Sleep
| IUDS,RAMOFF,BODOFF,FLASHOFF,RESET | Ultra Deep Sleep, no RAM retention, BOD disabled, Flash powered off, woken up on reset | 2.38 | μA | ||
| IUDS,RAMOFF,BODOFF,FLASHOFF,AON_GPIO | Ultra Deep Sleep, no RAM retention, BOD disabled, Flash powered off, woken up on AON GPIO | 2.38 | μA | ||
| IUDS,RAMOFF,BODOFF,FLASHOFF,SLP_TIMER | Ultra Deep Sleep, no RAM retention, BOD disabled, Flash powered off, woken up on Sleep Timer | 2.39 | μA | ||
| IUDS,RAMOFF,BODOFF,FLASHOFF,SLP_TIMER_LFRC | Ultra Deep Sleep, no RAM retention, BOD disabled, Flash powered off, woken up on Sleep Timer (running from LFXO_32K clock) | 2.5 | μA | ||
| IDP,RAMOFF,ANY | Deep Sleep, no RAM retention, woken up on any source | 2.5 | μA | ||
| IDP,RAMON,ANY | Deep Sleep, full 512 KB RAM retention, woken up on any source | 4.3 | μA | ||
| IDP,RAMON,BLE | Deep Sleep, full 512 KB RAM retention, woken up on Bluetooth LE controller | 4.2 | μA | ||
| IDP,RAMON,BLE_LFRC | Deep Sleep, full 512 KB RAM retention, woken up on Bluetooth LE controller (running from LFXO_32K clock) | 4.4 | μA | ||
| IDP,128RAMON,BLE | Deep Sleep, full 128 KB RAM retention, woken up on Bluetooth LE controller | 3.3 | μA | ||
| IDP,RAMON,SLP_TIMER | Deep Sleep, full 512 KB RAM retention, woken up on Sleep Timer | 4.2 | μA | ||
| IDP,RAMON,COMP | Deep Sleep, full 512 KB RAM retention, woken up on LPCOMP | 4.2 | μA | ||
| IDP,RAMON,SLP_TIMER_LFXO | Deep Sleep, full 512 KB RAM retention, woken up on Sleep Timer (running from LFXO_32K clock) | 4.4 | μA | ||
| IDP,RAMON,RTC | Deep Sleep, full 512 KB RAM retention, woken up on RTC | 4.4 | μA |
CPU Running
| ICOREMARK,FLASH | CPU running CoreMark from Flash | 4.9 | mA | ||
| ICOREMARK,FLASH,HFXO96M | CPU running CoreMark from Flash, System Clock = HFXO@96 MHz | 5.1 | mA | ||
| ICOREMARK,FLASH,HFRC16M | CPU running CoreMark from Flash, System Clock = HFRC@16 MHz | 1.8 | mA | ||
| ICOREMARK,FLASH,SEC | CPU running CoreMark from Flash, Enable security mode | 5.0 | mA | ||
| ICOREMARK,RAM | CPU running CoreMark from RAM | 4.4 | mA | ||
| ICOREMARK,RAM_ALIAS | CPU running CoreMark from RAM Alias | 4.9 | mA | ||
| ICOREMARK,RAM_ALIAS,HFRC16M | CPU running CoreMark from RAM Alias, System Clock = HFRC@16 MHz | 1.8 | |||
| ILOOP,FLASH | CPU running while loop from Flash | 4.5 | mA | ||
| ILOOP,FLASH,SEC | CPU running while loop from Flash, Enable security mode | 4.6 | mA | ||
| ILOOP,RAM_ALIAS | CPU running while loop from RAM Alias | 4.7 | mA | ||
| ILOOP,RAM_ALIAS,HFRC16M | CPU running while loop from RAM Alias, System Clock = HFRC@16 MHz | 1.7 | mA | ||
| IIDLE,FLASH | CPU idle from Flash | 2.4 | mA | ||
| IIDLE,FLASH,SEC | CPU idle from Flash, Enable security mode | 2.4 | mA | ||
| IIDLE,RAM_ALIAS | CPU idle from RAM Alias | 2.3 | mA |
Radio Transmitting/Receiving
| ITRANSMIT,0dBm,1Mbps,HFXO96M | Radio transmitting @0 dBm output power, 1 Mbps Bluetooth LE, System Clock = HFXO@96 MHz | 4.0 | mA | ||
| ITRANSMIT,7dBm,1Mbps,HFXO96M | Radio transmitting @7 dBm output power, 1 Mbps Bluetooth LE, System Clock = HFXO@96 MHz | 7.7 | mA | ||
| ITRANSMIT,-20dBm,1Mbps,HFXO96M | Radio transmitting @-20 dBm output power, 1 Mbps Bluetooth LE, System Clock = HFXO@96 MHz | 2.2 | mA | ||
| ITRANSMIT,0dBm,1Mbps,HFXO16M | Radio transmitting @0 dBm output power, 1 Mbps Bluetooth LE, System Clock = HFXO@16 MHz | 3.7 | mA | ||
| IRECEIVE,1Mbps,HFXO96M | Radio receiving @ 1 Mbps Bluetooth LE mode, System Clock = HFXO@96 MHz | 3.5 | mA | ||
| IRECEIVE,1Mbps,HFXO16M | Radio receiving @ 1 Mbps Bluetooth LE mode, System Clock = HFXO@16 MHz | 3.4 | mA |
PSRAM
| IRUNNING | Read/Write @48 MHz | 7 | mA | ||
| IFULL,STANDBY | Full array refresh standby current, slow refresh, without CLK toggling | 66 | μA | ||
| I1/2,STANDBY | 1/2 array refresh standby current, slow refresh, without CLK toggling | 65 | μA | ||
| I1/4,STANDBY | 1/4 array refresh standby current, slow refresh, without CLK toggling | 64 | μA | ||
| I1/8,STANDBY | 1/8 array refresh standby current, slow refresh, without CLK toggling | 60 | μA | ||
| IFULL,HS | Full array refresh half sleep current, slow refresh, without CLK toggling | 20 | μA | ||
| I1/2,HS | 1/2 array refresh half sleep current, slow refresh, without CLK toggling | 14 | μA | ||
| I1/4,HS | 1/4 array refresh half sleep current, slow refresh, without CLK toggling | 11 | μA | ||
| I1/8,HS | 1/8 array refresh half sleep current, slow refresh, without CLK toggling | 10 | μA | ||
| IDPD | Reset values and memory content are not retained in Deep Power Down mode. | 7 | μA |
USB
| IRAMON,RUNNING,USB_ACTIVE | Full 512 KB RAM retention, CPU running, USB active | mA | |||
| IRAMON,SLEEPING,USB_SUSPEND | Full 512 KB RAM retention, CPU sleeping, USB suspended | μA |
ADC Active
| IADC,4KHz,128_POINTS | CPU running, ADC sampling@4 kHz sample clock, acquire 128 points | mA | |||
| IADC,16KHz,128_POINTS | CPU running, ADC sampling@16 kHz sample clock, acquire 128 points | mA | |||
| IADC,1MHz,128_POINTS | CPU running, ADC sampling@1 MHz sample clock, acquire 128 points | mA | |||
| IADC,16MHz,128_POINTS | CPU running, ADC sampling@16 MHz sample clock, acquire 128 points | mA |
TEMP Measure Active
ITEMP |
TEMP measurement started |
mA |
VBATL Measure Active
IVBATL |
VBATL measurement started |
mA |
COMP Active
ICOMP |
COMP started |
μA |
BOD Active
IBOD |
BOD running |
0.4 | μA |
TRNG Active
ITRNG |
TRNG running |
μA |
Security Active
IPRESENT128 |
Present-128 running in encryption mode |
μA |
IAES |
AES running |
μA |
IPKC |
PKC running |
μA |
IHMAC |
HMAC running |
μA |
