文档中心 > GR5525 Datasheet/ Peripherals/ I/O/ Mixed Signal I/O Copy URL
Mixed Signal I/O
The device has eight individually configurable MSIOs that can be applied by peripherals, digital input\output or analog input.
  • MSIO default state is analog input mode.
  • As analog input for sense ADC or Comparator.
  • As digital MSIOs for input/output, no interrupt.
  • To multiplex some different peripherals.
  • For digital modules with high timing requirements, it is recommended to increase the MSIO drive current.
MSIO_APAD_CFG0
  • Name: MSIO Pad Control Register
  • Description: This register contains the input and output data.
  • Base Address: 0x4000A1D4
  • Offset: 0x00
  • Reset Value: 0x00FF0000
Table 299 MSIO_APAD_CFG0 Register
31:24
MSIO_VAL
MSIO read value
23:16
MSIO_IE_N
0xFF
MSIO input enable
  • 0x0: Disable MSIO_x input.
  • 0x1: Enable MSIO_x input.
15:8
MSIO_OE_N
MSIOA output enable (active low)
  • 0x0: Disable MSIO_x output.
  • 0x1: Enable MSIO_x output.
7:0
MSIO_OUT
MSIO output value (valid in output mode)
MSIO_APAD_CFG1
  • Description: This register contains the MSIOA configurations.
  • Base Address: 4000A1D8
  • Offset: 0x00
Table 300 MSIO_APAD_CFG1 Register
31:16
15:8
MSIO_RTYPE
MSIO resistor type
  • 0x0: Pull down.
  • 0x1: Pull up.
7:0
MSIO_AE_N
MSIO input enable (active low)
  • 0x0: Disable input.
  • 0x1: Enable input.
MSIO_APAD_MCU_OVR
  • Name: MSIO Using MCU Domain Setting Control Register
  • Description: This register controls MSIO using the settings from the MCU domain.
  • Base Address: 0x4000A1E0
  • Offset: 0x0
Table 301 MSIO_APAD_MCU_OVR Register
31:8
N/A
7:0
MSIO_MCU_OVR
Use the settings from MCU domain, only valid when MCU domain is ON
  • 0x0: Use settings in MSIO_APAD_CFG as GPIO.
  • 0x1: Use PAD MUX settings in MCU.
The electrical parameters for the MSIO_0–MSIO_7 are as follows:
Table 302 GPIO electrical specifications
VIH
Input high voltage
VDDIO x 0.7
VDDIO
V
VIL
Input low voltage
VSSIO
VDDIO x 0.3
V
VOH,L
Output high voltage, 2.5 mA, VDD ≥ 1.7 V
VDD – 0.4
VDD
V
VOH,M
Output high voltage, 2.5 mA, VDD ≥ 2.5 V
VDD – 0.4
VDD
V
VOH,H
Output high voltage, 2.5 mA, VDD ≥ 3 V
VDD – 0.4
VDD
V
VOL,L
Output low voltage, 2.5 mA, VDD ≥ 1.7 V
VSS
VSS + 0.4
V
VOL,M
Output low voltage, 2.5 mA, VDD ≥ 2.5 V
VSS
VSS + 0.4
V
VOL,H
Output low voltage, 2.5 mA, VDD ≥ 3 V
VSS
VSS + 0.4
V
IOL
Current at VSS+0.4 V, output set low, VDD ≥1.7 V
7
mA
IOH
Current at VDD-0.4 V, output set high, VDD ≥ 1.7 V
7
mA
RPU
Pull-up resistance
70
120
150
RPD
Pull-down resistance
10
CPAD
Pad capacitance
10
pF
