Timer
The GR5526 SoC has two instances of Timer module that is a 32-bit general-purpose timer. Since the Timer is in the MCU Subsystem domain, Timer interrupt is not available during sleep, and the running Timer will not prevent MCU from sleeping. In active mode, when Timer is started again after stopping, it will continue to count down from the stop time. The value of RELOAD register will not take effect until the end of the current cycle.
- Generate an interrupt when the 32-bit down counter reaches 0.
- The clock source of the Timer follows the system clock.
- Each timer module has an independent interrupt entry.
- Timer pauses when MCU is suspended.
- The Timer can generate an interrupt request signal when the 32-bit down counter reaches 0. The interrupt request is held until it is cleared by writing 1 to the INT_STAT register.
- If the Timer count reaches 0 and, at the same time, the software clears a previous interrupt status, the interrupt status is set to 1.
- When the value of the RELOAD register is configured to 0, no count and no interrupt are generated.
- The RELOAD
value only represents the count-down number of timers. If you want to configure a specific
duration (for example, µs, ms, or s), you need to use the following formula:
- If you need to start counting from the new RELOAD value immediately, you need to deinitialize the Timer first, and then initialize the Timer.
CTRL
- Name: Timer Control Register
- Description: The CTRL register enables the software to control the Timer.
- Base Address: 0x40000000 + x*0x1000
- Offset: 0x00
- Reset Value: 0x00
*x is used to identify the Timer Module. The “x” can be 0 or 1.
31:4 |
Reserved bits |
3 |
INT_EN |
Timer interrupt enable Value:
2:1 |
Reserved bits |
0 |
EN |
Timer enable. Value:
VAL
- Name: Timer Value Register
- Description: The VAL register indicates the current value of the decrementing counter.
- Offset: 0x04
- Reset Value: 0x01
31:0 |
CUR_VALUE |
0x1 |
Current value |
RELOAD
- Name: Timer Reload Register
- Description: When this register is written to, the count value takes effect at the end of the current cycle.
- Offset: 0x08
- Reset Value: 0x00
31:0 |
RELOAD_VALUE |
Sets reload value. |
INT_STAT
- Name: Timer Interrupt Status Register
- Description: The INT_STAT register indicates the interrupt status from the counter. Writing one to the INT_STAT register clears the timer interrupt.
- Offset: 0x0C
31:1 |
Reserved bits |
0 |
STAT |
Timer interrupt. Write 1 to clear. |
