True Random Number Generator (TRNG)
The True Random Number Generator (TRNG) generates random numbers used in encryption and decryption. Post-processing is added to the TRNG module to ensure the quality of random number and amend the bias of TRNG.
The goal of true random data generated by TRNG is to pass the NIST SP 800-22 standard test suite.
- Supports true and pseudo random number generation.
- Random number quality can pass the NIST SP 800-22 standard test suite.
- Supports multiple post-processing mechanisms, including bit-skipping, bit-counting, and von-Neumann.
- Supports multiple combinations of random numbers.
- Supports both interrupt and query modes.
Standard
| Document Code | Name of Standard |
NIST SP 800-22 |
A Statistical Test Suite for Random and Pseudorandom Number Generators for Cryptographic Applications |
Module Overview
The TRNG module supports pseudo random number generation and true random number generation. Pseudo random numbers are generated by a linear feedback shift register (LFSR). True random numbers are generated by using a feedforward ring oscillator (FRO) as the entropy source.
Digital_FRO is the digital true random number generator, based on the FRO scheme.
The work mode of the LFSR can be configured as 128 or 59 polynomial which is implemented by Galois structure. The LFSR seed can be configured from the FRO or in parallel be written in user-configured seed by using the user_seed register.
The TRNG module supports multiple output modes, including LFSR direct output, LFSR XOR TRNG, LFSR and TRNG cyclic sampling, LFSR and TRNG cyclic sampling and parity generation, and the FRO direct output. Since only the FRO is used as the true random number source, the results of LFSR direct output, LFSR XOR TRNG, as well as LFSR and TRNG cyclic sampling will be the same when the LFSR seed is configured by users.
The TRNG module supports multiple post-processing mechanisms, including bit-skipping, bit-counting, and von-Neumann.
Usage
The CFG register can be used to configure relevant parameters for the TRNG module. CFG.OUT_MODE can be used to configure the output mode. CFG.P_MODE_CFG can be used to configure the post-process mode. CFG.LFSR_MODE_CFG can be used to configure the 59-bit or 128-bit LFSR operation mode. CFG.LFSR_SEED_CFG can be used to configure the LFSR seed source. CFG.HW_INT_EN can set the TRNG module into interrupt mode.
The FRO acts as the entropy source, so that CFG.FRO_EN should be enabled in order to generate true random numbers. It can directly output or be set as the LFSR seed.
The TRNG module also supports user-defined LFSR seeds. In the 59-bit LFSR operation mode, the USER_SEED register needs to be written 4 consecutive times to configure the seed. In the 128-bit LFSR operation mode, the USER_SEED register needs to be written 8 consecutive times to configure the seed. If the output mode is set to LFSR directly output, the random number will be pseudo random number.
The TRNG module can be started by using the CTRL register. The STAT register is used to indicate the current status of the TRNG module. The generated random number can be read out from the DATA register.
CTRL
- Name: TRNG Controller Register
- Description: This register acts as a global enable/disable for TRNG.
- Base Address: 0x40017800
- Offset: 0x0
| Bits | Name | Access | Reset Value | Description |
31:1 |
Reserved bits |
0 |
RUN |
TRNG working enable signal, valid at HIGH
STAT
- Name: TRNG Status Register
- Description: This is a read-only register used to indicate the current status of TRNG.
- Offset: 0x4
31:1 |
Reserved bits |
0 |
READY |
R WC |
TRNG status flag bit, queried by CPU. Value:
This register is automatically cleared by hardware after READY is set HIGH. This register is automatically cleared by hardware after data reads. |
DATA
- Name: TRNG Data Register
- Description: This register is a 32-bit read buffer for the random numbers.
- Offset: 0x8
31:0 |
DATA |
TRNG data. This register is automatically cleared by hardware after data reads. |
MCULOCK
Not used in GR5526.
LONG_RUN_STAT
- Name: TRNG Long Run Status Register
- Description: This is a read-only register used to indicate the current status of long run mode.
- Offset: 0x10
31:9 |
Reserved bits |
8:1 |
LONG_RUN_COUNT |
Counts of TRNG long run test. This value is incremented by 1 for every long run detected by TRNG. After TRNG is disabled or reset, the register is cleared. |
0 |
LONG_RUN_FLAG |
Flag of TRNG long run test Value:
After TRNG is disabled or reset, this register is cleared. |
CFG
- Name: TRNG Configuration Register
- Description: This register acts as a configuration for TRNG.
- Offset: 0x14
- Reset Value: 0x0000B246
31:16 |
Reserved bits |
15 |
FRO_EN |
0x1 |
Ring oscillator TRNG enable signal Value:
14 |
LFS_EN |
Low frequency sampling TRNG enable signal Value:
Reserved in GR5526. |
13 |
HW_INT_EN |
0x1 |
TRNG hardware interrupt enable bit. Value:
12:10 |
LFSR_SEED_CFG |
0x4 |
LFSR seed configuration mode. Select a source for LFSR seed. Value:
Value is limited to 0x4 or 0x6 in GR5526. |
9 |
LFSR_MODE_CFG |
0x1 |
LFSR configuration mode:
8:7 |
P_MODE_CFG |
TRNG post-process configuration Value:
6:4 |
LFSR_XOR_SEL |
0x4 |
In output mode 8, select TRNG with LFSR XOR. 0x4: LFSR Note:
Value is limited to 0x4 in GR5526. |
3:0 |
OUT_MODE |
0x6 |
Select a TRNG output mode. Value:
Value is limited to 0x4, 0x6, 0x7, 0x8, or 0x9 in GR5526. |
SRC_CFG
- Name: TRNG Source Configuration Register
- Description: This register acts as a configuration for source of TRNG.
- Offset: 0x18
- Reset Value: 0x00007864
31:15 |
Reserved bits |
14:11 |
FRO_CHAIN_SEL |
0xF |
Selection of Chain4–Chain7 for FRO Value:
10:8 |
Reserved bits |
7:0 |
WAIT_TIME |
0x64 |
The waiting time during which the TRNG input reaches stable. Default value is 100 time cycles. |
FRO_CFG
- Name: TRNG FRO Configuration Register
- Description: This register acts as a configuration for FRO.
- Offset: 0x1C
- Reset Value: 0x0000FFFF
31:16 |
Reserved bits |
15:8 |
TEST_IN |
0xFF |
Test input signal of each chain for FRO. The default value is 1. |
7:0 |
CHAIN_EN |
0xFF |
Enable signal of each chain in ring oscillator module. It is valid when FROEN is high. |
USER_SEED
- Name: TRNG User Seed Register
- Description: This register acts as a user seed value for TRNG.
- Offset: 0x20
31:16 |
Reserved bits |
15:0 |
USER_SEED |
W |
RNG seed configured by users. Write four times to user_seed[58:0] to configure a 59-bit random number. Write eight times to user_seed[127:0] to configure a 128-bit random number. |
LONG_RUN_CFG
- Name: TRNG Long Run Configuration Register
- Description: This register acts as a configuration for long run mode.
- Offset: 0x24
- Reset Value: 0x00000035
31:6 |
Reserved bits |
5:1 |
LONG_RUN_THD |
0x1A |
Threshold configuration of RNG long run test. The run which lasts in a longer or an equal period than this value will be detected. Default value is 26 and the maximum value is 31. |
0 |
THD_LR_TEST |
0x1 |
RNG long run test enable bit Value:
Ring Oscillator s0
