文档中心 > GR5526 Datasheet/ Peripherals/ Security Interfaces/ Advanced Encryption Standard (AES) Copy URL
Advanced Encryption Standard (AES), also known as Rijndael encryption method in cryptography, is a block encryption standard adopted by the U.S. federal government. This standard is used to replace the Data Encryption Standard (DES). The block length of AES is fixed at 128 bits, and the key length can be 128, 192, or 256 bits. The basic processes of AES include SubBytes, ShiftRows, MixColumns, and AddRoundKey.
  • Compliance with NIST “Advanced Encryption Standard (AES), FIPS Publication 197” from November 2001
  • Supports 128-bit, 192-bit, and 256-bit key.
  • Supports encryption mode and decryption mode.
  • Supports interrupt and query register to report status.
  • Supports Electronic Codebook (ECB) and Cipher Block chaining (CBC) modes.
  • Supports MCU and DMA operation.
Standard
表 628 AES module standard
FIPS PUB 197
Module Overview
The AES co-processor encrypts or decrypts data, using an algorithm and implementation fully compliant with the AES defined in Federal Information Processing Standards (FIPS) publication 197. GR5526 embeds the AES module in order to realize hardware acceleration of calculation.
图 135 AES module in the system
Electronic Codebook (ECB) and Cipher Block Chaining (CBC) are supported for key size of 128 bits, 192 bits, and 256 bits.
Due to the feature of block cipher of AES, the data to be encrypted requires an integer multiple of 16 bytes.
The AES co-processor adopts both 32-bit AHB and APB interfaces. It supports DMA transfers for incoming and outgoing data (through a dedicated integrated DMA).
Usage
The CFG register can be used to configure relevant parameters for the AES module. CFG.KEY_MODE can be used to configure the key size to 128 bits, 192 bits, or 256 bits. CFG.DEC_ENC_SEL can be used to configure the encryption or decryption mode. CFG.OPT_MODE can be used to configure the working mode of ECB or CBC. CFG.KEY_TYPE can be used to configure the mode of fetching the key.
If the key is configured by MCU, the KEY0 to KEY7 registers need to be configured (128-bit for KEY0 to KEY3 only and 192-bit for KEY0 to KEY5 only). If the key is fetched through AHB, the KEY_ADDR register should be configured.
CTRL.FKEY_EN is configured in order to enable the AES module to fetch the key through AHB master interface. The STAT register is used to indicate the current status of the AES module. The random seeds are set to the INIT_SSI, INIT_SSO, MASK_SSI, and MASK_SSO registers.
The initialization vector (IV) should be set to the INIT_V0 to INIT_V3 registers for AES CBC mode.
If the AES module is in interrupt or DMA operation mode, the INT register needs to be configured.
In MCU operation mode, a block data (128-bit) is written into the DATA_IN0 to DATA_IN3 registers. In DMA operation mode, the XFER_SIZE, RD_START_ADDR, and WR_START_ADDR registers should be configured. The AES module will read the data from the address which is stored in the RD_START_ADDR register.
The AES module can be started through the CTRL register. The STAT register or the interrupt callback function can judge whether the calculation completes.
The plain data or the encrypted data can be read from the DATA_OUT0 to DATA_OUT3 registers in MCU operation mode. In DMA operation mode, the result has been sent to the address which is stored in the WR_START_ADDR register.
The endian of the data needs to be noticed and configured; otherwise it will affect the result of encryption and decryption. If the data is encrypted and decrypted in batches in CBC mode, the encryption result should be set as the IV to the INIT_V0 to INIT_V3 registers.
CTRL
  • Name: AES Controller Register
  • Description: This register acts as a global enable/disable for AES.
  • Base Address: 0x40015000
  • Offset: 0x0
表 629 AES Controller Register
31:4
3
FKEY_EN
W
Enable AES fetch key by itself through AHB master interface or key port. This register can be cleared by itself when key_valid is set to 1.
2
DMA_MODE_EN
DMA mode start enable bit.
Start N block data encryption or decryption in DMA mode.
MCU_MODE_EN
MCU mode start enable bit.
Start a block data encryption or decryption in DMA mode.
This signal should be cleared to zero before a new block input data is ready to start.
MODULE_EN
Enables AES module.
  • 0x0: Disable
  • 0x1: Enable
CFG
  • Name: AES Configuration Register
  • Description: This register acts as a configuration for AES.
  • Offset: 0x4
表 630 AES Configuration Register
31:13
12:11
KEY_TYPE
Key type selection for encryption/decryption
  • 0x0: Configured by MCU (default)
  • 0x1: Fetched through AHB interface
  • 0x2: Fetched through key port
  • 0x3: Reserved
10:8
OPT_MODE
Selection for operation mode
  • 0x0: Electronic Codebook (ECB) mode
  • 0x1: Cipher Block Chaining (CBC) mode
  • 0x2–0x7: Reserved for future application
7
ENDIAN
Selection for data endian control
  • 0x0: Reverse to big-endian (default)
  • 0x1: No reverse
6
FIRST_BLK
W
This register should be set to 1 before starting the first block in normal CBC and DMA CBC modes, and this register will be cleared by itself.
5
LOAD_SEED
W
Loads seed for LFSR. Seed for LFSR will be reloaded when this register is written with 1. This register can be cleared by itself.
4
DEC_ENC_SEL
Selection for encryption/decryption
  • 0x0: Decryption (default)
  • 0x1: Encryption
3
FULL_MASK_EN
Full mask enable signal
  • 0x0: Disable (default)
  • 0x1: Enable (DPA resistance)
2
Reserved bit
1:0
KEY_MODE
Key mode selection for encryption/decryption
  • 0x0: 128 bits (default)
  • 0x1: 192 bits
  • 0x2: 256 bits
  • 0x3: Reserved
STAT
  • Name: AES Status Register
  • Description: This is a read-only register used to indicate the current status of AES.
  • Offset: 0x8
表 631 AES Status Register
31:4
3
KEY_STAT
Key status, whether the key is ready to read or not
  • 0x0: Not ready
  • 0x1: Ready
2
DMA_XFE_ERR
WC
DMA transfer error. Write 1 to clear this register.
  • 0x0: No error
  • 0x1: Error
DMA_XFE_CPLT
DMA transfer complete
  • 0x0: Not complete
  • 0x1: Complete
READY
AES result data out ready or not.
This signal may be cleared when MCUEN (CTRL[1]) is disabled.
  • 0x0: Not ready
  • 0x1: Ready
INT
  • Name: AES Interrupt Register
  • Description: This register enables or disables all interrupts generated by the AES. Additionally, it reports the status of the AES interrupts after they have been enabled.
  • Offset: 0x0C
表 632 AES Interrupt Register
31:2
CPLT_INT_EN
AES result data complete interrupt
  • 0x0: Disable
  • 0x1: Enable
CPLT_INT_FLAG
WC
AES result data complete interrupt flag. Write 1 to clear.
Read:
  • 0x0: Not interrupt
  • 0x1: Interrupt
Write:
  • 0x0: Not effect
  • 0x1: Clear
XFE_SIZE
  • Name: AES Transfer Size Register
  • Description: This register sets a size for AES DMA mode transfer.
  • Offset: 0x10
表 633 AES Transfer Size Register
31:15
14:0
SIZE
Total transfer size. Up to 32 KB
  • 0x000f: 1 block
  • 0x001f: 2 blocks
  • 0x002f: 3 blocks
  • 0x7fff: 2048 blocks
RD_START_ADDR
  • Name: AES Read Start Address Register
  • Description: This register acts as a start address for AES DMA reading.
  • Offset: 0x14
表 634 AES Read Start Address Register
31:0
ADDR
In DMA mode, sets the read start address of transfer.
WR_START_ADDR
  • Name: AES Write Start Address Register
  • Description: This register acts as a start address for AES DMA writing.
  • Offset: 0x18
表 635 AES Write Start Address Register
31:0
ADDR
In DMA mode, sets the write start address of transfer.
KEY_ADDR
  • Name: AES Key Address Register
  • Description: This register acts as a key address for AES encryption or decryption.
  • Offset: 0x1C
表 636 AES Key Address Register
31:0
ADDR
Indicates the AES key address in memory.
DATA_OUT0
  • Name: AES Data Output 0 Register
  • Description: This register is a 32-bit read-only buffer for the result data[127:96] from AES.
  • Offset: 0x20
表 637 AES Data Output 0 Register
31:0
DATA_OUT0
AES result data[127:96]
DATA_OUT1
  • Name: AES Data Output 1 Register
  • Description: This register is a 32-bit read-only buffer for the result data[95:64] from AES.
  • Offset: 0x24
表 638 AES Data Output 1 Register
31:0
DATA_OUT1
AES result data[95:64]
DATA_OUT2
  • Name: AES Data Output 2 Register
  • Description: This register is a 32-bit read-only buffer for the result data[63:32] from AES.
  • Offset: 0x28
表 639 AES Data Output 2 Register
31:0
DATA_OUT2
AES result data[63:32]
DATA_OUT3
  • Name: AES Data Output 3 Register
  • Description: This register is a 32-bit read-only buffer for the result data[31:0] from AES.
  • Offset: 0x2C
表 640 AES Data Output 3 Register
31:0
DATA_OUT3
AES result data[31:0]
KEY0
  • Name: AES Key 0 Register
  • Description: This register is a 32-bit write-only buffer for the key data[255:224] for AES.
  • Offset: 0x30
表 641 AES Key 0 Register
31:0
KEY0
W
AES key[255:224]
KEY1
  • Name: AES Key 1 Register
  • Description: This register is a 32-bit write-only buffer for the key data[223:192] for AES.
  • Offset: 0x34
表 642 AES Key 1 Register
31:0
KEY1
W
AES key[223:192]
KEY2
  • Name: AES Key 2 Register
  • Description: This register is a 32-bit write-only buffer for the key data[191:160] for AES.
  • Offset: 0x38
表 643 AES Key 2 Register
31:0
KEY2
W
AES key[191:160]
KEY3
  • Name: AES Key 3 Register
  • Description: This register is a 32-bit write-only buffer for the key data[159:128] for AES.
  • Offset: 0x3C
表 644 AES Key 3 Register
31:0
KEY3
W
AES key[159:128]
KEY4
  • Name: AES Key 4 Register
  • Description: This register is a 32-bit write-only buffer for the key data[127:96] for AES.
  • Offset: 0x40
表 645 AES Key 4 Register
31:0
KEY4
W
AES key[127:96]
KEY5
  • Name: AES Key 5 Register
  • Description: This register is a 32-bit write-only buffer for the key data[95:64] for AES.
  • Offset: 0x44
表 646 AES Key 5 Register
31:0
KEY5
W
AES key[95:64]
KEY6
  • Name: AES Key 6 Register
  • Description: This register is a 32-bit write-only buffer for the key data[63:32] for AES.
  • Offset: 0x48
表 647 AES Key 6 Register
31:0
KEY6
W
AES key[63:32]
KEY7
  • Name: AES Key 7 Register
  • Description: This register is a 32-bit write-only buffer for the key data[31:0] for AES.
  • Offset: 0x4C
表 648 AES Key 7 Register
31:0
KEY7
W
AES key[31:0]
INIT_SSI
  • Name: AES Sbox Initial Seed Input Register
  • Description: This register acts as an initial seed input for Sbox.
  • Offset: 0x50
表 649 AES Sbox Initial Seed Input Register
31:0
SEED
Sbox initial seed input
INIT_SSO
  • Name: AES Sbox Initial Seed Output Register
  • Description: This register acts as an initial seed output for Sbox.
  • Offset: 0x54
表 650 AES Sbox Initial Seed Output Register
31:0
SEED
Sbox initial seed output
MASK_SSI
  • Name: AES Sbox Seed Input Mask Register
  • Description: This register acts as a mask for Sbox initial seed input mask.
  • Offset: 0x58
表 651 AES Sbox Seed Input Mask Register
31:0
MASK
MASK_SSO
  • Name: AES Sbox Seed Output Mask Register
  • Description: This register acts as a mask for Sbox initial seed output mask.
  • Offset: 0x5C
表 652 AES Sbox Seed Output Mask Register
31:0
MASK
INIT_V0
  • Name: AES Initialization Vector 0 Register
  • Description: This register acts as an initialization vector[127:96] for CBC mode.
  • Offset: 0x60
表 653 AES Initialization Vector 0 Register
31:0
VECTOR
W
Initialization vector[127:96] for CBC mode
INIT_V1
  • Name: AES Initialization Vector 1 Register
  • Description: This register acts as an initialization vector[95:64] for CBC mode.
  • Offset: 0x64
表 654 AES Initialization Vector 1 Register
31:0
VECTOR
W
Initialization vector[95:64] for CBC mode
INIT_V2
  • Name: AES Initialization Vector 2 Register
  • Description: This register acts as an initialization vector[63:32] for CBC mode.
  • Offset: 0x68
表 655 AES Initialization Vector 2 Register
31:0
VECTOR
W
Initialization vector[63:32] for CBC mode
INIT_V3
  • Name: AES Initialization Vector 3 Register
  • Description: This register acts as an initialization vector[31:0] for CBC mode.
  • Offset: 0x6C
表 656 AES Initialization Vector 3 Register
31:0
VECTOR
W
Initialization vector[31:0] for CBC mode
DATA_IN0
  • Name: AES Data Input 0 Register
  • Description: This register is a 32-bit only write buffer for the input data[127:96] for encryption or decryption.
  • Offset: 0x70
表 657 AES Data Input 0 Register
31:0
DATA_IN0
W
Input data[127:96] for encryption or decryption.
This register is valid in MCU mode.
DATA_IN1
  • Name: AES Data Input 1 Register
  • Description: This register is a 32-bit only write buffer for the input data[95:64] for encryption or decryption.
  • Offset: 0x74
表 658 AES Data Input 1 Register
31:0
DATA_IN1
W
Input data[95:64] for encryption or decryption.
DATA_IN2
  • Name: AES Data Input 2 Register
  • Description: This register is a 32-bit only write buffer for the input data[63:32] for encryption or decryption.
  • Offset: 0x78
表 659 AES Data Input 2 Register
31:0
DATA_IN2
W
Input data[63:32] for encryption or decryption.
DATA_IN3
  • Name: AES Data Input 3 Register
  • Description: This register is a 32-bit only write buffer for the input data[31:0] for encryption or decryption.
  • Offset: 0x7C
表 660 AES Data Input 3 Register
31:0
DATA_IN3
W
Input data[31:0] for encryption or decryption.
KEYPORT_MASK
  • Name: AES Keyport Mask Register
  • Description: This register acts as a mask for key from key port.
  • Offset: 0x80
表 661 AES Keyport Mask Register
31:0
MASK
W
Mask for key from key port
