文档中心 > GR5526 Datasheet/ Peripherals/ Security Interfaces/ Hash-based Message Authentication Code (HMAC) Copy URL
Hash-based Message Authentication Code (HMAC) is a mechanism for message authentication by using hash functions in cryptography. The message authentication provided by HMAC includes two aspects:
  • Message integrity authentication: This can prove that the message has not been modified during transmission.
  • Source identity authentication: Because both sides of the communication share the authentication key, receiver can verify that the source sending the data is consistent with the claim so that the receiver can reliably confirm that the received message is consistent with the sent message.
  • Compatible with SHA-256
  • Supports custom initial hash values.
  • Supports querying registers and interrupts to report status.
  • Supports MCU mode and DMA mode.
Standard
表 662 HMAC module standard
FIPS PUB 180-4
Secure Hash Standard (SHS) (Compliant with SHA-256)
FIPS PUB 198-1
Keyed-Hash Message Authentication Code (HMAC)
Module Overview
The HMAC co-processor authenticates data, using an algorithm and implementation fully compliant with the Keyed-Hash Message Authentication Code defined in Federal Information Processing Standards (FIPS) Publication 198. GR5526 embeds the HMAC module in order to realize hardware acceleration of calculation.
图 136 HMAC module in the system
Multiple modes are supported (SHA256, HMAC-SHA256) for a key size of 256 bits.
Information preprocessing is required for input data, including additional padding bits and additional length value.
The HMAC co-processor adopts both 32-bit AHB and APB interfaces. It supports DMA transfers for incoming and outgoing data (through a dedicated integrated DMA).
Usage
The CFG register can be used to configure relevant parameters for the HMAC module. CFG.CALC_TYPE can be used to configure the working mode including SHA-256 and HMAC. If the working mode is set to HMAC, the mode of fetching the key should be configured through CFG.KEY_TYPE.
If the key is configured by MCU, the KEY0 to KEY7 registers need to be configured. If the key is fetched through AHB, the KEY_ADDR register should be configured.
The SER_HASH0 to USER_HASH7 registers are used to customize the initial HASH values if the CFG register enables users to define the initial HASH.
If the HMAC module is in interrupt or DMA operation mode, the INT register needs to be configured.
In DMA operation mode, the XFER_SIZE, RD_START_ADDR, and WR_START_ADDR registers should be configured. If misalignment is required when MCU reads or writes data, the last two bits of the RD_START_ADDR and the WR_START_ADDR registers can be configured.
The HMAC module can be started through the CTRL register. CTRL.KEY_EN is configured in order to enable the HMAC module to fetch the key through AHB master interface.
In MCU operation mode, a block data (512-bit) is continuously written into the DATA_IN register. In DMA operation mode, the HMAC module will read the data from the address which is stored in the RD_START_ADDR register.
The STAT register or interrupt callback function can judge whether the calculation completes. Before writing next block data into the DATA_IN register, the INT register needs to be cleared.
In MCU operation mode, the result of the SHA-256 or HMAC can be obtained by repeatedly reading the DATA_OUT register until getting 256-bit data. In DMA operation mode, the result has been sent to the address which is stored in the WR_START_ADDR register.
CTRL
  • Name: HMAC Controller Register
  • Description: This register acts as a global enable/disable for HMAC.
  • Base Address: 0x40015800
  • Offset: 0x0
表 663 HMAC Controller Register
31:4
3
LST_TX
W
Last block in MCU mode or last DMA transfer. This signal may be cleared by itself when hmac_ready was set.
2
KEY_EN
W
Enable HMAC fetch key by itself through AHB master interface or key port. This signal may be cleared by itself when hmac_key_valid was set.
DMA_START
DMA mode start enable. Starting DMA transfer, this signal should be cleared after DMA has finished all transfers.
EN
HMAC enable, high valid for whole HMAC processing. Users must disable it once all HMAC blocks complete. This signal should be asserted until all blocks complete.
CFG
  • Name: HMAC Configuration Register
  • Description: This register acts as a configuration for HMAC.
  • Offset: 0x4
表 664 HMAC Configuration Register
31:6
5
PRIVT_MOD
To resist DPA, select private mode.
  • 0x0: Standard mode
  • 0x1: Private mode
4
CALC_TYPE
Selects a calculation type.
  • 0x0: HMAC
  • 0x1: SHA
3:2
KEY_TYPE
Selects a key type.
  • 0x0: Configured by MCU
  • 0x1: Fetched through AHB interface
  • 0x2: Fetched through key port
  • 0x3: Reserved
ENDIAN
Selection for endian control
  • 0x0: Reverse to big-endian (default)
  • 0x1: No reverse
HASH
Enables user-defined hash.
  • 0x0: Initial Hash from standard (default)
  • 0x1: User-defined initial Hash enabled
STAT
  • Name: HMAC Status Register
  • Description: This is a read-only register used to indicate the current status of HMAC.
  • Offset: 0x8
表 665 HMAC Status Register
31:6
5
DMA_TX_DONE
HMAC DMA transfer done or not
4
HMAC_READY
HMAC process status
  • 0x0: Result data is not ready.
  • 0x1: Result data is valid.
3
KEY_VALID
HMAC has fetched key or not
2
DMA_TX_ERR
WC
HMAC DMA transfer error.
Write 1 to clear.
DMA_MSG_DONE
If the number of all block messages is bigger than the transfer size, it indicates all block messages are sent when this signal is set.
HASH_READY
Hash process status
XFER_SIZE
  • Name: HMAC Transfer Size Register
  • Description: This register sets a size for HMAC DMA mode transfer.
  • Offset: 0xC
表 666 HMAC Transfer Size Register
31:15
14:0
SIZE
Total transfer size. Up to 32 KB
  • 0x003F: 1 block
  • 0x007F: 2 blocks
  • 0x00BF: 3 blocks
  • 0x7FFF: 512 blocks
INT
  • Name: HMAC Interrupt Register
  • Description: This register enables or disables all interrupts generated by the HMAC. Additionally, it reports the status of the HMAC interrupts after they have been enabled.
  • Offset: 0x10
表 667 HMAC Interrupt Register
31:2
EN
HMAC result data complete interrupt
  • 0x0: Disable
  • 0x1: Enable
DONE
WC
HMAC result data complete interrupt flag. Write 1 to clear.
Read:
  • 0x0: Not interrupt
  • 0x1: Interrupt
Write:
  • 0x0: Not effect
  • 0x1: Clear
RD_START_ADDR
  • Name: HMAC Read Start Address Register
  • Description: This register acts as a start address for HMAC DMA reading.
  • Offset: 0x14
表 668 HMAC Read Start Address Register
31:0
ADDR
In DMA mode, set the read start address of transfer.
WR_START_ADDR
  • Name: HMAC Write Start Address Register
  • Description: This register acts as a start address for HMAC DMA writing.
  • Offset: 0x18
表 669 HMAC Write Start Address Register
31:0
ADDR
In DMA mode, set the write start address of transfer.
USER_HASH_0
  • Name: HMAC User Hash 0 Register
  • Description: This register acts as a user Hash value for HASH calculation.
  • Offset: 0x20
表 670 HMAC User Hash 0 Register
Bits
Field Name
Reset
Description
31:0
HASH_0
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7.
User defined Hash value[255:224]
USER_HASH_1
  • Name: HMAC User Hash 1 Register
  • Offset: 0x24
表 671 HMAC User Hash 1 Register
31:0
HASH_1
User defined Hash value[223:192]
USER_HASH_2
  • Name: HMAC User Hash 2 Register
  • Offset: 0x28
表 672 HMAC User Hash 2 Register
31:0
HASH_2
User defined Hash value[191:160]
USER_HASH_3
  • Name: HMAC User Hash 3 Register
  • Offset: 0x2C
表 673 HMAC User Hash 3 Register
31:0
HASH_3
User defined Hash value[159:128]
USER_HASH_4
  • Name: HMAC User Hash 4 Register
  • Offset: 0x30
表 674 HMAC User Hash 4 Register
31:0
HASH_4
If UHASH is selected, you can configure a user-defined Hash value with USER_HASH_0/1/2/3/4/5/6/7.
User defined Hash value[127:96]
USER_HASH_5
  • Name: HMAC User Hash 5 Register
  • Offset: 0x34
表 675 HMAC User Hash 5 Register
31:0
HASH_5
User defined Hash value[95:64]
USER_HASH_6
  • Name: HMAC User Hash 6 Register
  • Offset: 0x38
表 676 HMAC User Hash 6 Register
31:0
HASH_6
User defined Hash value[63:32]
USER_HASH_7
  • Name: HMAC User Hash 7 Register
  • Offset: 0x3C
表 677 HMAC User Hash 7 Register
31:0
HASH_7
User defined Hash value[31:0]
DATA_OUT
  • Name: HMAC Data Output Register
  • Description: This register is a 32-bit only read buffer for the result data from HMAC.
  • Offset: 0x40
表 678 HMAC Data Output Register
31:0
DATA
In MCU mode, users can read out results with this register:
When all blocks of messages are processed, 256-bit HMAC data should be read out 8 or 9 times. HMAC data can be read when hmac_ready is valid.
DATA_IN
  • Name: HMAC Data Input Register
  • Description: This register is a 32-bit only write buffer for the input data for HMAC.
  • Offset: 0x44
表 679 HMAC Data Input Register
Bits
Field Name
Reset
Description
31:0
DATA
W
In MCU mode, users can configure input data with this register:
32-bit data should be sent 16 or 17 times.
KEY0
  • Name: HMAC Key 0 Register
  • Description: This register is a 32-bit only write buffer for the key data[255:224] for HMAC.
  • Offset: 0x48
表 680 HMAC Key 0 Register
31:0
KEY0
W
Key is set as 256 bits (8 words).
WORD0
KEY1
  • Name: HMAC Key 1 Register
  • Description: This register is a 32-bit only write buffer for the key data[223:192] for HMAC.
  • Offset: 0x4C
表 681 HMAC Key 1 Register
31:0
KEY1
W
WORD1
KEY2
  • Name: HMAC Key 2 Register
  • Description: This register is a 32-bit only write buffer for the key data[191:160] for HMAC.
  • Offset: 0x50
表 682 HMAC Key 2 Register
31:0
KEY2
W
WORD2
KEY3
  • Name: HMAC Key 3 Register
  • Description: This register is a 32-bit only write buffer for the key data[159:128] for HMAC.
  • Offset: 0x54
表 683 HMAC Key 3 Register
31:0
KEY3
W
WORD3
KEY4
  • Name: HMAC Key 4 Register
  • Description: This register is a 32-bit only write buffer for the key data[127:96] for HMAC.
  • Offset: 0x58
表 684 HMAC Key 4 Register
31:0
KEY4
W
WORD4
KEY5
  • Name: HMAC Key 5 Register
  • Description: This register is a 32-bit only write buffer for the key data[95:64] for HMAC.
  • Offset: 0x5C
表 685 HMAC Key 5 Register
31:0
KEY5
W
WORD5
KEY6
  • Name: HMAC Key 6 Register
  • Description: This register is a 32-bit only write buffer for the key data[63:32] for HMAC.
  • Offset: 0x60
表 686 HMAC Key 6 Register
Bits
Field Name
Reset
Description
31:0
KEY6
W
WORD6
KEY7
  • Name: HMAC Key 7 Register
  • Description: This register is a 32-bit only write buffer for the key data[31:0] for HMAC.
  • Offset: 0x64
表 687 HMAC Key 7 Register
31:0
KEY7
W
WORD7
KEY_ADDR
  • Name: HMAC Key Address Register
  • Description: This register acts as a key address for HMAC.
  • Offset: 0x68
表 688 HMAC Key Address Register
31:0
KEY_ADDR
Indicates the HMAC key address in memory.
KEYPORT_MASK
  • Name: HMAC Keyport Mask Register
  • Description: This register acts as a mask for key from key port.
  • Offset: 0x6C
表 689 HMAC Keyport Mask Register
31:0
MASK
W
Mask for key from key port
