文档中心 > GR5526 Datasheet/ PMU/ BOD/ Registers Copy URL
BOD_REG1
  • Address: 0xA000A810
  • Reset Value: 0x00000061
表 48 BOD_REG1 Register
7
NC_0
Not connected
6
BOD_MODE_SEL
0x1
  • 0x1: Enable static mode.
  • 0x0: Enable dynamic mode.
In dynamic mode, the BOD will operate at a certain clock period, with lower power but lower accuracy.
5:2
BOD_INT_LV_SEL
0x8
BOD Interrupt threshold setting; deviation: ±100 mv (depending on temperature and process)
  • 0x9: Set threshold to 2.4 V.
  • 0xA: Set threshold to 2.5 V.
  • 0xB: Set threshold to 2.6 V.
  • 0xC: Set threshold to 2.7 V.
  • 0xD: Set threshold to 2.8 V.
  • 0xE: Set threshold to 2.9 V.
  • 0xF: Set threshold to 3.0 V.
BOD_INT_EN
  • 0x1: Enable BOD interrupt.
  • 0x0: Disable BOD interrupt.
BOD_RESET_EN
0x1
  • 0x1: Enable BOD reset.
  • 0x0: Disable BOD reset.
