Hash-based Message Authentication Code (HMAC)
Hash-based Message Authentication Code (HMAC) is a mechanism for message authentication by using hash functions in cryptography. The message authentication provided by HMAC includes two aspects:
- Message integrity authentication: This can prove that the message has not been modified during transmission.
- Source identity authentication: Because both sides of the communication share the authentication key, receiver can verify that the source sending the data is consistent with the claim so that the receiver can reliably confirm that the received message is consistent with the sent message.
- Compatible with SHA-256
- Supports custom initial hash values.
- Supports querying registers and interrupts to report status.
- Supports MCU mode and DMA mode.
Standard
| Document Code | Name of Standard |
FIPS PUB 180-4 |
Secure Hash Standard (SHS) (Compliant with SHA-256) |
FIPS PUB 198-1 |
Keyed-Hash Message Authentication Code (HMAC) |
Module Overview
The HMAC co-processor authenticates data, using an algorithm and implementation fully compliant with the Keyed-Hash Message Authentication Code defined in Federal Information Processing Standards (FIPS) Publication 198. GR5525 embeds the HMAC module in order to realize hardware acceleration of calculation.
Multiple modes are supported (SHA256, HMAC-SHA256) for a key size of 256 bits.
Information preprocessing is required for input data, including additional padding bits and additional length value.
The HMAC co-processor adopts both 32-bit AHB and APB interfaces. It supports DMA transfers for incoming and outgoing data (through a dedicated integrated DMA).
Usage
The CFG register can be used to configure relevant parameters for the HMAC module. CFG.CALC_TYPE can be used to configure the working mode including SHA-256 and HMAC. If the working mode is set to HMAC, the mode of fetching the key should be configured through CFG.KEY_TYPE.
If the key is configured by MCU, the KEY0 to KEY7 registers need to be configured. If the key is fetched through AHB, the KEY_ADDR register should be configured.
The SER_HASH0 to USER_HASH7 registers are used to customize the initial HASH values if the CFG register enables users to define the initial HASH.
If the HMAC module is in interrupt or DMA operation mode, the INT register needs to be configured.
In DMA operation mode, the XFER_SIZE, RD_START_ADDR, and WR_START_ADDR registers should be configured. If misalignment is required when MCU reads or writes data, the last two bits of the RD_START_ADDR and the WR_START_ADDR registers can be configured.
The HMAC module can be started through the CTRL register. CTRL.KEY_EN is configured in order to enable the HMAC module to fetch the key through AHB master interface.
In MCU operation mode, a block data (512-bit) is continuously written into the DATA_IN register. In DMA operation mode, the HMAC module will read the data from the address which is stored in the RD_START_ADDR register.
The STAT register or interrupt callback function can judge whether the calculation completes. Before writing next block data into the DATA_IN register, the INT register needs to be cleared.
In MCU operation mode, the result of the SHA-256 or HMAC can be obtained by repeatedly reading the DATA_OUT register until getting 256-bit data. In DMA operation mode, the result has been sent to the address which is stored in the WR_START_ADDR register.
CTRL
- Name: HMAC Controller Register
- Description: This register acts as a global enable/disable for HMAC.
- Base Address: 0x40015800
- Offset: 0x0
31:4 |
Reserved bits |
3 |
LST_TX |
W |
Last block in MCU mode or last DMA transfer. This signal may be cleared by itself when hmac_ready was set. |
2 |
KEY_EN |
W |
Enable HMAC fetch key by itself through AHB master interface or key port. This signal may be cleared by itself when hmac_key_valid was set. |
1 |
DMA_START |
DMA mode start enable. Starting DMA transfer, this signal should be cleared after DMA has finished all transfers. |
0 |
EN |
HMAC enable, high valid for whole HMAC processing. Users must disable it once all HMAC blocks complete. This signal should be asserted until all blocks complete. |
CFG
- Name: HMAC Configuration Register
- Description: This register acts as a configuration for HMAC.
- Offset: 0x4
31:6 |
Reserved bits |
5 |
PRIVT_MOD |
To resist DPA, select private mode. Value:
4 |
CALC_TYPE |
Selects a calculation type. Value:
3:2 |
KEY_TYPE |
Selects a key type. Value:
1 |
ENDIAN |
Selection for endian control Value:
0 |
HASH |
Enables user-defined hash. Value:
STAT
- Name: HMAC Status Register
- Description: This is a read-only register used to indicate the current status of HMAC.
- Offset: 0x8
31:6 |
Reserved bits |
5 |
DMA_TX_DONE |
HMAC DMA transfer done or not |
4 |
HMAC_READY |
HMAC process status Value:
3 |
KEY_VALID |
HMAC has fetched key or not |
2 |
DMA_TX_ERR |
R WC |
HMAC DMA transfer error. Write 1 to clear. |
1 |
DMA_MSG_DONE |
If the number of all block messages is bigger than the transfer size, it indicates all block messages are sent when this signal is set. |
0 |
HASH_READY |
Hash process status Value:
XFER_SIZE
- Name: HMAC Transfer Size Register
- Description: This register sets a size for HMAC DMA mode transfer.
- Offset: 0xC
31:15 |
Reserved bits |
14:0 |
SIZE |
Total transfer size. Up to 32 KB
INT
- Name: HMAC Interrupt Register
- Description: This register enables or disables all interrupts generated by the HMAC. Additionally, it reports the status of the HMAC interrupts after they have been enabled.
- Offset: 0x10
31:2 |
Reserved bits |
1 |
EN |
HMAC result data complete interrupt Value:
0 |
DONE |
R WC |
HMAC result data complete interrupt flag. Write 1 to clear. Read:
Write:
RD_START_ADDR
- Name: HMAC Read Start Address Register
- Description: This register acts as a start address for HMAC DMA reading.
- Offset: 0x14
31:0 |
ADDR |
In DMA mode, set the read start address of transfer. |
WR_START_ADDR
- Name: HMAC Write Start Address Register
- Description: This register acts as a start address for HMAC DMA writing.
- Offset: 0x18
31:0 |
ADDR |
In DMA mode, set the write start address of transfer. |
USER_HASH_0
- Name: HMAC User Hash 0 Register
- Description: This register acts as a user Hash value for HASH calculation.
- Offset: 0x20
Bits |
Field Name |
Reset |
Description |
31:0 |
HASH_0 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[255:224] |
USER_HASH_1
- Name: HMAC User Hash 1 Register
- Offset: 0x24
31:0 |
HASH_1 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[223:192] |
USER_HASH_2
- Name: HMAC User Hash 2 Register
- Offset: 0x28
31:0 |
HASH_2 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[191:160] |
USER_HASH_3
- Name: HMAC User Hash 3 Register
- Offset: 0x2C
31:0 |
HASH_3 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[159:128] |
USER_HASH_4
- Name: HMAC User Hash 4 Register
- Offset: 0x30
31:0 |
HASH_4 |
If UHASH is selected, you can configure a user-defined Hash value with USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[127:96] |
USER_HASH_5
- Name: HMAC User Hash 5 Register
- Offset: 0x34
31:0 |
HASH_5 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[95:64] |
USER_HASH_6
- Name: HMAC User Hash 6 Register
- Offset: 0x38
31:0 |
HASH_6 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[63:32] |
USER_HASH_7
- Name: HMAC User Hash 7 Register
- Offset: 0x3C
31:0 |
HASH_7 |
If UHASH is selected, you can configure a user-defined Hash value by using USER_HASH_0/1/2/3/4/5/6/7. User defined Hash value[31:0] |
DATA_OUT
- Name: HMAC Data Output Register
- Description: This register is a 32-bit only read buffer for the result data from HMAC.
- Offset: 0x40
31:0 |
DATA |
In MCU mode, users can read out results with this register: When all blocks of messages are processed, 256-bit HMAC data should be read out 8 or 9 times. HMAC data can be read when hmac_ready is valid. |
DATA_IN
- Name: HMAC Data Input Register
- Description: This register is a 32-bit only write buffer for the input data for HMAC.
- Offset: 0x44
Bits |
Field Name |
Reset |
Description |
31:0 |
DATA |
W |
In MCU mode, users can configure input data with this register: 32-bit data should be sent 16 or 17 times. |
KEY0
- Name: HMAC Key 0 Register
- Description: This register is a 32-bit only write buffer for the key data[255:224] for HMAC.
- Offset: 0x48
31:0 |
KEY0 |
W |
Key is set as 256 bits (8 words). WORD0 |
KEY1
- Name: HMAC Key 1 Register
- Description: This register is a 32-bit only write buffer for the key data[223:192] for HMAC.
- Offset: 0x4C
31:0 |
KEY1 |
W |
Key is set as 256 bits (8 words). WORD1 |
KEY2
- Name: HMAC Key 2 Register
- Description: This register is a 32-bit only write buffer for the key data[191:160] for HMAC.
- Offset: 0x50
31:0 |
KEY2 |
W |
Key is set as 256 bits (8 words). WORD2 |
KEY3
- Name: HMAC Key 3 Register
- Description: This register is a 32-bit only write buffer for the key data[159:128] for HMAC.
- Offset: 0x54
31:0 |
KEY3 |
W |
Key is set as 256 bits (8 words). WORD3 |
KEY4
- Name: HMAC Key 4 Register
- Description: This register is a 32-bit only write buffer for the key data[127:96] for HMAC.
- Offset: 0x58
31:0 |
KEY4 |
W |
Key is set as 256 bits (8 words). WORD4 |
KEY5
- Name: HMAC Key 5 Register
- Description: This register is a 32-bit only write buffer for the key data[95:64] for HMAC.
- Offset: 0x5C
31:0 |
KEY5 |
W |
Key is set as 256 bits (8 words). WORD5 |
KEY6
- Name: HMAC Key 6 Register
- Description: This register is a 32-bit only write buffer for the key data[63:32] for HMAC.
- Offset: 0x60
Bits |
Field Name |
Reset |
Description |
31:0 |
KEY6 |
W |
Key is set as 256 bits (8 words). WORD6 |
KEY7
- Name: HMAC Key 7 Register
- Description: This register is a 32-bit only write buffer for the key data[31:0] for HMAC.
- Offset: 0x64
31:0 |
KEY7 |
W |
Key is set as 256 bits (8 words). WORD7 |
KEY_ADDR
- Name: HMAC Key Address Register
- Description: This register acts as a key address for HMAC.
- Offset: 0x68
31:0 |
KEY_ADDR |
Indicates the HMAC key address in memory. |
KEYPORT_MASK
- Name: HMAC Keyport Mask Register
- Description: This register acts as a mask for key from key port.
- Offset: 0x6C
31:0 |
MASK |
W |
Mask for key from key port |
