Always-On I/O
The Always-on Watchdog(AON_WDT) is a 32-bit countdown hardware timer. When the AON_WDT counter counts to 0, a system reset signal is sent, and when the counter value decreases to the set warning value, an interrupt signal is generated. Because the AON_WDT timer is in the AON domain, it can keep running when the MCU is off.
- The LOCK register enables or disables write accesses to all other registers. This is to prevent malicious software from disabling the watchdog functionality. Writing a value of 0x15CC5A51 (LOCK.LOCK_SET[31:1]) enables write accesses to all other registers. Writing any other value to the LOCK register disables the write accesses.
- When the AON_WDT is disabled, all register values must be cleared to restore the default values.
- When the CFG0.EN bit is set to 1, the value of the TIMER_W register is automatically loaded into the TIMER_R register, and the value starts to decrease.
- The AON_WDT alarm interrupt is triggered when the value of the TIMER_R register decrements to the value of the ALARM_R register.
- When the TIMER_R count value decrements to 0, the system restarts.
AON_PAD_CTRL0
- Name: Always-on Pad Control Register
- Description: This register contains the AON_GPIO configurations.
- Base Address: 0x4000A000
- Offset: 0x1E4
- Reset Value: 0x00FF0000
| 31:24 | AON_INPUT_VAL | R | 0x0 | Always-on PAD signal from outside to cores |
| 16:23 | AON_IN_N | RW | 0xFF |
Always-on PAD input enable Value:
15:8 |
AON_O_N |
Always-on PAD output enable Value:
7:0 |
AON_OUT_VAL |
Always-on PAD signal from core to outside |
AON_PAD_CTRL1
- Description: This register contains the input and output data.
- Offset: 0x1E8
- Reset Value: 0x000000FF
31:16 |
Reserved bits |
| 15:8 | AON_R_TYPE | RW | 0x00 | Always-on PAD resistor type Value:
| 7:0 | AON_RE_N | RW | 0xFF | Always-on PAD
resistor
enable Value:
AON_PAD_CLK
- Name: Always-on PAD output clock controls register
- Description: This register controls inner clock output from AON_GPIO_4.
- Offset: 0x1F0
31:5 |
Reserved bits |
4:2 |
CLK_OUT_SEL |
Clock out selection Value:
1 |
Reserved bits |
0 |
CLK_OUT_EN |
Enable clock out via AON GPIO 4. Value:
AON_PAD_MCU_OVR
- Description: This register controls the MCU domain setting of always-on pads.
- Offset: 0x1F4
31:17 |
Reserved bits |
23:16 |
AON_PAD_MCU_OVR |
Use the settings from MCU domain; only valid when MCU domain is ON
15:0 |
Reserved bits |
The electrical parameters for the AON_GPIO_0–AON_GPIO_7 are as follows:
VIH |
Input high voltage |
VDDIO x 0.7 |
VDDIO |
V |
VIL |
Input low voltage |
VSSIO |
VDDIO x 0.3 |
V |
VOH,L |
Output high voltage, 4 mA, VDD ≥ 1.7 V |
VDD – 0.4 |
VDD |
V |
VOH,M |
Output high voltage, 4 mA, VDD ≥ 2.5 V |
VDD – 0.4 |
VDD |
V |
VOH,H |
Output high voltage, 4 mA, VDD ≥ 3 V |
VDD – 0.4 |
VDD |
V |
VOL,L |
Output low voltage, 4 mA, VDD ≥ 1.7 V |
VSS |
VSS + 0.4 |
V |
VOL,M |
Output low voltage, 4 mA, VDD ≥ 2.5 V |
VSS |
VSS + 0.4 |
V |
VOL,H |
Output low voltage, 4 mA, VDD ≥ 3 V |
VSS |
VSS + 0.4 |
V |
IOL |
Current at VSS+0.4 V, output set low, VDD ≥1.7 V |
4 |
mA |
IOH |
Current at VDD-0.4 V, output set high, VDD ≥ 1.7 V |
4 |
mA |
RPU |
Pull-up resistance |
20 |
kΩ |
RPD |
Pull-down resistance |
20 |
kΩ |
CPAD |
Pad capacitance |
5 |
pF |
