Timer
The device has two instances of Timer module that is a 32-bit general-purpose timer. Since the Timer is in the MCU Subsystem domain, Timer interrupt is not available during sleep, and the running Timer will not prevent MCU from sleeping. In active mode, when Timer is started again after stopping, it will continue to count down from the stop time. The value of RELOAD register will not take effect until the end of the current cycle.
  • Generate an interrupt when the 32-bit down counter reaches 0.
  • The clock source of the Timer follows the system clock.
  • Each timer module has an independent interrupt entry.
  • Timer pauses when MCU is suspended.
  • The Timer can generate an interrupt request signal when the 32-bit down counter reaches 0. The interrupt request is held until it is cleared by writing 1 to the INTSTAT register.
  • If the Timer count reaches 0 and, at the same time, the software clears a previous interrupt status, the interrupt status is set to 1.
  • When the value of the RELOAD register is configured to 0, no count and no interrupt are generated.
  • The RELOAD value only represents the count-down number of timers. If you want to configure a specific duration (for example, µs, ms, or s), you need to use the following formula:
  • If you need to start counting from the new RELOAD value immediately, you need to deinitialize the Timer first, and then initialize the Timer.
CTRL
  • Name: Timer Control Register
  • Description: The CTRL register enables the software to control the Timer.
  • Base Address: 0x40000000 + x*0x1000
  • Offset: 0x00
  • Reset Value: 0x00
*x is used to identify the Timer Module. The “x” can be 0 or 1.
Table 303 CTRL Register
31:4
3
INT_EN
Timer interrupt enable
  • 0x0: Disable the Timer interrupt.
  • 0x1: Enable the Timer interrupt.
2:1
EN
Timer enable.
  • 0x0: Disable the Timer.
  • 0x1: Enable the Timer.
VALUE
  • Name: Timer Value Register
  • Description: The VALUE register indicates the current value of the decrementing counter.
  • Offset: 0x04
  • Reset Value: 0x00
Table 304 VALUE Register
31:0
CUR_VALUE
0x1
Current value
RELOAD
  • Name: Timer Reload Register
  • Description: When this register is written to, the count value takes effect at the end of the current cycle.
  • Offset: 0x08
  • Reset Value: 0x00
Table 305 RELOAD Register
31:0
RELOAD_VALUE
Sets reload value.
INTSTAT
  • Name: Timer Interrupt Status Register
  • Description: The INTSTAT register indicates the interrupt status from the counter. Writing one to the INTSTAT register clears the timer interrupt.
  • Offset: 0x0C
Table 306 INTSTAT Register
31:1
STAT
Timer interrupt. Write 1 to clear.
