Cache
The GR5526 cache supports:
- 4-way set associative map mode with LFU replacement policy
- 8 KB cache memory (DataRAM) and 16 bytes per cache line
- Auto clock gating for power saving
- Profiling counters
GR5526 has an 8 KB cache memory that supports two map modes: direct map and 4-way set associative map with least frequently used (LFU) replacement policy. Both instruction and data access towards Flash memory or XIP code regions can be cached. The cache memory is enabled by default, but can be disabled by setting CACHE_DIS bit in XF_CTRL register. When cache is disabled, the number of Flash reading increases significantly, thus increasing power consumption and reducing the access speed.
The cache consists of TagRAM and DataRAM. The TagRAM is used to match addresses, and DataRAM is used to cache data. One cache line has 128 bits (16 bytes) DataRAM to cache data. In direct map mode, there are 512 cache lines; in 4-way set associative mode, one way has 128 cache lines.
The cache includes profiling counters. To measure the performance (hit-rate) of a code-section, the built-in profiling counters should be enabled. Before the beginning of the section, start the profiling counters by resetting CLR_HITMISS bit in XF_CTRL register. At the end of the section, the number of cache hits and cache misses for the section can be read from XF_HIT_COUNT and XF_MISS_COUNT registers, and users can stop the counters by setting CLR_HITMISS bit. The cache hit-rate can be calculated based on the formula: XF_HIT_COUNT/(XF_HIT_COUNT + XF_MISS_COUNT). The XF_HIT_COUNT and XF_MISS_COUNT registers do not wrap around after reaching the maximum value. If the maximum value is reached, consider profiling for a shorter duration to get correct numbers.
XF_CTRL
- Name: Cache Control Register
- Description: Cache Control Register
- Base address: 0x4000D000
- Offset: 0x00
- Reset value: 0x00000012
31:12 |
Reserved bits |
11 |
DIREC_MAP |
Enable direct map.
10 |
CLK_FORCE_EN_3 |
Cache_FSM and cache memory clock gating
9 |
CLK_FORCE_EN_2 |
APB clock gating control
8 |
CLK_FORCE_EN_1 |
Cache CLK_96 gating control
7 |
CLK_FORCE_EN_0 |
XQSPI and cache HCLK gating control
6 |
BUF_DIS |
Disable cache buffer preload.
5 |
DIS_SEQ_ACCESS |
Disable sequential cache access.
4 |
CLR_HITMISS |
0x1 |
Clear hit/miss counters.
3 |
CLR_FIFO |
Clear LFU FIFO.
2 |
Reserved bit |
1 |
TAG_MEM_FLUSH_EN |
0x1 |
Enable tag memory flush. Out of resetting tag memory will get flushed unless tag_ret is enabled (tag_ret signal lives in CPU register space).
0 |
CACHE_DIS |
0x1 |
Disable cache.
XF_HIT_COUNT
- Name: Cache Hit Count Register
- Description: Cache hit counter
- Base Address: 0x4000D000
- Offset: 0x08
31:0 |
CACHE_HIT_CNT |
RO |
Read cache hit count (If bit[4] of XF_CTRL is 0). |
XF_MISS_COUNT
- Name: Cache Miss Count Register
- Description: Cache miss counter
- Offset: 0x0C
31:0 |
CACHE_MISS_CNT |
RO |
Read cache miss count (If bit[4] of XF_CTRL is 0). |
XF_STAT
- Name: Cache Flush Status Register
- Description: Read cache flush status.
- Offset: 0x10
31:1 |
RO |
Reserved bits |
0 |
CACHE_STAT |
RO |
0x1: Tag flush busy 0x0: Tag flush not busy |
