8 Non-programmable interrupts
No. Name Default Priority Waking up MCU Description
1 Reset_IRQ -3 Reset exception
2 NMI_IRQn -2 Non-maskable interrupt
3 HardFault_IRQ -1 All classes of fault. This interrupt occurs when the corresponding fault handler cannot be activated because it is currently disabled or masked by exception masking.
表 9 Programmable interrupts
No. Name Default Preemption Priority Default Subpriority Waking up MCU Description
4 MemManage_IRQ - - Memory management fault; caused by MPU violation or invalid accesses
5 BusFault_IRQ - - Error response received from the bus system
6 UsageFault_IRQ - - Usage fault; typical causes are invalid instructions or invalid state transition attempts.
7–10 Reserved - - Unused
11 SVCall_IRQ 0 0 Supervisor call via SVC instruction
12 DebugMonitor_IRQ - - Debug monitor – for software-based debugging
13 Reserved - - Unused
14 PendSV_IRQ 15 15 Pendable request for system service
15 SysTick_IRQ 15 15 System tick timer interrupt
16 Reserved - - Reserved
17 BLE_SDK_IRQ 15 15 BLE software development kit (SDK) schedule interrupt
18 BLE_IRQ 2 0 √ BLE interrupt
19 DMA0_IRQ 6 0 DMA0 interrupt
20 SPI_M_IRQ 8 0 SPI master interrupt
21 SPI_S_IRQ 8 0 SPI slave interrupt
22 EXT0_IRQ 8 0 GPIO_0 interrupt
23 EXT1_IRQ 8 0 GPIO_1 interrupt
24 TIMER0_IRQ 12 0 TIMER0 interrupt
25 TIMER1_IRQ 12 0 TIMER1 interrupt
26 DUAL_TIMER_IRQ 12 0 DUAL_TIMER interrupt
27 QSPI0_IRQ 8 0 QSPI0 interrupt
28 UART0_IRQ 10 0 UART0 interrupt
29 UART1_IRQ 10 0 UART1 interrupt
30 I2C0_IRQ 8 0 I2C0 interrupt
31 I2C1_IRQ 8 0 I2C1 interrupt
32 AES_IRQ 8 0 AES interrupt
33 HMAC_IRQ 8 0 HMAC interrupt
34 EXT2_IRQ 8 0 GPIO_2 interrupt
35 RNG_IRQ 8 0 TRNG interrupt
36 BOD_ASSERT_IRQ 8 0 Brown-out detect interrupt
37 PKC_IRQ 8 0 PKC interrupt
38 XQSPI_IRQ 8 0 XQSPI interrupt
39 QSPI1_IRQ 8 0 QSPI1 interrupt
40 OSPI_IRQ 8 0 OSPI interrupt
41 BLESLP_IRQ 2 0 √ BLE timer done interrupt
42 SLPTIMER_IRQ 12 0 √ Sleep timer done interrupt
43 AON_EXT_IRQ 8 0 √ AON GPIO interrupt
44 AON_WDT_IRQ 8 0 √ AON watch dog timer interrupt
45 I2S_M_IRQ 8 0 I2S master interrupt
46 I2S_S_IRQ 8 0 I2S slave interrupt
47 ISO7816_IRQ 8 0 SIM card interrupt
48 PRESENT_IRQ 8 0 Present done interrupt
49 RTC0_IRQ 8 0 √ Real-timer counter0 interrupt
50 COMM_CORE_IRQ 8 0 Communication core
51 DMA1_IRQ 6 0 DMA1 interrupt
52 DMA2_IRQ 6 0 DMA2 interrupt
53 DSPI_IRQ 8 0 DSPI interrupt
54 AON_IRQ 8 0 AON domain interrupt
55 PDM_IRQ 8 0 PDM interrupt
56 VTTBL_IRQ 8 0 VT table interrupt
57 CTE_FULL_IRQ 8 0 CTE full interrupt
58 USB_IRQ 8 0 USB interrupt
59 TSI_DC_IRQ 8 0 Display control interrupt
60 BOD_DEASSERT_IRQ 8 0 √ Brown out detect disappear interrupt
61 COMP_IRQ 8 0 √ Comparator interrupt
62 USB_ATTACH_IRQ 8 0 √ USB attach interrupt
63 USB_DETACH_IRQ 8 0 √ USB detach interrupt
64 RTC1_IRQ 8 0 √ Real-timer counter1 interrupt
65 CPLL_DRIFT_IRQ 8 0 CPLL drift interrupt
66 CLK_CALIB_IRQ 8 0 Clock calibration0/1 interrupt
67 TSI_GPU_IRQ 8 0 GPU interrupt
68 UART2_IRQ 10 0 UART2 interrupt
69 UART3_IRQ 10 0 UART3 interrupt
70 UART4_IRQ 10 0 UART4 interrupt
71 UART5_IRQ 10 0 UART5 interrupt
72 BLE_PWR_ON_IRQ 2 0 BLE sequencer power on done interrupt
73 BLE_PWR_DN_IRQ 8 0 BLE sequencer power off done interrupt
74 I2C2_IRQ 8 0 I2C2 interrupt
75 I2C3_IRQ 8 0 I2C3 interrupt
76 I2C4_IRQ 8 0 I2C4 interrupt
77 I2C5_IRQ 8 0 I2C5 interrupt
78 XO_BIAS_SW_CHG_IRQ 8 0 Crystal oscillator (XO) bias switch changed interrupt
79 AVS_ERR_IRQ 8 0 AVS control error interrupt
80 TSI_GPU_ERR_IRQ 8 0 GPU error interrupt
81 QSPI2_IRQ 8 0 QSPI2 interrupt
