DC-DC Converter
The DC-DC buck converter supplies power to all RF blocks, digital logic blocks, and memories.
| Parameter | Symbol | Min. | Typ. | Max. | Unit | Remarks |
Output Voltage |
VDCDC |
0.9 |
1.05 |
1.35 |
V |
Programmable |
Load Current |
ILOAD |
45 |
mA |
Startup Time |
TSTARTUP |
100 |
μs |
Voltage Ripples |
VRIPP |
10 |
mV |
Peak-to-peak ripple voltage |
Conversion Efficiency |
ηDCDC |
85% |
VBATL=3.3 V, ILOAD=10 mA |
Voltage Ripples is obtained based on Lext = 2.2 μH + 9.1 nH and Cext = 2.2 μF
RF_REG_4
- Address: 0xA000A814
- Reset Value: 0x0098877D
| 23 | EN_BLEED | RW | 0x1 | Enables Bleed Current to improve stability |
| 22 | LDO_BYPASS | RW | 0x0 | Enables Bypass mode. |
| 21 | CTRL_GATE_ON | RW | 0x0 |
| 20:16 | VREF_CTRL_4_0 | RW | 0x18 | The dcdc_vref value to PMU. |
