文档中心 > GR5525 Datasheet/ Peripherals/ Timer Interfaces/ Always-on Watchdog (AON_WDT) Copy URL
The Always-on Watchdog(AON_WDT) is a 32-bit countdown hardware timer. When the AON_WDT counter counts to 0, a system reset signal is sent, and when the counter value decreases to the set warning value, an interrupt signal is generated. Because the AON_WDT timer is in the AON domain, it can keep running when the MCU is off.
  • The CLK register is a read/write register when the AON_WDT is disabled and is read only when the AON_WDT is enabled. Writing to the CLK register when the AON_WDT is enabled has no effect.
  • 32-bit down counter running with a low-power clock
  • Generates an interrupt to warn the MCU when the 32-bit down counter reaches alarm values
  • 16-bit alarm register, supporting reading and writing
  • Flexible clock source selections from LFRC_32K or LFXO_32K
  • An independent interrupt entry
  • Supports write access protection
  • The LOCK register enables or disables write accesses to all other registers. This is to prevent malicious software from disabling the watchdog functionality. Writing a value of 0x15CC5A51 (LOCK.LOCK_SET[31:1]) enables write accesses to all other registers. Writing any other value to the LOCK register disables the write accesses.
  • When the AON_WDT is disabled, all register values must be cleared to restore the default values.
  • When the CFG0.EN bit is set to 1, the value of the TIMER_W register is automatically loaded into the TIMER_R register, and the value starts to decrease.
  • The AON_WDT alarm interrupt is triggered when the value of the TIMER_R register decrements to the value of the ALARM_R register.
  • When the TIMER_R count value decrements to 0, the system restarts.
Block Diagram
The following figure shows the functional blocks of the Always-on watchdog module.
Figure 41 Always-on Watchdog Block Diagram
The watchdog starts running when AON_WDT_EN = 1 is synchronized to AON_WDT clock domain, which takes 1 – 3 RNG (Random Number Generators) clock cycles (20 – 100 µs).
If no reload operation is performed, the down counter default value is 0xFFFFFFFF. Otherwise, the counter will be reloaded with the value of timer_value.
Clock
The AON_WDT works in RNG clock (30 kHz – 50 kHz), which is much slower than MCU system clock (16 MHz – 64 MHz). Therefore, synchronization time is needed to propagate the MCU operations. For example, in reload operation, MCU needs to check whether the VAL_RD value has changed as expected.
Enable/Disable and Timer Reload
  • To enable the block, set AON_WDT_EN = 1 and wait until AON_WDT_RUNNING being high.
  • To disable the block, set AON_WDT_EN = 0 and wait until AON_WDT_RUNNING being low.
  • To reload down counter, program the desired value to timer_value, then set write-only register AON_WDT_RELOAD = 1. MCU can check read-only register VAL_RD to confirm.
Alarm
The AON_WDT provides an almost-expired alarm to warn MCU before system reset. By setting ALARM_VAL= N(non-zero), the AON_WDT generates an interrupt N RNG clocks before the system reset.
CFG_0
  • Name: CFG_0 Register
  • Description: This register sets AON_WDT configurations.
  • Base Address: 0x4000A700
  • Offset: 0x0
Table 326 CFG_0 Register
31:25
24
CFG
W
Writing 1 to this register triggers the watchdog timer configuration.
23:4
3
ALARM_SET
Sets the timer alarm value.
2
ALARM_EN
Enables AON WDT alarm.
RELOAD
W
Enables AON WDT timer reload (feed).
EN
Enables AON WDT.
LOCK
  • Name: LOCK Register
  • Description: This register can prevent other registers of AON_WDT from being overwritten
  • Offset: 0x4
Table 327 LOCK Register
31:1
LOCK_VALUE
W
Enable write access to all other registers by writing 0x15CC5A51. Disable write access by writing any other value to the LOCK register.
STATUS
  • 0: Unlocked. Write to other watchdog registers is enabled.
  • 1: Locked. Write to other watchdog registers is disabled.
STAT
  • Name: STAT Register
  • Description: This register can be used to get status of AON_WDT.
  • Offset: 0x38
Table 328 STAT Register
31:2
BUSY
Watchdog timer is busy. The application layer can perform other operations until this bit is set is 0.
STAT
AON WDT is running.
CLK
  • Name: CLK Register
  • Description: This register is used to select an AON_WDT clock source.
  • Offset: 0x3C
Table 329 CLK Register
31:2
1:0
CLK_SEL
  • 0x02: LFRC_32K (LFRC 32 kHz Clock)
  • 0x03: LFXO_32K (LF_XO 32 kHz Clock)
TIMER_WR
  • Name: TIMER_WR Register
  • Description: This register is used to configure the initial AON_WDT value.
  • Offset: 0x40
Table 330 TIMER_WR Register
31:0
TIMER_SET
Write:
Write the initial AON WDT value to the register.
Read:
  • Read the initial AON WDT value that users have configured.
  • Read TIMER_RD to get the current internal value.
ALARM_WR
  • Name: ALARM_WR Register
  • Description: This register is used to configure the AON_WDT alarm value.
  • Offset: 0x44
  • Reset Value: 0x64
Table 331 ALARM_WR Register
31:16
15:0
ALARM_SET
0x64
Write:
Write an AON WDT alarm value to the register.
Read:
  • Read the AON WDT alarm value that users have configured.
  • Read ALARM_RD to get the current internal alarm value of AON WDT.
TIMER_RD
  • Name: TIMER_RD Register
  • Description: This register is used to get the current value of AON_WDT.
  • Offset: 0x4C
Table 332 TIMER_RD Register
31:0
TIMER_RD
Current internal value of AON WDT
ALARM_RD
  • Name: ALARM_RD Register
  • Description: This register reads the current alarm value of AON_WDT.
  • Offset: 0x50
Table 333 ALARM_RD Register
31:16
15:0
ALARM_RD
Current internal alarm value of the AON WDT
