Dual Timer
The Dual Timer module consists of two programmable down counters (32-bit or 16-bit) that can generate interrupts when they reach 0. Since the Dual-Timer is in the MCU Subsystem domain, Dual-Timer interrupt is not available during sleep, and the running Dual-Timer will not prevent the MCU from sleeping. If the RELOAD register is configured with a value, the Dual-Timer immediately counts down from the RELOAD value; if the BG_LOAD register is configured with a value, the Dual-Timer starts counting down again with the BG_LOAD value after the current counting cycle is completed. If BG_LOAD value is set before Dual-Timer is initialized, the BG_LOAD value will be invalid after the Dual-Timer is initialized with RELOAD value.
  • A 32-bit or 16-bit counter
  • One of the following timer modes:
    • Periodic
    • One-shot
    • Free-running
  • The clock source of the Dual Timer follows the system clock
  • Dual Timer has a prescaler that can divide down the enabled timer clock rate by 1, 16, or 256.
  • Dual Timer pauses when the MCU is suspended.
In Dual Timer, both of the counters are defined by default. For each counter, the following operational modes are available:
  • Free-running mode
    The counter wraps after reaching zero, and continues to count down from the maximum value (0xFFFFFFFF). This is the default mode.
  • Periodic mode
    The counter generates an interrupt at a fixed interval, reloading the original value after wrapping past zeros.
  • One-shot mode
    The counter generates an interrupt once. When the counter reaches 0, it halts until you reprogram it.
    When the value of the RELOAD register is configured to 0, no count and no interrupt are generated.
The RELOAD value only represents the count-down number of timers. If you want to configure a specific duration (for example, µs, ms, or s), you need to use the following formula:
Expect_time (s) = RELOAD/(SystemCoreClock/PRE−1)
where PRE stands for prescaled coefficient.
RELOAD
  • Name: Dual Timer Reload Register
  • Description: This register contains the value from which the counter is to decrease. The count is immediately restarted from the new RELOAD value.
  • Base Address: 0x40002000
  • Offset: 0x00 + x*0x20
  • Reset Value: 0x00
*x is used to identify the counter of the Dual Timer Module. The “x” can be 0 or 1.
表 179 RELOAD Register
31:0
RELOAD_VALUE
Reload value. Write to this register sets the current value.
VAL
  • Name: Dual Timer Current Value Register
  • Description: This register provides the current count value of the decrementing counter.
  • Offset: 0x04 + x*0x20
  • Reset Value: 0xFFFFFFFF
表 180 VAL Register
31:0
CUR_VALUE
RO
0xFFFFFFFF
Current count value
CTRL
  • Name: Dual Timer Control Register
  • Description: This register enables the software to control the Dual Timer.
  • Offset: 0x08 + x*0x20
  • Reset Value: 0x20
表 181 CTRL Register
31:8
7
EN
Timer enable
  • 0x0: Timer disabled; default
  • 0x1: Timer enabled
6
MODE
Timer mode
  • 0x0: Timer is in free-running mode; default
  • 0x1: Timer is in periodic mode
5
INT_EN
0x1
Interrupt enable
  • 0x0: Timer interrupt disabled
  • 0x1: Timer interrupt enabled; default
4
3:2
PRE
Prescale bits
  • 0x00: 0 stage of prescale, clock is divided by 1; default
  • 0x01: 4 stages of prescale, clock is divided by 16
  • 0x10: 8 stages of prescale, clock is divided by 256
  • 0x11: Undefined. Do not use this value.
SIZE
Select 16-bit or 32-bit counter operation:
  • 0x0: 16-bit counter; default
  • 0x1: 32-bit counter
COUNT_MODE
Select wrap mode or one-shot mode:
  • 0x0: Wrap mode; default
  • 0x1: One-shot mode
INT_CLR
  • Name: Dual Timer Interrupt Clear Register
  • Description: Any write to the INT_CLR register clears the interrupt output from the counter.
  • Offset: 0x0C + x*0x20
  • Reset Value: 0x00
表 182 INT_CLR Register
31:0
STAT
WO
Clear the Dual-Timer interrupt event.
RAW_INT_STAT
  • Name: Dual Timer Raw Interrupt Status Register
  • Description: The RAW_INT_STAT register indicates the raw interrupt status from the counter.
  • Offset: 0x10 + x*0x20
  • Reset Value: 0x00
表 183 RAW_INT_STAT Register
31:1
STAT
RO
Raw interrupt status from the counter
INT_STAT
  • Name: Dual-Timer interrupt enable status register
  • Description: The INT_STAT register indicates the masked interrupt status from the counter.
  • Offset: 0x14 + x*0x20
  • Reset Value: 0x00
表 184 INT_STAT Register
31:1
STAT
RO
Enable interrupt status from the counter.
BG_LOAD
  • Name: Dual-Timer background reload register
  • Description: When the BG_LOAD value is set, the counter will count down again from the BG_LOAD value after completing the current counting cycle.
  • Offset: 0x18 + x*0x20
  • Reset Value: 0x00
表 185 BG_LOAD Register
31:0
BG_LOAD_VALUE
The BG_LOAD does not cause the counter to immediately restart from the new value.
