GPU
Graphics Processing Unit (GPU) is a kind of microprocessor that specializes in image and graphic related operations. GR5526 integrates a low-power GPU which can bring high-quality graphics to the user interface with a very small silicon/power budget. It supports entry-level IoT platforms, wearables, and embedded devices with low-cost and ultra-low power consumption requirements, and provides a smooth graphical experience suitable for various applications. Developers can create compelling graphical user interfaces (GUIs) and software applications with extremely long battery life for power-memory-area constrained IoT devices at significantly lower cost.
  • Hardware components:
    • Programmable shader engine with a very long instruction word (VLIW) architecture
    • Command-list-based DMAs to minimize CPU overhead
    • Primitive rasterizer
    • Texture mapping unit
    • Blending unit
  • Drawing primitives:
    • Pixel/Line drawing
    • Filled rectangles
    • Triangles (Gouraud shaded)
    • Quadrilaterals
  • Color formats:
    • 32-bit RGBA8888/BGRA8888/ABGR8888
    • 24-bit RGB
    • 16-bit RGBA5551/RGB565
    • 8-bit A8/L8/RGB332
    • TSCTM
  • Compression & Decompression feature:
    • Image transformation
    • Texture mapping
    • Point sampling
    • Bilinear filtering
    • Blit support
    • Rotation any angle
    • Mirroring
    • Stretch (independently on X and Y axes)
    • Source and/or destination color keying
    • Format conversions on the fly
    • 2.5D perspective correct projections
  • Text rendering support:
    • Bitmap antialiased A1/A2/A4/A8
    • Font Kerning
    • Unicode (UTF8)
  • Blending support:
    • Fully programmable Alpha blending modes (source and destination)
    • Source/Destination color keying
  • Antialiasing:
    • 8 x MSAA
    • Quadrilaterals per edge antialiasing
    • Triangles per edge antialiasing
    • Antialiased thick lines
    • Antialiased circles
Block Diagram
图 123 GPU block diagram
The fixed-point data path and instruction set architecture (ISA) of the GPU are tailored specifically for GUIs acceleration and small display applications, resulting in significant improvements in power consumption and silicon area. The GPU combines hardware-level support for multithreading, VLIW, and low-level vector processing in the most energy-efficient way. The GPU block diagram is shown above.
I/O Interfaces
The GPU supports connection via AHB that helps it communicate with the MCU, configuration registers, and system memory. The GPU uses two 32-bit AHB master ports that enable access to the main memory and that support data fetch from the G PU (such as textures and frame data). The AHB version of the system fetches both the command lists and rendering data over the same read bus.
Configuration Register File
The GPU is programmed through a set of registers which are known as configuration register file (CRF), and each sub-module of the GPU is programmed through a subset of the CRF. CRF can be memory-mapped to the CPU address space, making it directly accessible. Writing CRF directly is considered inefficient because it consumes a lot of CPU resources and associates CPU execution with the GPU. Therefore, the GPU supports indirect CRF access through the Command List Processor (CLP).
In order to decouple CPU from GPU execution and achieve both better performance and lower power consumption, the GPU incorporates an advanced Command List Processor (CLP), capable of reading entire lists of commands from the main memory and relaying them to the CRF.
The CPU pre-assembles Command Lists (CLs) prior to submitting them to the CLP for execution, while a single CL can be submitted multiple times. This approach alleviates the CPU from recalculating drawing operations for repetitive tasks, resulting in more efficient resource utilization.
The steps for writing commands to the configuration registers through the CLP are the following:
  1. The CPU assembles a CL, through the GFX library.
  2. The CPU submits the CL for execution. The CLP is informed of a pending CL.
  3. The CLP reads the CL from the system memory.
  4. The CLP relays the commands to the Configuration Register File.
Rasterizer
The GPU can draw a multitude of geometrical shapes called Geometric Primitives, such as lines, rectangles, triangles, and quadrilaterals. The rasterizer unit reads the coordinates of the primitives’ vertices and feeds the rest of the graphics pipeline with the fragments contained in the geometry. A fragment contains information concerning a single pixel. This information includes raster position (coordinates), texture coordinates, interpolated color, and alpha values.
The rasterizer can draw:
  • Line drawing (at any direction)
  • Filled rectangles
  • Quadrilaterals
  • Triangles
In addition, the rasterizer handles clipping by either dropping fragments that are outside the effective drawing area and back-face culling or dropping entire primitives that are considered to be non-visible, like the rear looking faces of a cube. If a pixel resides inside or outside of the geometry primitive, the pixel is determined by the value of E which is positive inside the geometry primitive and negative outside of it.
The pixel’s edge function value is calculated for each line of the geometry primitive (for example, 3 times for a triangle) using the following equation:
E = A ∙ x + B ∙ y + C
Although the equation requires two multiplications and two additions since the variation is always one pixel on the X or Y axis, this is reduced to a single accumulator.
The color variances are also calculated in a similar way, where each of the RGBA components is linearly interpolated across the geometry of the primitive. If H/W Blender is enabled, each edge can be independently programmed to either have antialiasing or not. The rasterizer also determines the coverage value of each pixel as a function of the pixel center to the closest edge distance.
Transformations are performed using matrix multiplication. The Vector Matrix Multiplier multiplies a 2 x 1 Vector (x,y) by a 3 x 3 homogeneous Matrix to produce a new 2 x 1 Vector (Tx,Ty). The following computation is required to calculate texel coordinates from screen coordinates:
T x = t00 ∙ x + t01 ∙ y + t02 t20 ∙ x + t21 ∙ y + t22             T y = t10 ∙ x + t11 ∙ y + t12 t20 ∙ x + t21 ∙ y + t22
Texture Map Unit
The texture map unit produces texels that are sent to the fragment processing core. It is fed with texture’s attributes (base address, dimensions, color format) and the required coordinates. The texture map unit performs some internal processing and outputs the corresponding texel. Generating a texture element requires a series of operations like wrapping (clamp, mirror, and repeat), reading corresponding color values from memory, converting the color values to RGBA8888 format, and performing filtering if necessary.
Fragment Processing Core
The fragment processing core is the main processing unit of the GPU’s architecture. It is a 64-bit VLIW processor which performs computations on the fragments coming from the rasterizer unit and on the texels coming from the texture map unit and calculates the final color to a fragment. The core is programmable through binary executables called Fragment Shaders.
Render Output Unit
The render output unit (ROP) is the last stage of the graphics pipeline. The fragment processing core feeds the ROP with the pixel’s coordinates and color value. Before the color value is written to the memory, the color is converted to the frambuffer’s format.
If H/W Blender is enabled, the ROP reads pixels from the fragment processing core (source) and pixels from the framebuffer (destination) to perform blending. Blending requires a series of calculations between the source (foreground) and destination (background) color fragments to produce the final color, which is written back to memory. The following equations are used for the final color:
F c = S c ∙ S f + D c ∙ D f                 F a = S a ∙ S f + D a ∙ D f
  • Fc: Final Color
  • Sc: Source Color
  • Sf: Source Blend Factor (multiplier)
  • Dc: Destination Color
  • Df: Destination Blend Factor (multiplier)
  • Fa: Final Alpha
  • Sa: Source Alpha
  • Da: Destination Alpha
The Color and Alpha values range from 0 to 1, therefore each calculation result is also clamped to the same range. The available Blend Factors and the resulting RGBA values are listed in the table below. The effect of the blending modes is shown in the figure below.
表 465 Blend factors
Blending Mode Name Blend Factors (Sc or Df ) RGBA Value Definition
DSBF_ZERO
0,0,0,0
DSBF_ONE
1,1,1,1
DSBF_SRCCOLOR
Sc
Rsrc, Gsrc, Bsrc, Asrc
  • Sc: Source Color
  • Rsrc: Source Red value
  • Gsrc: Source Green value
  • Bsrc: Source Blue value
  • Asrc: Source Alpha value
DSBF_INVSRCCOLOR
(1 – Sc)
1 – Rsrc, 1 – Gsrc, 1–Bsrc, 1 – Asrc
DSBF_SRCALPHA
Sa
Asrc, Asrc, Asrc, Asrc
  • Sa: Source Alpha
DSBF_INVSRCALPHA
(1 – Sa)
1 – Asrc, 1 – Asrc, 1 – Asrc, 1 – Asrc
DSBF_DESTALPHA
Da
Adst, Adst, Adst, Adst
  • Adst: Destination Alpha value
DSBF_INVDESTALPHA
(1 – Da)
1 – Adst, 1 – Adst, 1 – Adst, 1 – Adst
DSBF_DESTCOLOR
Dc
Rdst, Gdst, Bdst, Adst
  • Rdst: Destination Red value
  • Gdst: Destination Green value
  • Bdst: Destination Blue value
DSBF_INVDESTCOLOR
(1 – Dc)
1 – Rdst, 1 – Gdst, 1 – Bdst, 1 – Adst
DSBF_CONSTCOLOR
Cc
Rconst, Gconst, Bconst, Aconst
  • Cc: Constant Color
  • Ca: Constant Alpha
  • Rconst: Constant Red value
  • Gconst: Constant Green value
  • Bconst: Constant Blue value
  • Aconst: Constant Alpha value
DSBF_CONSTALPHA
Ca
Aconst, Aconst, Aconst, Aconst
DSBF_UNKNOWN
0,0,0,0
图 124 Blending modes
Framebuffer Compression
Framebuffer compression operates in screen blocks (4 x 4 pixel blocks) and achieves TSCTM4, TSCTM6 and TSCTM6a lossy, fixed-ratio compression depending on the configuration.
  • TSCTM4 is a 6:1 compression (4bpp).
  • TSCTM6 is a 4:1 compression (6bpp).
  • TSCTM6a is a 4:1 compression (6bpp) with alpha channel.
Compression is performed at run time using minimal hardware. Pixel data can be stored in the framebuffer in compressed form and decompressed in the display control (DC) module. The output of the TSCTM4 compression is 64 bits per 4 x 4 block of pixels, and the output of the TSCTM6 compression is 96 bits per 4 x 4 block of pixels.
Color Modes
The GPU supports multiple color formats. The supported color formats are the following:
  • RGBX8888 32-bit
表 466 RGBX8888 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
X7
X6
X5
X4
X3
X2
X1
X0
B7
B6
B5
B4
B3
B2
B1
B0
G7
G6
G5
G4
G3
G2
G1
G1
R7
R6
R5
R4
R3
R2
R1
R0
Byte 3
Byte 2
Byte 1
Byte 0
  • RGBA8888 32-bit
表 467 RGBA8888 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
A7
A6
A5
A4
A3
A2
A1
A0
B7
B6
B5
B4
B3
B2
B1
B0
G7
G6
G5
G4
G3
G2
G1
G1
R7
R6
R5
R4
R3
R2
R1
R0
Byte 3
Byte 2
Byte 1
Byte 0
  • XRGB8888 32-bit
表 468 XRGB8888 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
B7
B6
B5
B4
B3
B2
B1
B0
G7
G6
G5
G4
G3
G2
G1
G1
R7
R6
R5
R4
R3
R2
R1
R0
X7
X6
X5
X4
X3
X2
X1
X0
Byte 3
Byte 2
Byte 1
Byte 0
  • ARGB8888 32-bit
表 469 ARGB8888 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
B7
B6
B5
B4
B3
B2
B1
B0
G7
G6
G5
G4
G3
G2
G1
G1
R7
R6
R5
R4
R3
R2
R1
R0
A7
A6
A5
A4
A3
A2
A1
A0
Byte 3
Byte 2
Byte 1
Byte 0
  • RGB5650 16-bit
表 470 RGB5650 16-bit
Pixel 0
15
14
13
12
11
10
9
8
7
6
5
4
3
2
R4
R3
R2
R1
R0
G5
G4
G3
G2
G1
G1
B4
B3
B2
B1
B0
Byte 1
Byte 0
  • RGBA5551 16-bit
表 471 RGBA5551 16-bit
Pixel 0
15
14
13
12
11
10
9
8
7
6
5
4
3
2
R4
R3
R2
R1
R0
G4
G3
G2
G1
G1
B4
B3
B2
B1
B0
A0
Byte 1
Byte 0
  • RGBA4444 16-bit
表 472 RGBA4444 16-bit
Pixel 0
15
14
13
12
11
10
9
8
7
6
5
4
3
2
R3
R2
R1
R0
G3
G2
G1
G1
B3
B2
B1
B0
A3
A2
A1
A0
Byte 1
Byte 0
  • RGBA0008 8-bit
表 473 RGBA0008 8-bit
Pixel 0
7
6
5
4
3
2
A7
A6
A5
A4
A3
A2
A1
A0
Byte 0
  • L8 8-bit
表 474 L8 8-bit
Pixel 0
7
6
5
4
3
2
L7
L6
L5
L4
L3
L2
L1
L0
Byte 0
  • L1 big-endian 1-bit
表 475 L1 big-endian 1-bit
Pixel 0 Pixel 1 Pixel 2 Pixel 3 Pixel 4 Pixel 5 Pixel 6 Pixel 7
7
6
5
4
3
2
L0
L0
L0
L0
L0
L0
L0
L0
Byte 0
  • A1 big-endian 1-bit
表 476 A1 big-endian 1-bit
7
6
5
4
3
2
A0
A0
A0
A0
A0
A0
A0
A0
Byte 0
  • UYVY 32-bit 2-pixel
表 477 UYVY 32-bit 2-pixel
Pixel 1 Pixel1&0 Pixel 0 Pixel1&0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
Y7
Y6
Y5
Y4
Y3
Y2
Y1
Y0
V7
V6
V5
V4
V3
V2
V1
V0
Y7
Y6
Y5
Y4
Y3
Y2
Y1
Y1
U7
U6
U5
U4
U3
U2
U1
U0
Byte 3
Byte 2
Byte 1
Byte 0
  • ABGR8888 32-bit
表 478 ABGR8888 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
R7
R6
R5
R4
R3
R2
R1
R0
G7
G6
G5
G4
G3
G2
G1
G1
B7
B6
B5
B4
B3
B2
B1
B0
A7
A6
A5
A4
A3
A2
A1
A0
Byte 3
Byte 2
Byte 1
Byte 0
  • BGRA 32-bit
表 479 BGRA 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
A7
A6
A5
A4
A3
A2
A1
A0
R7
R6
R5
R4
R3
R2
R1
R0
G7
G6
G5
G4
G3
G2
G1
G1
B7
B6
B5
B4
B3
B2
B1
B0
Byte 3
Byte 2
Byte 1
Byte 0
  • BGRX 32-bit
表 480 BGRX 32-bit
Pixel 0
31
30
29
28
27
26
25
24
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
X7
X6
X5
X4
X3
X2
X1
X0
R7
R6
R5
R4
R3
R2
R1
R0
G7
G6
G5
G4
G3
G2
G1
G1
B7
B6
B5
B4
B3
B2
B1
B0
Byte 3
Byte 2
Byte 1
Byte 0
  • TSC4 16-pixel/64-bit
  • TSC6 16-pixel/96-bit
  • TSC6A 16-pixel with Alpha/96-bit
  • A1LE little-endian 1-bit
表 481 A1LE little-endian 1-bit
Pixel 7 Pixel 6 Pixel 5 Pixel 4 Pixel 3 Pixel 2 Pixel 1 Pixel 0
7
6
5
4
3
2
A0
A0
A0
A0
A0
A0
A0
A0
Byte 0
  • A2LE little-endian 2-bit
表 482 A2LE little-endian 2-bit
7
6
5
4
3
2
A1
A0
A1
A0
A1
A0
A1
A0
Byte 0
  • A4LE little-endian 4-bit
表 483 A4LE little-endian 4-bit
Pixel 1 Pixel 0
7
6
5
4
3
2
A3
A2
A1
A0
A3
A2
A1
A0
Byte 0
  • L1LE little-endian 1-bit
表 484 L1LE little-endian 1-bit
7
6
5
4
3
2
L0
L0
L0
L0
L0
L0
L0
L0
Byte 0
  • L2LE little-endian 2-bit
表 485 L2LE little-endian 2-bit
7
6
5
4
3
2
L1
L0
L1
L0
L1
L0
L1
L0
Byte 0
  • L4LE little-endian 4-bit
表 486 L4LE little-endian 4-bit
Pixel 1 Pixel 0
7
6
5
4
3
2
L3
L2
L1
L0
L3
L2
L1
L0
Byte 0
  • A2 big-endian 2-bit
表 487 A2 big-endian 2-bit
7
6
5
4
3
2
A1
A0
A1
A0
A1
A0
A1
A0
Byte 0
  • L2 big-endian 2-bit
表 488 L2 big-endian 2-bit
7
6
5
4
3
2
L1
L0
L1
L0
L1
L0
L1
L0
Byte 0
  • A4 big-endian 4-bit
表 489 A4 big-endian 4-bit
Pixel 0 Pixel 1
7
6
5
4
3
2
A3
A2
A1
A0
A3
A2
A1
A0
Byte 0
  • L4 big-endian 4-bit
表 490 L4 big-endian 4-bit
Pixel 0 Pixel 1
7
6
5
4
3
2
L3
L2
L1
L0
L3
L2
L1
L0
Byte 0
  • RGBA3320 8-bit
表 491 RGBA3320 8-bit
Pixel 0
7
6
5
4
3
2
R2
R1
R0
G2
G1
G0
B1
B0
Byte 0
  • BGR24 24-bit
表 492 BGR24 24-bit
Pixel 0
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
R7
R6
R5
R4
R3
R2
R1
R0
G7
G6
G5
G4
G3
G2
G1
G0
B7
B6
B5
B4
B3
B2
B1
B0
Byte 2
Byte 1
Byte 0
  • RGB24 24-bit
表 493 RGB24 24-bit
Pixel 0
23
22
21
20
19
18
17
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
B7
B6
B5
B4
B3
B2
B1
B0
G7
G6
G5
G4
G3
G2
G1
G0
R7
R6
R5
R4
R3
R2
R1
R0
Byte 2
Byte 1
Byte 0
Color Expansion
The internal format is always on RGBA8888 32-bit format. Therefore, lower-order color formats are expanded to 8 bits per color channel. This is achieved by high-order bit replication. For example, a 5-bit color format is constructed as follows:
C 7 : 0 = C 4 : 0   ;  C 4 : 2
Instruction Set Architecture
The microarchitecture of the GPU for fragment processing is a four-issue VLIW core. Each VLIW instruction is 64 bits’ long and consists of four sub-instructions (corresponding to sub-operations). The sub-operations for the GPU are: i) instructions for Alpha channel arithmetic operations (SUBOP0); ii) instructions for RGB vector arithmetic operations (SUBOP1); iii) memory addressing instructions for reading and writing to memory (SUBOP2); and iv) branching instructions based on comparisons between RGB or Alpha values (SUBOP3).
Each VLIW bundle is designed to perform six arithmetic operations per cycle (simultaneously). If more than one VLIW bundle is enabled, the addressing sub-operations (SUBOP2) are issued once for all the enabled bundles while the remaining sub-operations (SUBOP0, SUBOP1, and SUBOP3) are issued once for each VLIW bundle.
TEX0_BASE
  • Name: Base Address Register 0
  • Description: This register specifies the base address of drawing surface 0.
  • Base Address: 0x40028000
  • Offset: 0x0
表 494 Base Address Register 0
31:0
Specifies the base address of drawing surface 0.
TEX0_FSTRIDE
  • Name: Image Stride Register 0
  • Description: This register specifies image 0 mode and stride.
  • Offset: 0x4
表 495 Image Stride Register 0
31
If set for destination texture, color dithering is enabled.
(Applicable to output formats: RGBA5650, RGBA5551, and RGBA4444).
30:24
Specifies the image format.
  • 0x00: RGBX8888
  • 0x01: RGBA8888
  • 0x02: XRGB8888
  • 0x03: ARGB8888
  • 0x04: RGBA5650
  • 0x05: RGBA555
  • 0x06: RGBA44441
  • 0x08: RGBA0008 (only available as input format)
  • 0x09: L8
  • 0x0B: L1 (only available as input format)
  • 0x0C: A1 (only available as input format)
  • 0x0D: UYVY (only available as input format)
  • 0x0E: ABGR8888 (only available as input format)
  • 0x10: BGRA (only available as input format)
  • 0x11: BGRX (only available as input format)
  • 0x12: TSC4
  • 0x16: TSC6
  • 0x17: TSC6A
  • 0x27: A1LE (only available as input format)
  • 0x28: A2LE (only available as input format)
  • 0x29: A4LE (only available as input format)
  • 0x2A: L1LE (only available as input format)
  • 0x2B: L2LE (only available as input format)
  • 0x2C: L4LE (only available as input format)
  • 0x30: A2 (only available as input format)
  • 0x31: L2 (only available as input format)
  • 0x34: A4 (only available as input format)
  • 0x35: L4 (only available as input format)
  • 0x38: RGBA3320 (only available as input format)
  • 0x39: BGR24
  • 0x3C: RGB24
23:16
Specifies the image mode.
  • 0x00: Point sampling
  • 0x01: Bilinear filtering
15:0
Specifies the image stride distance in bytes from one scanline to another (signed).
TEX0_RESXY
  • Name: Image Size Register 0
  • Description: This register specifies the size of image 0 resolution.
  • Offset: 0x8
表 496 Image Size Register 0
31:16
Specifies the size of resolution Y.
15:0
Specifies the size of resolution X.
TEX1_BASE
  • Name: Base Address Register 1
  • Description: This register specifies the base address of drawing surface 1.
  • Offset: 0x10
表 497 Base Address Register 1
31:0
Specifies the base address of drawing surface 1.
TEX1_FSTRIDE
  • Name: Image Stride Register 1
  • Description: This register specifies image 1 mode and stride.
  • Offset: 0x14
表 498 Image Stride Register 1
31
If set for destination texture, enables color dithering.
30:24
  • 0x00: RGBX8888
  • 0x01: RGBA8888
  • 0x02: XRGB8888
  • 0x03: ARGB8888
  • 0x04: RGBA5650
  • 0x05: RGBA5551
  • 0x06: RGBA4444
  • 0x09: L8
  • 0x12: TSC4
  • 0x16: TSC6
  • 0x17: TSC6A
  • 0x39: BGR24
  • 0x3C: RGB24
23:16
15:0
TEX1_RESXY
  • Name: Image Size Register 1
  • Description: This register specifies the size of image 1 resolution.
  • Offset: 0x18
表 499 Image Size Register 1
31:16
15:0
TEX_COLOR
  • Name: Color Register
  • Description: This register specifies texture map’s default color.
  • Offset: 0x1C
表 500 Color Register
31:24
Specifies the Alpha (A) value.
23:16
Specifies the Blue (B) value.
15:8
Specifies the Green (G) value.
7:0
Specifies the Red (R) value.
TEX2_BASE
  • Name: Base Address Register 2
  • Description: This register specifies the base address of drawing surface 2.
  • Offset: 0x20
表 501 Base Address Register 2
31:0
Specifies the base address of drawing surface 2.
TEX2_FSTRIDE
  • Name: Image Stride Register 2
  • Description: This register specifies image 2 mode and stride.
  • Offset: 0x24
表 502 Image Stride Register 2
31
30:24
  • 0x00: RGBX8888
  • 0x01: RGBA8888
  • 0x02: XRGB8888
  • 0x03: ARGB8888
  • 0x04: RGBA5650
  • 0x05: RGBA5551
  • 0x06: RGBA4444
  • 0x09: L8
  • 0x12: TSC4
  • 0x16: TSC6
  • 0x17: TSC6A
  • 0x39: BGR24
  • 0x3C: RGB24
23:16
15:0
TEX2_RESXY
  • Name: Image Size Register 2
  • Description: This register specifies the size of image 2 resolution.
  • Offset: 0x28
表 503 Image Size Register 2
31:16
15:0
TEX3_BASE
  • Name: Base Address Register 3
  • Description: This register specifies the base address of drawing surface 3.
  • Offset: 0x30
表 504 Base Address Register 3
31:0
Specifies the base address of drawing surface 3.
TEX3_FSTRIDE
  • Name: Image Stride Register 3
  • Description: This register specifies image 3 mode and stride.
  • Offset: 0x34
表 505 Image Stride Register 3
31
30:24
  • 0x00: RGBX8888
  • 0x01: RGBA8888
  • 0x02: XRGB8888
  • 0x03: ARGB8888
  • 0x04: RGBA5650
  • 0x05: RGBA5551
  • 0x06: RGBA4444
  • 0x09: L8
  • 0x12: TSC4
  • 0x16: TSC6
  • 0x17: TSC6A
  • 0x39: BGR24
  • 0x3C: RGB24
23:16
15:0
TEX3_RESXY
  • Name: Image Size Register 3
  • Description: This register specifies the size of image 3 resolution.
  • Offset: 0x38
表 506 Image Size Register 3
31:16
15:0
BREAKPOINT
  • Name: Break Point Register
  • Description: This register specifies the break point.
  • Offset: 0x80
表 507 Break Point Register
31:0
BREAKPOINT_MASK
  • Name: Break Point Mask Register
  • Description: This register specifies the break point mask.
  • Offset: 0x8C
表 508 Break Point Mask Register
31:0
CG_CTRL
  • Name: Clock Gating Control Register
  • Description: This register controls the clock gating.
  • Offset: 0x94
表 509 Clock Gating Control Register
31
Disable clock gating for all modules.
30:28
27
Disable clock gating for Core 0 Instruction Memory.
26:24
23
Disable clock gating for Core 0.
22:20
19
Disable clock gating for Core 0 Scheduler.
18:16
15
Disable clock gating for Core 0 Register File.
14:12
11
Disable clock gating for Core 0 Pipeline.
10:8
7
Disable clock gating for the BusInterface (memory system).
6:4
3
Disable clock gating for the Render Output Unit of Core 0.
2
Reserved bit
Disable clock gating for the NemaP Configuration Register File.
Disable clock gating for the Command List Processor.
DIRTYMIN
  • Name: Dirty Region Min Register
  • Description: This register reads the Dirty_Min value and resets dirty region to resolution size on write function.
  • Offset: 0x98
  • Reset Value: 0xFFFFFFFF
表 510 Dirty Region Min Register
31:0
0xFFFFFFFF
Write any value to reset dirty region to resolution size.
Read the Dirty_Min value.
DIRTYMAX
  • Name: Dirty Region Max Register
  • Description: This register reads the Dirty_Max value.
  • Offset: 0x9C
表 511 Dirty Region Max Register
31:0
Read the Dirty_Max value.
IMEM_ADDR
  • Name: Load Shader Instruction Memory Address Register
  • Description: This register specifies the load shader instruction memory address.
  • Offset: 0xC4
表 512 Load Shader Instruction Memory Address Register
31:4
3:0
Specifies the load shader instruction memory address.
IMEM_DATA_LOW
  • Name: Lower Bit Data Register
  • Description: This register specifies the lower bits (31: 0) of the 64-bit load shader instruction memory data.
  • Offset: 0xC8
表 513 Lower Bit Data Register
31:0
Specifies the lower bits (31:0) of the load shader instruction memory data.
IMEM_DATA_HIGH
  • Name: Higher Bit Data Register
  • Description: This register specifies the higher bits (63-32) of the 64-bit load shader instruction memory data.
  • Offset: 0xCC
表 514 Higher Bit Data Register
31:0
Specifies the higher bits (63-32) of the load shader instruction memory data.
FLUSH_CTRL
  • Name: System Flush Register
  • Description: This register controls the system flush.
  • Offset: 0xE4
  • Reset Value: 0x00000007
表 515 System Flush Register
31:14
13
When set to 1, the write caches are flushed.
12
Reserved bit
11
If set to 1, the write caches are flushed when the host triggers the rasterizer register (NEMA_DRAW_CMD_NOHOLD).
10:8
7
If set to 1, the write caches are flushed when the Command List Processor triggers the rasterizer register (NEMA_DRAW_CMD_NOHOLD).
6
When set to 1, the read caches are flushed.
5
Reserved bit
4
If set to 1, the read caches are flushed when the host triggers the rasterizer register (NEMA_DRAW_CMD_NOHOLD)
3:1
0x1
If set to 1, the read caches are flushed when the Command List Processor triggers the rasterizer register (NEMA_DRAW_CMD_NOHOLD).
CMD_STAT
  • Name: Command Status Register
  • Description: This register shows the command status.
  • Offset: 0xE8
表 516 Command Status Register
31
Indicates if the Command List Processor is busy.
30
Indicates if there are data available in System Memory.
29
Indicates if there are available data to read from FIFO.
28
Shows many cells are still available in FIFO.
27:18
17:13
12
Reserved bit
11:9
Shows the address of the stack pointer.
8:7
6:4
Indicates the state of CMDList internal FSM.
3:1
Indicates the state of the FSM responsible for fetching.
RING_BUF_STORE
  • Name: Ring Buffer Register
  • Description: This register stores the Ring Buffer’s last written address.
  • Offset: 0xEC
表 517 Ring Buffer Register
31:0
Stores the last written address of the ring buffer.
CMD_ADDR
  • Name: Command List Base Address Register
  • Description: This register specifies the command list base address.
  • Offset: 0xF0
表 518 Command List Base Address Register
31:0
Specifies the base address of every new command list ready to be executed.
CMD_SIZE
  • Name: Command List Size Register
  • Description: This register specifies the command list size.
  • Offset: 0xF4
表 519 Command List Size Register
31:0
Specifies the length of the command list ready to be executed.
INT_CTRL
  • Name: Interrupt Control Register
  • Description: This register controls the interrupt.
  • Offset: 0xF8
表 520 Interrupt Control Register
31:30
Specifies the core_clk_dvfs output.
29:28
27
When set to 1, the throttle signal will be ignored.
26:4
3
When set to 1, the interrupt in the NEMA_IRQ_ID register is cleared.
2
When set to 1, an interrupt is signaled at the end of a drawing command.
When set to 1, an interrupt is signaled at the end of a command list.
  • 1: IRQ signal is active low.
  • 0: IRQ signal is active high.
STAT
  • Name: GPU Status Register
  • Description: This register shows the GPU status.
  • Offset: 0xFC
表 521 GPU Status Register
31
Indicates if the system is busy.
30
Indicates if the bus interface unit is busy.
29
Indicates if the command list bus is busy.
28
27:24
Indicate if the rasterizer unit is busy.
23:13
12
Indicates if the Core 0 render output unit is busy.
11:9
8
Indicates if the Core 0 texture map unit is busy.
7:5
4
Indicates if the Core 0 graphics pipeline is busy.
3:1
Indicates if the Core 0 is busy.
DRAW_CMD_NOHOLD
  • Name: Rasterizer Command Register
  • Description: This register controls the rasterizer.
  • Offset: 0x100
表 522 Rasterizer Command Register
31
Reserved bit
30
When set to 1, tile mode is enabled.
29
When set to 1, positive culling (counter-clockwise) is enabled.
28
When set to 1, negative culling (clockwise) is enabled.
27
When set to 1, color gradient is enabled.
26
When set to 1, antialiasing feature is enabled for edge 0.
25
When set to 1, antialiasing feature is enabled for edge 1.
24
When set to 1, antialiasing feature is enabled for edge 2.
23
When set to 1, antialiasing feature is enabled for edge 3.
22:3
2:0
Draw commands:
  • 0x00: Draw pixels.
  • 0x01: Draw lines.
  • 0x02: Draw rectangles.
  • 0x03: Draw triangles.
  • 0x04: Draw quadrilaterals.
DRAW_STARTXY
  • Name: Draw Start XY Register
  • Description: This register specifies the start XY of drawing.
  • Offset: 0x104
表 523 Draw Start XY Register
31:16
Specifies the Y coordinate (integer value) of vertex 0.
15:0
Specifies the X coordinate (integer value) of vertex 0.
DRAW_ENDXY
  • Name: Draw End XY Register
  • Description: This register specifies the end XY of drawing.
  • Offset: 0x108
表 524 Draw End XY Register
31:16
Specifies the Y coordinate (integer value) of vertex 1.
15:0
Specifies the X coordinate (integer value) of vertex 1.
CLIPMIN
  • Name: Clip Min Register
  • Description: This register specifies clipping rectangle upper left vertex.
  • Offset: 0x110
表 525 Clip Min Register
31:16
Defines the upper left Y coordinate.
15:0
Defines the upper left X coordinate.
CLIPMAX
  • Name: Clip Max Register
  • Description: This register specifies clipping rectangle bottom right vertex.
  • Offset: 0x114
表 526 Clip Max Register
31:16
Defines the bottom right Y coordinate.
15:0
Defines the bottom right X coordinate.
MAT_MCL
  • Name: Matrix Multiplication Control Register
  • Description: This register controls the rasterizer matrix multiplication.
  • Offset: 0x118
表 527 Matrix Multiplication Control Register
31:30
29
When set to 1, the 0.5 value is added to the X and Y coordinates.
28
When set to 1, the matrix multiplications are bypassed.
27
When set to 0, the result is in fixed point value (default).
26
When set to 1, the result is in floating point value.
25:0
CODEPTR
  • Name: Shader Code Register
  • Description: This register specifies the pointer of the shader code.
  • Offset: 0x11C
表 528 Shader Code Register
31:16
Specifies the pointer for the instruction that will be executed for the background pixels.
15:0
Specifies the pointer for the instruction that will be executed for the foreground pixels.
DRAW_PT0_X
  • Name: Vertex 0 Draw X Register
  • Description: This register specifies the X coordinate of vertex 0 drawing primitive.
  • Offset: 0x120
表 529 Vertex 0 Draw X Register
31:0
Specifies the X coordinate of vertex 0 drawing primitive (16.16 fixed point).
DRAW_PT0_Y
  • Name: Vertex 0 Draw Y Register
  • Description: This register specifies the Y coordinate of vertex 0 drawing primitive.
  • Offset: 0x124
表 530 Vertex 0 Draw Y Register
31:0
Specifies the Y coordinate of vertex 0 drawing primitive (16.16 fixed point).
DRAW_COLOR
  • Name: Drawing Color Register
  • Description: This register specifies the drawing color for filling primitives.
  • Offset: 0x12C
表 531 Drawing Color Register
31:0
Specifies the drawing color for filling primitives.
DRAW_PT1_X
  • Name: Vertex 1 Draw X Register
  • Description: This register specifies the X coordinate of vertex 1 drawing primitive.
  • Offset: 0x130
表 532 Vertex 1 Draw X Register
31:0
Specifies the X coordinate of vertex 1 drawing primitive (16.16 fixed point).
DRAW_PT1_Y
  • Name: Vertex 1 Draw Y Register
  • Description: This register specifies the Y coordinate of vertex 1 drawing primitive.
  • Offset: 0x134
表 533 Vertex 1 Draw Y Register
31:0
Specifies the Y coordinate of vertex 1 drawing primitive (16.16 fixed point).
BYPASS_ADDR
  • Name: Bypass Address Register
  • Description: This register shows the address of bypass mode of rasterizer setup access.
  • Offset: 0x138
表 534 Bypass Address Register
31:0
Sets the address of bypass mode of rasterizer setup access.
BYPASS_DATA
  • Name: Bypass Data Register
  • Description: This register shows the data and enablement of bypass mode of rasterizer.
  • Offset: 0x13C
表 535 Bypass Data Register
31:0
Shows data and enablement of bypass mode of rasterizer.
DRAW_PT2_X
  • Name: Vertex 2 Draw X Register
  • Description: This register specifies the X coordinate of vertex 2 drawing primitive.
  • Offset: 0x140
表 536 Vertex 2 Draw X Register
31:0
Specifies the X coordinate of vertex 2 drawing primitive (16.16 fixed point).
DRAW_PT2_Y
  • Name: Vertex 2 Draw Y Register
  • Description: This register specifies the Y coordinate of vertex 2 drawing primitive.
  • Offset: 0x144
表 537 Vertex 2 Draw Y Register
31:0
Specifies the Y coordinate of vertex 2 drawing primitive (16.16 fixed point).
CMD_LIST_ID
  • Name: Command List ID Register
  • Description: This register specifies the last executed command list.
  • Offset: 0x148
表 538 Command List ID Register
31:0
Specifies the last executed command list.
DRAW_PT3_X
  • Name: Vertex 3 Draw X Register
  • Description: This register specifies the X coordinate of vertex 3 drawing primitive.
  • Offset: 0x150
表 539 Vertex 3 Draw X Register
31:0
Specifies the X coordinate of vertex 3 drawing primitive (16.16 fixed point).
DRAW_PT3_Y
  • Name: Vertex 3 Draw Y Register
  • Description: This register specifies the Y coordinate of vertex 3 drawing primitive.
  • Offset: 0x154
表 540 Vertex 3 Draw Y Register
31:0
Specifies the Y coordinate of vertex 3 drawing primitive (16.16 fixed point).
CLIPMIN1
  • Name: Clip Min Register 1
  • Description: This register specifies the second clipping rectangle upper left vertex.
  • Offset: 0x158
表 541 Clip Min Register 1
31:16
15:0
CLIPMAX1
  • Name: Clip Max Register 1
  • Description: This register specifies the second clipping rectangle bottom right vertex.
  • Offset: 0x15C
  • Reset Value: 0x7FFF7FFF
表 542 Clip Max Register 1
31:16
0x7FFF
15:0
0x7FFF
MM00
  • Name: (0,0) Matrix Register
  • Description: This register specifies the (0,0) matrix floating point element.
  • Offset: 0x160
表 543 (0,0) Matrix Register
31:21
20:0
Specifies the (0,0) element.
MM01
  • Name: (0,1) Matrix Register
  • Description: This register specifies the (0,1) matrix floating point element.
  • Offset: 0x164
表 544 (0,1) Matrix Register
31:21
20:0
Specifies the (0,1) element.
MM02
  • Name: (0,2) Matrix Register
  • Description: This register specifies the (0,2) matrix floating point element.
  • Offset: 0x168
表 545 (0,2) Matrix Register
31:21
20:0
Specifies the (0,2) element.
MM10
  • Name: (1,0) Matrix Register
  • Description: This register specifies the (1,0) matrix floating point element.
  • Offset: 0x16C
表 546 (1,0) Matrix Register
31:21
20:0
Specifies the (1,0) element.
MM11
  • Name: (1,1) Matrix Register
  • Description: This register specifies the (1,1) matrix floating point element.
  • Offset: 0x170
表 547 (1,1) Matrix Register
31:21
20:0
Specifies the (1,1) element.
MM12
  • Name: (1,2) Matrix Register
  • Description: This register specifies the (1,2) matrix floating point element.
  • Offset: 0x174
表 548 (1,2) Matrix Register
31:21
20:0
Specifies the (1,2) element.
MM20
  • Name: (2,0) Matrix Register
  • Description: This register specifies the (2,0) matrix floating point element.
  • Offset: 0x178
表 549 (2,0) Matrix Register
31:21
20:0
Specifies the (2,0) element.
MM21
  • Name: (2,1) Matrix Register
  • Description: This register specifies the (2,1) matrix floating point element.
  • Offset: 0x17C
表 550 (2,1) Matrix Register
31:21
20:0
Specifies the (2,1) element.
MM22
  • Name: (2,2) Matrix Register
  • Description: This register specifies the (2,2) matrix floating point element.
  • Offset: 0x180
表 551 (2,2) Matrix Register
31:21
20:0
Specifies the (2,2) element.
DEPTH_START_L
  • Name: Integral Depth Value Low Register
  • Description: This register specifies the integral part of lower 32-bit depth value of the STARTXY pixel.
  • Offset: 0x184
表 552 Integral Depth Value Low Register
31:0
Specifies the integral part of the depth value of the STARTXY pixel.
DEPTH_START_H
  • Name: Integral Depth Value High Register
  • Description: This register specifies the integral part of higher 32-bit depth value of the STARTXY pixel.
  • Offset: 0x188
表 553 Integral Depth Value High Register
31:0
Specifies the integral value of the depth value of the STARTXY pixel.
DEPTH_DX_L
  • Name: Fractional X Depth Value Low Register
  • Description: This register specifies the fractional part of lower 32-bit depth value for each step at X axis.
  • Offset: 0x18C
表 554 Fractional X Depth Value Low Register
31:0
Specifies the fractional part of the added depth value for each step at X axis.
DEPTH_DX_H
  • Name: Integral X Depth Value High Register
  • Description: This register specifies the integral part of higher 32-bit depth value for each step at X axis.
  • Offset: 0x190
表 555 Integral X Depth Value High Register
31:0
Specifies the integral part of the added depth value for each step at X axis.
DEPTH_DY_L
  • Name: Fractional Y Depth Value Low Register
  • Description: This register specifies the fractional part of lower 32-bit depth value for each step at Y axis.
  • Offset: 0x194
表 556 Fractional Y Depth Value Low Register
31:0
Specifies the fractional part of the added depth value for each step at Y axis.
DEPTH_DY_H
  • Name: Integral Y Depth Value High Register
  • Description: This register specifies the integral part of higher 32-bit depth value for each step at Y axis.
  • Offset: 0x198
表 557 Integral Y Depth Value High Register
31:0
Specifies the integral part of the added depth value for each step at Y axis.
RED_DX
  • Name: Red (R) Value X Register
  • Description: This register specifies the added Red (R) value for each step at X axis.
  • Offset: 0x1A0
表 558 Red (R) Value X Register
31:0
Specifies the added Red (R) value for each step at X axis.
RED_DY
  • Name: Red (R) Value Y Register
  • Description: This register specifies the added Red (R) value for each step at Y axis.
  • Offset: 0x1A4
表 559 Red (R) Value Y Register
31:0
Specifies the added Red (R) value for each step at Y axis.
GRE_DX
  • Name: Green (G) Value X Register
  • Description: This register specifies the added Green (G) value for each step at X axis.
  • Offset: 0x1A8
表 560 Green (G) Value X Register
31:0
Specifies the added Green (G) value for each step at X axis.
GRE_DY
  • Name: Green (G) Value Y Register
  • Description: This register specifies the added Green (G) value for each step at Y axis.
  • Offset: 0x1AC
表 561 Green (G) Value Y Register
31:0
Specifies the added Green (G) value for each step at Y axis.
BLU_DX
  • Name: Blue (B) Value X Register
  • Description: This register specifies the added Blue (B) value for each step at X axis.
  • Offset: 0x1B0
表 562 Blue (B) Value X Register
31:0
Specifies the added Blue (B) value for each step at X axis.
BLU_DY
  • Name: Blue (B) Value Y Register
  • Description: This register specifies the added Blue (B) value for each step at Y axis.
  • Offset: 0x1B4
表 563 Blue (B) Value Y Register
31:0
Specifies the added Blue (B) value for each step at Y axis.
ALF_DX
  • Name: Alpha (A) Value X Register
  • Description: This register specifies the added Alpha (A) value for each step at X axis.
  • Offset: 0x1B8
表 564 Alpha (A) Value X Register
31:0
Specifies the added Alpha (A) value for each step at X axis.
ALF_DY
  • Name: Alpha (A) Value Y Register
  • Description: This register specifies the added Alpha (A) value for each step at Y axis.
  • Offset: 0x1BC
表 565 Alpha (A) Value Y Register
31:0
Specifies the added Alpha (A) value for each step at Y axis.
RED_INIT
  • Name: Red (R) Value Init Register
  • Description: This register specifies the Red (R) value of the STARTXY pixel.
  • Offset: 0x1C0
表 566 Red (R) Value Init Register
31:0
Specifies the Red (R) value of the STARTXY pixel.
GRE_INIT
  • Name: Green (G) Value Init Register
  • Description: This register specifies the Green (G) value of the STARTXY pixel.
  • Offset: 0x1C4
表 567 Green (G) Value Init Register
31:0
Specifies the Green (G) value of the STARTXY pixel.
BLU_INIT
  • Name: Blue (B) Value Init Register
  • Description: This register specifies the Blue (B) value of the STARTXY pixel.
  • Offset: 0x1C8
表 568 Blue (B) Value Init Register
31:0
Specifies the Blue (B) value of the STARTXY pixel.
ALF_INIT
  • Name: Alpha (A) Value Init Register
  • Description: This register specifies the Alpha (A) value of the STARTXY pixel.
  • Offset: 0x1CC
表 569 Alpha (A) Value Init Register
31:0
Specifies the Alpha (A) value of the STARTXY pixel.
ROPBLENDER_BLEND_MODE
  • Name: Blending Mode Register
  • Description: This register specifies the blending modes for different calculations between the source (Fragment Processing Core) and destination (Framebuffer) colors.
  • Offset: 0x1D0
表 570 Blending Mode Register
31
If set, destination color keying is enabled.
30
If set, source color keying is enabled.
29:26
25
If set, negative destination color keying is enabled.
24:12
11:8
Indicates the blending mode of the stored pixel in the Framebuffer (destination pixel).
7:4
3:0
Indicates the blending mode of the current pixel (source pixel).
ROPBLENDER_DST_CKEY
  • Name: Destination Color Register
  • Description: This register specifies the destination color value.
  • Offset: 0x1D4
表 571 Destination Color Register
31:24
23:16
15:8
7:0
ROPBLENDER_CONST_COLOR
  • Name: Constant Color Register
  • Description: This register specifies the constant color value.
  • Offset: 0x1D8
表 572 Constant Color Register
31:24
23:16
15:8
7:0
IP_VERSION
  • Name: GPU Version Register
  • Description: This register shows the current version of the GPU.
  • Offset: 0x1DC
表 573 GPU Version Register
31:0
Indicates the current version of the GPU.
IDREG
  • Name: GPU ID Register
  • Description: This register shows the GPU ID (fixed value).
  • Offset: 0x1EC
  • Reset Value: 0x86362000
表 574 GPU ID Register
31:0
0x86362000
Indicates that the fixed value is 0x86362000.
CFG
  • Name: GPU Configuration Register
  • Description: This register shows the GPU configuration status.
  • Offset: 0x1F0
  • Reset Value: 0x74030105
表 575 GPU Configuration Register
31
Being set to 1 indicates that the master bus is AXI.
Being set to 0 indicates that the master bus is AHB.
30
0x1
Being set to 1 indicates that Bilinear filtering is enabled.
29
0x1
Being set to 1 indicates that TSC6 compression mode is enabled.
28
0x1
Being set to 1 indicates that H/W Blender is enabled.
27
When set to 1, bus to memory is asynchronous to core clock.
26
0x1
When set to 1, dirty region is enabled.
25:18
17
0x1
When set to 1, TSC4 compression mode is enabled.
16
0x1
When set to 1, clock gating is enabled.
15:12
11:8
0x1
Indicates the number of cores.
7:0
0x5
Indicates the log2 number of threads.
CFG_H
  • Name: GPU Configuration (High Bits) Register
  • Description: This register shows the GPU configuration status (high bits).
  • Offset: 0x1F4
  • Reset Value: 0x000000E3
表 576 GPU Configuration (High Bits) Register
31:8
7
0x1
Indicates that external debug interface (GP_FLAG/SYSERROR_IRQ/FREEZE) is enabled.
6
0x1
Indicates that separate logic/mem clock gating is enabled.
5
0x1
Indicates that texture map unit has two channels.
4
Indicates that YUV coefficients are present.
3
Indicates that Gamma Correction is enabled.
2
Indicates that 10-bit precision is selected.
0x1
Indicates that the TSC Framebuffer/Texture Decompression is enabled.
0x1
Indicates that the antialiasing feature is enabled.
C0_REG
  • Name: Reg0 RGBA Value Register
  • Description: This register specifies the RGBA value stored in constant register 0 for fragment calculations.
  • Offset: 0x200
表 577 Reg0 RGBA Value Register
31:24
W
23:16
W
15:8
W
7:0
W
C1_REG
  • Name: Reg1 RGBA Value Register
  • Description: This register specifies the RGBA value stored in constant register 1 for fragment calculations.
  • Offset: 0x204
表 578 Reg1 RGBA Value Register
31:24
W
23:16
W
15:8
W
7:0
W
C2_REG
  • Name: Reg2 RGBA Value Register
  • Description: This register specifies the RGBA value stored in constant register 2 for fragment calculations.
  • Offset: 0x208
表 579 Reg2 RGBA Value Register
31:24
W
23:16
W
15:8
W
7:0
W
C3_REG
  • Name: Reg3 RGBA Value Register
  • Description: This register specifies the RGBA value stored in constant register 3 for fragment calculations.
  • Offset: 0x20C
表 580 Reg3 RGBA Value Register
31:24
W
23:16
W
15:8
W
7:0
W
COORD_MASK
  • Name: Inverted Mask Register
  • Description: This register specifies the inverted mask for rasterizer coordinates.
  • Offset: 0x4D0
  • Reset Value: 0x00000FFF
表 581 Inverted Mask Register
31:0
0xFFF
Specifies the inverted mask for rasterizer coordinates.
IRQ_ID
  • Name: Interrupt Signal Register
  • Description: This register signals an interrupt.
  • Offset: 0xFF0
表 582 Interrupt Signal Register
31:0
Writes any value to signal an interrupt.
GP_FLAGS
  • Name: Stop/Break Register
  • Description: This register stops/breaks the command list when debugging.
  • Offset: 0xFF4
表 583 Stop/Break Register
31:20
19
When set to 1, set breakpoint for GP_FLAG line 0 if NEMA_GP_FLAGS[3] bit value is high.
18
When set to 1, set breakpoint for GP_FLAG line 0 if NEMA_GP_FLAGS[2] bit value is high.
17
When set to 1, set breakpoint for GP_FLAG line 0 if NEMA_GP_FLAGS[1] bit value is high.
16
When set to 1, set breakpoint for GP_FLAG line 0 if NEMA_GP_FLAGS[0] bit value is high.
15:12
11
GP_FLAG_irqmask when set to 1 masks/enables the generation of the IRQ_SYSERROR from line 3.
10
GP_FLAG_irqmask when set to 1 masks/enables the generation of the IRQ_SYSERROR from line 2.
9
GP_FLAG_irqmask when set to 1 masks/enables the generation of the IRQ_SYSERROR from line 1.
8
GP_FLAG_irqmask when set to 1 masks/enables the generation of the IRQ_SYSERROR from line 0.
7
GP_FLAG_mask when set to 1 masks/enables the generation of the output FREEZE signal from line 3.
6
GP_FLAG_mask when set to 1 masks/enables the generation of the output FREEZE signal from line 2.
5
GP_FLAG_mask when set to 1 masks/enables the generation of the output FREEZE signal from line 1.
4
GP_FLAG_mask when set to 1 masks/enables the generation of the output FREEZE signal from line 0.
3
GP_FLAG line 3
2
GP_FLAG line 2
GP_FLAG line 1
GP_FLAG line 0
SYS_INT
  • Name: System Interrupt Register
  • Description: This register indicates the type of the system interrupt.
  • Offset: 0xFF8
表 584 System Interrupt Register
31:12
11
Indicates that a bus error has occurred.
10:7
Indicates the bus error code interface.
  • 1000: AHB/AXI slave port
  • 0100: AHB/AXI M0 master port
  • 0010: AHB/AXI M1 master port
  • 0001: AXI CL master port
6:5
Indicates the bus error code occurrence direction (AXI only).
  • 01: Read direction
  • 10: Write direction
4
Indicates the interface error code (AXI only).
  • 0: SLVERR
  • 1: DECERR
3
Indicates that IRQ_SYSERROR occurs due to GP_FLAG line 3.
2
Indicates that IRQ_SYSERROR occurs due to GP_FLAG line 2.
Indicates that IRQ_SYSERROR occurs due to GP_FLAG line 1.
Indicates that IRQ_SYSERROR occurs due to GP_FLAG line 0.
BUSERROR_MASK
  • Name: Buserror Interrupt Mask Register
  • Description: This register sets the mask for the Buserror Interrupt.
  • Offset: 0xFFC
表 585 Buserror Interrupt Mask Register
31:7
6:3
Sets the mask for the bus error code interface.
2:1
Sets the mask for the bus error code occurrence direction (AXI only).
Reserved bit
