Advanced Encryption Standard (AES)
Advanced Encryption Standard (AES), also known as Rijndael encryption method in cryptography, is a block encryption standard adopted by the U.S. federal government. This standard is used to replace the Data Encryption Standard (DES). The block length of AES is fixed at 128 bits, and the key length can be 128, 192, or 256 bits. The basic processes of AES include SubBytes, ShiftRows, MixColumns, and AddRoundKey.
- Compliance with NIST “Advanced Encryption Standard (AES), FIPS Publication 197” from November 2001
- Supports 128-bit, 192-bit, and 256-bit key.
- Supports encryption mode and decryption mode.
- Supports interrupt and query register to report status.
- Supports Electronic Codebook (ECB) and Cipher Block chaining (CBC) modes.
- Supports MCU and DMA operation.
Standard
| Document Code | Name of Standard |
FIPS PUB 197 |
Advanced Encryption Standard (AES) |
Module Overview
The AES co-processor encrypts or decrypts data, using an algorithm and implementation fully compliant with the AES defined in Federal Information Processing Standards (FIPS) publication 197. The device embeds the AES module in order to realize hardware acceleration of calculation.
Electronic Codebook (ECB) and Cipher Block Chaining (CBC) are supported for key size of 128 bits, 192 bits, and 256 bits.
Due to the feature of block cipher of AES, the data to be encrypted requires an integer multiple of 16 bytes.
The AES co-processor adopts both 32-bit AHB and APB interfaces. It supports DMA transfers for incoming and outgoing data (through a dedicated integrated DMA).
Usage
The CFG register can be used to configure relevant parameters for the AES module. CFG.KEY_MODE can be used to configure the key size to 128 bits, 192 bits, or 256 bits. CFG.DEC_ENC_SEL can be used to configure the encryption or decryption mode. CFG.OPT_MODE can be used to configure the working mode of ECB or CBC. CFG.KEY_TYPE can be used to configure the mode of fetching the key.
If the key is configured by MCU, the KEY0 to KEY7 registers need to be configured (128-bit for KEY0 to KEY3 only and 192-bit for KEY0 to KEY5 only). If the key is fetched through AHB, the KEY_ADDR register should be configured.
CTRL.FKEY_EN is configured in order to enable the AES module to fetch the key through AHB master interface. The STAT register is used to indicate the current status of the AES module. The random seeds are set to the INIT_SSI, INIT_SSO, MASK_SSI, and MASK_SSO registers.
The initialization vector (IV) should be set to the INIT_V0 to INIT_V3 registers for AES CBC mode.
If the AES module is in interrupt or DMA operation mode, the INT register needs to be configured.
In MCU operation mode, a block data (128-bit) is written into the DATA_IN0 to DATA_IN3 registers. In DMA operation mode, the XFER_SIZE, RD_START_ADDR, and WR_START_ADDR registers should be configured. The AES module will read the data from the address which is stored in the RD_START_ADDR register.
The AES module can be started through the CTRL register. The STAT register or the interrupt callback function can judge whether the calculation completes.
The plain data or the encrypted data can be read from the DATA_OUT0 to DATA_OUT3 registers in MCU operation mode. In DMA operation mode, the result has been sent to the address which is stored in the WR_START_ADDR register.
The endian of the data needs to be noticed and configured; otherwise it will affect the result of encryption and decryption. If the data is encrypted and decrypted in batches in CBC mode, the encryption result should be set as the IV to the INIT_V0 to INIT_V3 registers.
CTRL
- Name: AES Controller Register
- Description: This register acts as a global enable/disable for AES.
- Base Address: 0x40015000
- Offset: 0x0
31:4 |
Reserved bits |
3 |
FKEY_EN |
W |
Enable AES fetch key by itself through AHB master interface or key port. This register can be cleared by itself when key_valid is set to 1. |
2 |
DMA_MODE_EN |
DMA mode start enable bit. Start N block data encryption or decryption in DMA mode. |
1 |
MCU_MODE_EN |
MCU mode start enable bit. Start a block data encryption or decryption in DMA mode. This signal should be cleared to zero before a new block input data is ready to start. |
0 |
MODULE_EN |
Enables AES module. Value:
CFG
- Name: AES Configuration Register
- Description: This register acts as a configuration for AES.
- Offset: 0x4
31:13 |
Reserved bits |
12:11 |
KEY_TYPE |
Key type selection for encryption/decryption Value:
10:8 |
OPT_MODE |
Selection for operation mode Value:
7 |
ENDIAN |
Selection for data endian control Value:
6 |
FIRST_BLK |
W |
This register should be set to 1 before starting the first block in normal CBC and DMA CBC modes, and this register will be cleared by itself. |
5 |
LOAD_SEED |
W |
Loads seed for LFSR. Seed for LFSR will be reloaded when this register is written with 1. This register can be cleared by itself. |
4 |
DEC_ENC_SEL |
Selection for encryption/decryption Value:
3 |
FULL_MASK_EN |
Full mask enable signal Value:
2 |
Reserved bit |
1:0 |
KEY_MODE |
Key mode selection for encryption/decryption Value:
STAT
- Name: AES Status Register
- Description: This is a read-only register used to indicate the current status of AES.
- Offset: 0x8
31:4 |
Reserved bits |
3 |
KEY_STAT |
Key status, whether the key is ready to read or not Value:
2 |
DMA_XFE_ERR |
R WC |
DMA transfer error. Write 1 to clear this register. Value:
1 |
DMA_XFE_CPLT |
DMA transfer complete Value:
0 |
READY |
AES result data out ready or not. This signal may be cleared when MCUEN (CTRL[1]) is disabled. Value:
INT
- Name: AES Interrupt Register
- Description: This register enables or disables all interrupts generated by the AES. Additionally, it reports the status of the AES interrupts after they have been enabled.
- Offset: 0x0C
31:2 |
Reserved bits |
1 |
CPLT_INT_EN |
AES result data complete interrupt Value:
0 |
CPLT_INT_FLAG |
R WC |
AES result data complete interrupt flag. Write 1 to clear. Read:
Write:
XFER_SIZE
- Name: AES Transfer Size Register
- Description: This register sets a size for AES DMA mode transfer.
- Offset: 0x10
31:15 |
Reserved bits |
14:0 |
SIZE |
Total transfer size. Up to 32 KB
RD_START_ADDR
- Name: AES Read Start Address Register
- Description: This register acts as a start address for AES DMA reading.
- Offset: 0x14
31:0 |
ADDR |
In DMA mode, sets the read start address of transfer. |
WR_START_ADDR
- Name: AES Write Start Address Register
- Description: This register acts as a start address for AES DMA writing.
- Offset: 0x18
31:0 |
ADDR |
In DMA mode, sets the write start address of transfer. |
KEY_ADDR
- Name: AES Key Address Register
- Description: This register acts as a key address for AES encryption or decryption.
- Offset: 0x1C
31:0 |
ADDR |
Indicates the AES key address in memory. |
DATA_OUT0
- Name: AES Data Output 0 Register
- Description: This register is a 32-bit read-only buffer for the result data[127:96] from AES.
- Offset: 0x20
31:0 |
DATA_OUT0 |
AES result data[127:96] |
DATA_OUT1
- Name: AES Data Output 1 Register
- Description: This register is a 32-bit read-only buffer for the result data[95:64] from AES.
- Offset: 0x24
31:0 |
DATA_OUT1 |
AES result data[95:64] |
DATA_OUT2
- Name: AES Data Output 2 Register
- Description: This register is a 32-bit read-only buffer for the result data[63:32] from AES.
- Offset: 0x28
31:0 |
DATA_OUT2 |
AES result data[63:32] |
DATA_OUT3
- Name: AES Data Output 3 Register
- Description: This register is a 32-bit read-only buffer for the result data[31:0] from AES.
- Offset: 0x2C
31:0 |
DATA_OUT3 |
AES result data[31:0] |
KEY0
- Name: AES Key 0 Register
- Description: This register is a 32-bit write-only buffer for the key data[255:224] for AES.
- Offset: 0x30
31:0 |
KEY0 |
W |
AES key[255:224] |
KEY1
- Name: AES Key 1 Register
- Description: This register is a 32-bit write-only buffer for the key data[223:192] for AES.
- Offset: 0x34
31:0 |
KEY1 |
W |
AES key[223:192] |
KEY2
- Name: AES Key 2 Register
- Description: This register is a 32-bit write-only buffer for the key data[191:160] for AES.
- Offset: 0x38
31:0 |
KEY2 |
W |
AES key[191:160] |
KEY3
- Name: AES Key 3 Register
- Description: This register is a 32-bit write-only buffer for the key data[159:128] for AES.
- Offset: 0x3C
31:0 |
KEY3 |
W |
AES key[159:128] |
KEY4
- Name: AES Key 4 Register
- Description: This register is a 32-bit write-only buffer for the key data[127:96] for AES.
- Offset: 0x40
31:0 |
KEY4 |
W |
AES key[127:96] |
KEY5
- Name: AES Key 5 Register
- Description: This register is a 32-bit write-only buffer for the key data[95:64] for AES.
- Offset: 0x44
31:0 |
KEY5 |
W |
AES key[95:64] |
KEY6
- Name: AES Key 6 Register
- Description: This register is a 32-bit write-only buffer for the key data[63:32] for AES.
- Offset: 0x48
31:0 |
KEY6 |
W |
AES key[63:32] |
KEY7
- Name: AES Key 7 Register
- Description: This register is a 32-bit write-only buffer for the key data[31:0] for AES.
- Offset: 0x4C
31:0 |
KEY7 |
W |
AES key[31:0] |
INIT_SSI
- Name: AES Sbox Initial Seed Input Register
- Description: This register acts as an initial seed input for Sbox.
- Offset: 0x50
31:0 |
SEED |
Sbox initial seed input |
INIT_SSO
- Name: AES Sbox Initial Seed Output Register
- Description: This register acts as an initial seed output for Sbox.
- Offset: 0x54
31:0 |
SEED |
Sbox initial seed output |
MASK_SSI
- Name: AES Sbox Seed Input Mask Register
- Description: This register acts as a mask for Sbox initial seed input mask.
- Offset: 0x58
31:0 |
MASK |
Sbox initial seed input mask |
MASK_SSO
- Name: AES Sbox Seed Output Mask Register
- Description: This register acts as a mask for Sbox initial seed output mask.
- Offset: 0x5C
31:0 |
MASK |
Sbox initial seed output mask |
INIT_V0
- Name: AES Initialization Vector 0 Register
- Description: This register acts as an initialization vector[127:96] for CBC mode.
- Offset: 0x60
31:0 |
VECTOR |
W |
Initialization vector[127:96] for CBC mode |
INIT_V1
- Name: AES Initialization Vector 1 Register
- Description: This register acts as an initialization vector[95:64] for CBC mode.
- Offset: 0x64
31:0 |
VECTOR |
W |
Initialization vector[95:64] for CBC mode |
INIT_V2
- Name: AES Initialization Vector 2 Register
- Description: This register acts as an initialization vector[63:32] for CBC mode.
- Offset: 0x68
31:0 |
VECTOR |
W |
Initialization vector[63:32] for CBC mode |
INIT_V3
- Name: AES Initialization Vector 3 Register
- Description: This register acts as an initialization vector[31:0] for CBC mode.
- Offset: 0x6C
31:0 |
VECTOR |
W |
Initialization vector[31:0] for CBC mode |
DATA_IN0
- Name: AES Data Input 0 Register
- Description: This register is a 32-bit only write buffer for the input data[127:96] for encryption or decryption.
- Offset: 0x70
31:0 |
DATA_IN0 |
W |
Input data[127:96] for encryption or decryption. This register is valid in MCU mode. |
DATA_IN1
- Name: AES Data Input 1 Register
- Description: This register is a 32-bit only write buffer for the input data[95:64] for encryption or decryption.
- Offset: 0x74
31:0 |
DATA_IN1 |
W |
Input data[95:64] for encryption or decryption. This register is valid in MCU mode. |
DATA_IN2
- Name: AES Data Input 2 Register
- Description: This register is a 32-bit only write buffer for the input data[63:32] for encryption or decryption.
- Offset: 0x78
31:0 |
DATA_IN2 |
W |
Input data[63:32] for encryption or decryption. This register is valid in MCU mode. |
DATA_IN3
- Name: AES Data Input 3 Register
- Description: This register is a 32-bit only write buffer for the input data[31:0] for encryption or decryption.
- Offset: 0x7C
31:0 |
DATA_IN3 |
W |
Input data[31:0] for encryption or decryption. This register is valid in MCU mode. |
KEYPORT_MASK
- Name: AES Keyport Mask Register
- Description: This register acts as a mask for key from key port.
- Offset: 0x80
31:0 |
MASK |
W |
Mask for key from key port |
