文档中心 > GR5526 Datasheet/ Peripherals/ I/O/ Mixed Signal I/O Copy URL
Mixed Signal I/O
A GR5526 SoC has eight individually configurable MSIOs that can be applied by peripherals, digital input\output or analog input.
  • MSIO default state is analog input mode.
  • As analog input for sense ADC or Comparator.
  • As digital MSIOs for input/output, no interrupt.
  • To multiplex some different peripherals.
  • For digital modules with high timing requirements, it is recommended to increase the MSIO drive current.
MSIO_A_PAD_CFG0
  • Name: MSIOA Pad Control Register
  • Description: This register contains the input and output data.
  • Base Address: 0x 4000A1D8
  • Offset: 0x00
表 171 MSIO_A_PAD_CFG0 Register
31:24
23:16
MSIO_A_VAL
MSIOA digital value
15:8
MSIO_A_OE_N
0xFF
MSIOA output enable (active low)
  • 0x0: Enable MSIOA_x output.
  • 0x1: Disable MSIOA_x output.
7:0
MSIO_A_OUT
MSIOA output value (valid in output mode)
MSIO_A_PAD_CFG1
  • Description: This register contains the MSIOA configurations.
  • Base Address: 0x 4000A1DC
  • Offset: 0x00
  • Reset Value: 0x00FF0000
表 172 MSIO_A_PAD_CFG1 Register
31:24
MSIO_A_IE_N
MSIOA input enable (active low)
  • 0x0: Enable input.
  • 0x1: Disable input.
23:16
MSIO_A_RE_N
0xFF
MSIOA resistor enable (active low)
  • 0x0: Enable resistor.
  • 0x1: Disable resistor.
15:8
MSIO_A_RTYPE
MSIOA resistor type
  • 0x0: Pull down.
  • 0x1: Pull up.
7:0
MSIO_A_AE_N
Analog enable control for MSIOA pad
  • 0x0: analog mode
  • 0x1: digital mode
MSIO_A_PAD_MCU_OVR
  • Name: MSIOA Using MCU Domain Setting Control Register
  • Description: This register controls MSIOA using the settings from the MCU domain.
  • Base Address: 0x4000A1E0
  • Offset: 0x0
表 173 MSIO_A_PAD_MCU_OVR Register
31:8
N/A
7:0
msio_a_mcu_ovr
Use the settings from MCU domain, only valid when MCU domain is ON
  • 0x0: Use settings in MSIO_A_PAD_CFG as GPIO.
  • 0x1: Use PAD MUX settings in MCU.
The electrical parameters for the MSIO_A0–MSIO_A7 are as follows:
表 174 GPIO electrical specifications
VIH
Input high voltage
VDDIO x 0.7
VDDIO
V
VIL
Input low voltage
VSSIO
VDDIO x 0.3
V
VOH,L
Output high voltage, 2.5 mA, VDDIO ≥ 1.7 V
VDDIO – 0.4
VDDIO
V
VOH,M
Output high voltage, 2.5 mA, VDDIO ≥ 2.5 V
VDDIO – 0.4
VDDIO
V
VOH,H
Output high voltage, 2.5 mA, VDDIO ≥ 3 V
VDDIO – 0.4
VDDIO
V
VOL,L
Output low voltage, 2.5 mA, VDDIO ≥ 1.7 V
VSS
VSS + 0.4
V
VOL,M
Output low voltage, 2.5 mA, VDDIO ≥ 2.5 V
VSS
VSS + 0.4
V
VOL,H
Output low voltage, 2.5 mA, VDDIO ≥ 3 V
VSS
VSS + 0.4
V
IOL,L
Current at VSS+0.4 V, output set low, VDDIO ≥1.7 V
2.5
mA
IOL,M
Current at VSS+0.4 V, output set low, VDDIO ≥ 2.5 V
2.5
mA
IOH,L
Current at VDD-0.4 V, output set high, VDDIO ≥ 1.7 V
2.5
mA
IOH,M
Current at VDD-0.4 V, output set high, VDDIO ≥ 2.5 V
2.5
mA
tRF,15pF
Rise/Fall time, 10%–90%, 15 pF load
5
8
ns
tRF,25pF
Rise/Fall time, 10%–90%, 25 pF load
6
13
ns
RPU
Pull-up resistance
70
120
150
kΩ
RPD
Pull-down resistance
70
120
150
kΩ
CPAD
Pad capacitance
5
pF
