Features
- Bluetooth
LE
5.3
transceiver
- AoA and AoD direction finding
- TX power: –20 dBm to +7 dBm
- RX
sensitivity
- –97 dBm sensitivity @ 1 Mbps mode
- –93 dBm sensitivity @ 2 Mbps mode
- –101 dBm sensitivity @ Long Range 500 kbps mode
- –103 dBm sensitivity @ Long Range 125 kbps mode
- Power
consumption at 3.3 V VBAT input:
- 6.3 mA TX current @ 0 dBm output power (64 MHz system clock)
- 5.3 mA RX current @ 1 Mbps (64 MHz system clock)
- Arm®
Cortex®-M4F 32-bit micro-processor with floating point support
- Up to 96 MHz clock frequency
- 56 µA/MHz CoreMark running from Flash @ 3.3 V, 64 MHz from HFXO
- On-chip memory
- 256 KB RAM data memory with retention capabilities
- 8 KB cache RAM instruction memory with retention capabilities
- Stack ROM (including boot ROM and Bluetooth LE Stack)
- 1 MB internal QSPI Flash (512 KB for GR5525IENI, and external Flash for GR5525I0NI)
- Digital peripherals
- 2 x general-purpose DMA engines with six channels and up to 16 programmable request/trigger sources
- Analog peripherals
- 1 x 13-bit Sense ADC with sampling rate of 1 Msps, supporting up to eight external I/O channels and three internal signal channels
- Flexible serial
peripherals
- 4 x UART modules up to 2 Mbps with flow control and IrDA features
- 4 x I2C modules for peripheral communication, up to 3.4 MHz, operating as either Master or Slave
- 2 x I2S interfaces (1 x I2S master interface and 1 x I2S slave interface)
- PDM interface with hardware sampling rate converter
- 1 x Dual-lane SPI (DSPI) interface for display, with MIPI DBI Type-C support
- 3 x Quad SPI (QSPI) interfaces, up to 48 MHz; supporting direct access via memory mapping when connecting with external NOR Flash
- Security
- Complete secure
computing engine:
- AES 128-bit/192-bit/256-bit symmetric encryption (ECB, CBC)
- Hash-based Message Authentication Code (HMAC-SHA256)
- Public key cryptography (PKC)
- Comprehensive
security operation mechanism:
- Secure boot
- Encrypted firmware running directly from Flash
- Complete secure
computing engine:
- I/O
peripherals
- Up to
50
multiplexed
I/O pins in total
- Up to 34 general-purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors
- Up to eight always-on I/O (AON I/O) pins, supporting wakeup from sleep mode
- Up to eight mixed signal I/O (MSIO) pins, configurable to be digital/analog signal interfaces
- Up to
50
multiplexed
I/O pins in total
- Timers
- 2 x 3-channel PWMs with edge-aligned and center-aligned modes
- 2 x real-time counters (1 x Calendar, 1 x real-time counter)
- Power management
- On-chip DC-DC to provide RF analog voltage and supply core LDO
- Supply voltage: 2.4 V–3.8 V
- I/O voltage: 1.8 V–3.6 V
- Low-power consumption
- Sleep mode: 7.3 µA (Typical) at 3.3 V VBAT input, wakeup sources from always-on domain, and LFXO_32K running
- Ultra deep sleep mode: 5.0 µA (Typical), with no memory data in retention and wakeup sources from SLP Timer or AON I/Os
Operating temperature range: –40°C to +85°C
- Packages
- QFN68: 7.0 x 7.0 x 0.85 mm, 0.35 mm pitch
- QFN56: 7.0 x 7.0 x 0.75 mm, 0.4 mm pitch
