Public Key Cryptography (PKC)
Public Key Cryptography (PKC) algorithm, also known as asymmetric key algorithm, uses a pair of keys: a public key and a private key. The security of the private key should be ensured. The public key can be published. Data encrypted with the public key can only be decrypted with the private key, and vice versa. The public key algorithm does not need an online key server, and the key distribution protocol is simple, which greatly simplifies the key management. In addition to the encryption function, the public key algorithm provides key exchange function and digital signature function.
- Compliance with FIPS 186-4 standard
- Supports Scalar multiplication for P-256 elliptic curve
- Supports diverse modular operations:
- Montgomery modular multiplication for a configurable 256–2048 bits’ length
- Partial Montgomery Inversion for a configurable 256–2048 bits’ length
- Modular addition for a configurable 256–2048 bits’ length
- Modular subtraction for a configurable 256–2048 bits’ length
- Modular comparison for a configurable 256–2048 bits’ length
- Modular left-shift operation for a configurable 256–2048 bits’ length
- Big integer multiplication for a configurable 256–1024 bits’ length
- Big integer addition for a configurable 256–2048 bits’ length
- Hardware dummy multiplication
- Supports random clocking gating.
- Protects register read/write operations (registers cannot be read or written in the DISABLE module state).
- Supports interrupt and query.
Standard
| Document Code | Name of Standard |
FIPS PUB 186-4 |
Digital Signature Standard (DSS) (Compliant with P-256) |
SEC 2 |
Recommended Elliptic Curve Domain Parameters |
Module Overview
The PKC controller module completes the basic underlying modular arithmetic and the FIPS standard 256-point ECC point multiplication in the public key algorithm. The device embeds the PKC module in order to realize hardware acceleration of calculation.
PKC_TOP includes PKC_CORE, PKC_REG, RAND_CLK_GATE, and SP_RAM. PKC_CORE includes PKC_ENGINE and PKC_CTRL sub modules, in which PKC_ENGINE completes the basic underlying modular operations (modular multiplication, modular inversion, modular addition, modular subtraction, modular comparison, modular shift, big integer multiplication, big integer addition, and dummy multiplication) in the public key algorithm.
The ECC point multiplication only supports P-256 curve, such as secp256r1 and secp256k1. The public key algorithm needs a software library which can be open source or user-defined for implementation.
Usage
The CTRL register is used to start and reset the PKC module. The STAT register is used to indicate the status of the PKC module. The INT_EN register is used to configure the interrupt mode, and the INT_STAT register is used to indicate the interrupt status.
- Point Multiplication: MCU writes the following parameters to SP_RAM that is a memory area of the PKC module. The parameters include the 256-bit random number k, order n, prime P, base point G, R2mod P, and the initial infinity point Q0. CFG0 to CFG12 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Modular Multiplication: MCU writes operand a, operand b, and prime p to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG0 and SW_CFG1 registers are used to configure the location pointers. The CFG13 register is used to configure the modular multiplication constant if the lowest 32-bit of prime p is not 0xFFFFFFFF. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Modular Inversion: MCU writes operand a, modulo p, x1 initial value 1, and x2 initial value 0 to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG4 and SW_CFG5 registers are used to configure the location pointers. The SW_CFG6 register is configured to save the intermediate result of modular inversion operation. The calculation can be started by using the CTRL register. MCU will read the modular inversion x1 from the SP_RAM and read the SW_CFG8 register to get the modular inversion k. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Modular Subtraction and Modular Addition: MCU writes operand a, operand b, and prime p to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG2 and SW_CFG3 registers are used to configure the location pointers. The calculation can be started with the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Modular Comparison and Modular Shift: MCU writes operand a and prime p to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG0 and SW_CFG1 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Big Integer Multiplication: MCU writes operand a and operand b to SP_RAM. The SW_CFG7 register is used to configure the operand word length. The maximum configurable length of the big number multiplication is 1024 bits. SW_CFG10 and SW_CFG11 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Big Integer Addition: MCU writes operand a and operand b to SP_RAM. The SW_CFG7 register is used to configure the operand word length. SW_CFG11 and SW_CFG12 registers are used to configure the location pointers. The calculation can be started by using the CTRL register. MCU will read the result from the SP_RAM when the calculation completes. In the interrupt mode, the INT_STAT register can indicate whether the calculation completes.
- Dummy Multiplication: The SW_CFG9 register is used to configure the random seed of dummy multiplication. The dummy multiplication can be started by using the CTRL register. Subsequently, modular addition or big integer addition is performed. The result of the modular addition or the big integer addition can be obtained.
- Random Clock Gating: The SW_CFG13 register is used to configure the random seed of random clock gating. The random clock gating can be enabled by using the CTRL register. Subsequently, PKC operation can be performed.
CTRL
- Name: PKC Controller Register
- Description: This register acts as a global enable/disable for PKC.
- Base Address: 0x40014000
- Offset: 0x0
31:9 |
Reserved bits |
8 |
RST |
Write 0 and then write 1 to this bit to force the PKC core to reset. |
7:5 |
Reserved bits |
4 |
SW_CTRL |
Only used in software mode. Value:
3:2 |
Reserved bits |
1 |
START |
Only used in hardware mode. After MCU configures all parameters; write 0 and then write 1 to this bit, and the PKC starts to work. |
0 |
EN |
PKC core enable bit Value:
CFG0
- Name: PKC Configuration 0 Register
- Description: This register acts as a configuration for PKC.
- Offset: 0x4
- Reset Value: 0x00100000
31:25 |
Reserved bits |
24:16 |
R_POINT |
0x10 |
R point in sp_ram |
15:9 |
Reserved bits |
8:0 |
K_POINT |
K point in sp_ram |
CFG1
- Name: PKC Configuration 1 Register
- Offset: 0x8
- Reset Value: 0x00280020
31:25 |
Reserved bits |
24:16 |
R2_POINT |
0x28 |
R^2 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
P_POINT |
0x20 |
P point in sp_ram |
CFG2
- Name: PKC Configuration 2 Register
- Offset: 0xC
- Reset Value: 0x00380030
31:25 |
Reserved bits |
24:16 |
GY_POINT |
0x38 |
Gy point in sp_ram |
15:9 |
Reserved bits |
8:0 |
GX_POINT |
0x30 |
Gx point in sp_ram |
CFG3
- Name: PKC Configuration 3 Register
- Offset: 0x10
- Reset Value: 0x00480040
31:25 |
Reserved bits |
24:16 |
R0X_POINT |
0x48 |
R0x point in sp_ram |
15:9 |
Reserved bits |
8:0 |
GZ_POINT |
0x40 |
Gz point in sp_ram |
CFG4
- Name: PKC Configuration 4 Register
- Offset: 0x14
- Reset Value: 0x00580050
31:25 |
Reserved bits |
24:16 |
R0Z_POINT |
0x58 |
R0z point in sp_ram |
15:9 |
Reserved bits |
8:0 |
R0Y_POINT |
0x50 |
R0y point in sp_ram |
CFG5
- Name: PKC Configuration 5 Register
- Offset: 0x18
- Reset Value: 0x00680060
31:25 |
Reserved bits |
24:16 |
R1Y_POINT |
0x68 |
R1y point in sp_ram |
15:9 |
Reserved bits |
8:0 |
R1X_POINT |
0x60 |
R1x point in sp_ram |
CFG6
- Name: PKC Configuration 6 Register
- Offset: 0x1C
- Reset Value: 0x00780070
31:25 |
Reserved bits |
24:16 |
TEMP1_POINT |
0x78 |
Tmp1 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
R1Z_POINT |
0x70 |
R1Z point in sp_ram |
CFG7
- Name: PKC Configuration 7 Register
- Offset: 0x20
- Reset Value: 0x00880080
31:25 |
Reserved bits |
24:16 |
TEMP3_POINT |
0x88 |
TMP3 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
TEMP2_POINT |
0x80 |
TMP2 point in sp_ram |
CFG8
- Name: PKC Configuration 8 Register
- Offset: 0x24
- Reset Value: 0x00980090
31:25 |
Reserved bits |
24:16 |
TEMP5_POINT |
0x98 |
TMP5 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
TEMP4_POINT |
0x90 |
TMP4 point in sp_ram |
CFG9
- Name: PKC Configuration 9 Register
- Offset: 0x28
- Reset Value: 0x00A800A0
31:25 |
Reserved bits |
24:16 |
CONT1_POINT |
0xA8 |
Constant 1 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
TEMP6_POINT |
0xA0 |
TMP6 point in sp_ram |
CFG10
- Name: PKC Configuration 10 Register
- Offset: 0x2C
- Reset Value: 0x00B800B0
31:25 |
Reserved bits |
24:16 |
X2_POINT |
0xB8 |
X2 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
X1_POINT |
0xB0 |
X1 point in sp_ram |
CFG11
- Name: PKC Configuration 11 Register
- Offset: 0x30
- Reset Value: 0x00C800C0
31:25 |
Reserved bits |
24:16 |
KT_POINT |
0xC8 |
Software computes 2^256 mod p and writes to sp_ram. |
15:9 |
Reserved bits |
8:0 |
MIT_POINT |
0xC0 |
Only used in hardware mode. MI point in sp_ram |
CFG12
- Name: PKC Configuration 12 Register
- Offset: 0x34
- Reset Value: 0x00D800D0
31:25 |
Reserved bits |
24:16 |
B_POINT |
0xD8 |
Curve parameter b in Montgomery field |
15:9 |
Reserved bits |
8:0 |
A_POINT |
0xD0 |
Curve parameter a in Montgomery field |
CFG13
- Name: PKC Configuration 13 Register
- Offset: 0x38
- Reset Value: 0x00000001
31:0 |
CONSTQ |
0x1 |
Constant used in Montgomery multiplication |
SW_CTRL
- Name: PKC Software Controller Register
- Description: This register acts as a controller for software operation.
- Offset: 0x40
31:10 |
Reserved bits |
9 |
RCG_EN |
Enable random clock gating. Value:
8 |
DM_EN |
Enable dummy multiplication. Value:
7 |
Reserved bit |
6:4 |
MODE |
3:1 |
Reserved bits |
0 |
START |
Only used in software mode. MCU writes 0 to this bit and then writes 1 to this bit to start the PKC. |
SW_CFG0
- Name: PKC Software Configuration 0 Register
- Description: This register acts as a configuration for PKC in software mode.
- Offset: 0x44
- Reset Value: 0x00080000
31:25 |
Reserved bits |
24:16 |
MMB_POINT |
0x8 |
Modular multiplication B point in sp_ram |
15:9 |
Reserved bits |
8:0 |
MMA_POINT |
Modular multiplication A point in sp_ram |
SW_CFG1
- Name: PKC Software Configuration 1 Register
- Offset: 0x48
- Reset Value: 0x00180010
31:25 |
Reserved bits |
24:16 |
MMC_POINT |
0x18 |
Modular multiplication C point in sp_ram |
15:9 |
Reserved bits |
8:0 |
MMP_POINT |
0x10 |
Modular multiplication P point in sp_ram |
SW_CFG2
- Name: PKC Software Configuration 2 Register
- Offset: 0x4C
31:25 |
Reserved bits |
24:16 |
MASB_POINT |
0x28 |
Modular addition/subtraction B point in sp_ram |
15:9 |
Reserved bits |
8:0 |
MASA_POINT |
0x20 |
Modular addition/subtraction A point in sp_ram |
SW_CFG3
- Name: PKC Software Configuration 3 Register
- Offset: 0x50
31:25 |
Reserved bits |
24:16 |
MASC_POINT |
0x38 |
Modular addition/subtraction C point in sp_ram |
15:9 |
Reserved bits |
8:0 |
MASP_POINT |
0x30 |
Modular addition/subtraction P point in sp_ram |
SW_CFG4
- Name: PKC Software Configuration 4 Register
- Offset: 0x54
31:25 |
Reserved bits |
24:16 |
MIV_POINT |
0x48 |
Modular inversion V point in sp_ram |
15:9 |
Reserved bits |
8:0 |
MIU_POINT |
0x40 |
Modular inversion U point in sp_ram |
SW_CFG5
- Name: PKC Software Configuration 5 Register
- Offset: 0x58
31:25 |
Reserved bits |
24:16 |
MIX2_POINT |
0x58 |
Modular inversion X2 point in sp_ram |
15:9 |
Reserved bits |
8:0 |
MIT_POINT |
0x50 |
Modular inversion X1 point in sp_ram |
SW_CFG6
- Name: PKC Software Configuration 6 Register
- Offset: 0x5C
- Reset Value: 0x00000060
31:9 |
Reserved bits |
8:0 |
MITP |
0x60 |
Modular inversion TEMP point in sp_ram |
SW_CFG7
- Name: PKC Software Configuration 7 Register
- Offset: 0x60
- Reset Value: 0x00000007
31:6 |
Reserved bits |
5:0 |
LEN |
0x7 |
Operator word length configuration in software mode:
In hardware mode, this register is fixed to 0x07. |
SW_CFG8
- Name: PKC Software Configuration 8 Register
- Offset: 0x64
31:13 |
Reserved bits |
12:0 |
MIK_OUT |
K out in modular inversion operation |
SW_CFG9
- Name: PKC Software Configuration 9 Register
- Offset: 0x68
- Reset Value: 0xAABBCCDD
| 31:0 |
RDMS |
0xAABBCCDD |
Random dummy multiplication seed |
SW_CFG10
- Name: PKC Software Configuration 10 Register
- Offset: 0x6C
31:25 |
Reserved bits |
24:16 |
BMB_POINT |
0x78 |
Big multiplication B point in sp_ram |
15:9 |
Reserved bits |
8:0 |
BMA_POINT |
0x70 |
Big multiplication A point in sp_ram |
SW_CFG11
- Name: PKC Software Configuration 11 Register
- Offset: 0x70
31:25 |
Reserved bits |
24:16 |
BAA_POINT |
0x88 |
Big addition A point in sp_ram |
15:9 |
Reserved bits |
8:0 |
BMC_POINT |
0x80 |
Big multiplication C point in sp_ram |
SW_CFG12
- Name: PKC Software Configuration 12 Register
- Offset: 0x74
31:25 |
Reserved bits |
24:16 |
BAC_POINT |
0x98 |
Big addition C point in sp_ram |
15:9 |
Reserved bits |
8:0 |
BAB_POINT |
0x90 |
Big addition B point in sp_ram |
SW_CFG13
- Name: PKC Software Configuration 13 Register
- Offset: 0x78
- Reset Value: 0x11223344
31:0 |
RCG_SEED |
0x11223344 |
Random clock gating seed |
INT_STAT
- Name: PKC Interrupt Status Register
- Description: This is a read-only register used to indicate the interrupt status of PKC.
- Offset: 0x80
31:3 |
Reserved bits |
2 |
BIAO_INT_FLAG |
R WC |
PKC big integer add overflow flag. Write 1 to clear. |
1 |
ERR_INT_EN |
R WC |
PKC error interrupt flag. Write 1 to clear. |
0 |
CPLT_INT_FLAG |
R WC |
PKC complete interrupt flag. Write 1 to clear. |
INT_EN
- Name: PKC Interrupt Enable Register
- Description: This register enables or disables all interrupts generated by the PKC.
- Offset: 0x84
31:3 |
Reserved bits |
2 |
BIAO_INT_EN |
PKC big integer add overflow interrupt enable |
1 |
ERR_INT_EN |
PKC error interrupt enable |
0 |
CPLT_INT_EN |
PKC complete interrupt enable |
STAT
- Name: PKC Status Register
- Description: This is a read-only register used to indicate the status of PKC.
- Offset: 0x88
31:1 |
Reserved bits |
0 |
BUSY |
PKC busy status |
