文档中心 > GR5525 Datasheet/ Peripherals/ DMA/ Registers Copy URL
Channel_x_Registers
SARx
  • Name: Source Address for Channel x
  • Description: The starting source address is programmed by software before the DMA channel is enabled, or by an LLI update before the start of the DMA transfer. While the DMA transfer is in progress, this register is updated to reflect the source address of the current AHB transfer.
You must program the SAR address to be aligned to CT_LOx.SRC_TR_WIDTH.
  • Base Address: 0x40019000 (DMA0)/0x4001A000 (DMA1)
  • Offset: 0x0 + x*0x58
  • Reset Value: 0x0
Table 673 Source Address Register for Channel x
63:32
31:0
SRC_ADDR
Current Source Address of DMA transfer.
Updated after each source transfer. The SRC_ADDR_INC field in the CTL_LOx register determines whether the address increments, decrements, or is left unchanged on every source transfer through the block transfer.
Volatile: true
DARx
  • Name: Destination Address Register for Channel x
  • Description: The starting destination address is programmed by software before the DMA channel is enabled, or by an LLI update before the start of the DMA transfer. While the DMA transfer is in progress, this register is updated to reflect the destination address of the current AHB transfer.
You must program the DAR to be aligned to CTL_LOx.DST_TR_WIDTH.
  • Offset: 0x8 + x*0x58
  • Reset Value: 0x0
Table 674 Destination Address Register for Channel x
63:32
31:0
DEST_ADDR
Current Destination address of DMA transfer.
Updated after each destination transfer. The DEST_ADDR_INC field in the CTRL_CHx register determines whether the address increments, decrements, or is left unchanged on every destination transfer throughout the block transfer.
Volatile: true
LLPx
  • Name: Linked List Pointer Register for Channel x
  • Description: The LLP register has two functions:
    • The logical result of the equation LLP.LOC !=0 is used to set up the type of DMA transfer: single or multi-block. If LLP.LOC is set to 0x0, transfers using linked lists are not enabled. This register must be programmed prior to enabling the channel in order to set up the transfer type.
    • LLP.LOC != 0 contains the pointer to the next LLI for block chaining using linked lists. The LLPx register can also point to the address where write back of the control and source/destination status information occurs after block completion.
  • Offset: 0x10 + x*0x58
  • Reset Value: 0x0
Table 675 Linked List Pointer Register for Channel x
63:32
31:2
LOC
Starting Address In Memory of next LLI if block chaining is enabled.
Note that the two LSBs of the starting address are not stored because the address is assumed to be aligned to a 32-bit boundary. LLI accesses are always 32-bit accesses (Hsize = 2) aligned to 32-bit boundaries and cannot be changed or programmed to anything other than 32-bit.
Volatile: true
1:0
CTL_LOx
  • Name: Control Register Low for Channel x
  • Description: This register contains fields that control the DMA transfer.
You need to program this register prior to enabling the channel.
  • Offset: 0x18 + x*0x58
  • Reset Value: 0x00304801
Table 676 Control Register Low for Channel x
31:29 RSVD R
Volatile: true
28 LLP_SRC_EN RW 0x0
Block chaining is enabled on the source side only if LLP_SRC_EN field is high and LLPx.LOC is non-zero .
  • 0x0 (LLP_SRC_DISABLE): Block chaining using linked list is disabled on the source size.
  • 0x1 (LLP_DST_ENABLE): Block chaining using linked list is enabled on the source size.
Volatile: true
27 LLP_DST_EN RW 0x0
Block chaining is enabled on the destination side only if LLP_DST_EN field is high and LLPx.LOC is non-zero .
  • 0x0 (LLP_DST_DISABLE): Block chaining using linked list is disabled on the destination size.
  • 0x1 (LLP_DST_ENABLE): Block chaining using linked list is enabled on the destination size.
Volatile: true
26:23 RSVD R
Volatile: true
22:20 TT_FC RW 0x3
Transfer Type and Flow Control.
Flow control can be assigned to the DMA, the source peripheral, or the destination peripheral.
  • 0x0: Transfer type is memory to memory, and flow controller is DMA.
  • 0x1: Transfer type is memory to peripheral, and flow controller is DMA.
  • 0x2: Transfer type is Peripheral to memory, and flow controller is DMA.
  • 0x3: Transfer type is peripheral to peripheral, and flow controller is DMA.
Volatile: true
19 RSVD R
Volatile: true
18 DST_GATHER_EN RW 0x0
Destination scatter enable.
Scatter on the destination side is applicable only when the CTL_LOx.DINC bit indicates an incrementing or decrementing address control.
  • 0x0 (DST_SCATTER_DISABLE): Destination scatter is disabled.
  • 0x1 (DST_SCATTER_ENABLE): Destination scatter is enabled.
Volatile: true
17 SRC_GATHER_EN RW 0x0
Source gather enable.
Gather on the source side is applicable only when the CTL_LOx.SINC bit indicates an incrementing or decrementing address control.
  • 0x0 (SRC_GATHER_DISABLE): Source gather is disabled.
  • 0x1 (SRC_GATHER_ENABLE): Source gather is enabled.
Volatile: true
16:14 SRC_MSIZE RW 0x1
Source burst transaction length.
Number of data items, each of width CTL_LOx. SRC_TR_WIDTH, to be read from the source every time a burst transferred request is made from either the corresponding hardware or software handshaking interface.
This value is not related to the AHB bus master HBURST bus.
  • 0x0: Number of data items to be transferred is 1.
  • 0x1: Number of data items to be transferred is 4.
  • 0x2: Number of data items to be transferred is 8.
Volatile: true
13:11 DST_MSIZE RW 0x1
Destination burst transaction length.
Number of data items, each of width CTL_LOx. DST_TR_WIDTH, to be written to the destination every time a destination burst transaction request is made from either the corresponding hardware or software handshaking interface.
Volatile: true
10:9 SINC RW 0x0
Source address increment.
Indicates whether to increment or decrement the source address on every source transfer. If the device is fetching data from a source peripheral FIFO with a fixed address, set this field to "No change".
  • 0x0: Increments the source address.
  • 0x1: Decrements the source address.
  • 0x2/0x3: No change in the source address
Volatile: true
8:7 DINC RW 0x0
Destination address increment.
Indicates whether to increment or decrement the destination address on every destination transfer. If your device is writing data to a destination peripheral FIFO with a fixed address, set this field to "No Change".
  • 0x0: Increments the destination address.
  • 0x1: Decrements the destination address.
  • 0x2/0x3: No change in the destination address
Volatile: true
6:4 SRC_TR_WIDTH RW 0x0
Source Transfer Width.
Mapped to AHB bus Hsize. For a non-memory peripheral, typically the peripheral (source) FIFO width.
  • 0x0: Source transfer width is 8 bits.
  • 0x1: Source transfer width is 16 bits.
  • 0x2: Source transfer width is 32 bits.
Volatile: true
3:1 DST_TR_WIDTH RW 0x0
Destination Transfer Width.
Mapped to AHB bus Hsize. For a non-memory peripheral, typically the peripheral (destination) FIFO width.
  • 0x0: Destination transfer width is 8 bits.
  • 0x1: Destination transfer width is 16 bits.
  • 0x2: Destination transfer width is 32 bits.
Volatile: true
0 INT_EN RW 0x1
Interrupt Enable Bit.
If set, all interrupt-generating sources are enabled. Functions as a global mask bit for all interrupts for the channel; raw interrupt registers still assert if CTL_LOx.INT_EN = 0.
  • 0x0: Interrupt is disabled.
  • 0x1: Interrupt is enabled.
Volatile: true
CTL_HIx
  • Name: Control Register High for Channel x
  • Offset: 0x1C + x*0x58
  • Reset Value: 0x00000002
Table 677 Control Register High for Channel x
31:13 RSVD R
Volatile: true
12 DONE RW 0x0
Done bit.
If status write-back is enabled, the upper word of the control register, CTL_HIx, is written to the control register location of the LLI in system memory at the end of the block transfer with the done bit set.
Software can poll the LLI CTL_HIx.DONE bit to see when a block transfer completes. The LLI CTL_HIx.DONE bit should be cleared when the linked lists are set up in memory prior to enabling the channel.
11:0 BLOCK_TS RW 0x2
Block Transfer Size.
When the DMA is the flow controller, the user writes this field before the channel is enabled in order to indicate the block size. The number programmed into BLOCK_TS indicates the total number of single transactions to perform for every block transfer; a single transaction is mapped to a single AMBA beat.
Width: The width of single transaction is determined by CTL_LOx. SRC_ TR_WIDTH.
Once the transfer starts, the read-back value is the total number of data items already read from the source peripheral, regardless of what the flow controller is.
When the source or destination peripheral is assigned as the flow controller, the maximum block size that can be read back saturates at 0xFFF, but the actual block size can be greater.
Volatile: true
SSTATx
  • Name: Source Status Register for Channel x
  • Description: After each block transfer completes, hardware can retrieve the source status information from the address pointed to by the contents of the SSTATARx register. This status information is then stored in the SSTATx register and written out to the SSTATx register location of the LLI before the start of the next block. For conditions under which the source status information is fetched, it can be varied on a block-by-block basis within a DMA transfer when block chaining is enabled. If status write-back is enabled, the upper word of the control register, CTL_HIx, is written to the control register location of the LLI in system memory at the end of the block transfer.
This register is a temporary placeholder for the source status information on its way to the SSTATx register location of the LLI. The source status information should be retrieved by software from the SSTATx register location of the LLI, and not by a read of this register over the DMA controller slave interface.
  • Offset: 0x20 + x*0x58
  • Reset Value: 0x0
Table 678 Source Status Register for Channel x
63:32
31:0
SSTAT
Source status information retrieved by hardware from the address pointed to by the contents of the STATARx register
Volatile: true
DSTATx
  • Name: Destination Status Register for Channel x
  • Description: After each block transfer completes, hardware can retrieve the destination status information from the address pointed to by the contents of the DSTATARx register. This status information is then stored in the DSTATx register and written out to the DSTATx register location of the LLI before the start of the next block.
This register is a temporary placeholder for the destination status information on its way to the DSTATx register location of the LLI. The destination status information should be retrieved by software from the DSTATx register location of the LLI, and not by a read of this register over the DMAC controller slave interface.
  • Offset: 0x28 + x*0x58
  • Reset Value: 0x0
Table 679 Destination Status Register for Channel x
63:32
31:0
DSTAT
Destination status information retrieved by hardware from the address pointed to by the contents of the DSTATARx register
Volatile: true
SSTATARx
  • Name: Source Status Address Register for Channel x
  • Description: After completion of each block transfer, hardware can retrieve the source status information from the user-defined address to which the contents of the SSTATARx register point. Users can select any location in system memory that would provide a 32-bit value to indicate the status of the source transfer.
  • Offset: 0x30 + x*0x58
  • Reset Value: 0x0
Table 680 Source Status Address Register for Channel x
63:32
31:0
SSTATAR
Pointer from where hardware can fetch the source status information which is registered in the SSTATx register and written out to the SSTATx register location of the LLI before the start of the next block.
DSTATARx
  • Name: Destination Status Address Register for Channel x
  • Description: After completion of each block transfer, hardware can retrieve the destination status information from the user-defined address to which the contents of the DSTATARx register point. Users can select any location in system memory that would provide a 32-bit value to indicate the status of the destination transfer.
  • Offset: 0x38 + x*0x58
  • Reset Value: 0x0
Table 681 Destination Status Address Register for Channel x
63:32
31:0
DSTATAR
Pointer from where hardware can fetch the destination status information which is registered in the DSTATx register and written out to the DSTATx register location of the LLI before the start of the next block.
CFG_LOx
  • Name: Configuration Register Low for Channel x
  • Description: This register contains fields that configure the DMA transfer. The channel configuration register remains fixed for all blocks of a multi-block transfer.
  • Offset: 0x40 + x*0x58
  • Reset Value: 0x00000e00 + (x*0x20)
Table 682 Configuration Register Low for Channel x
31 RELOAD_DST RW 0x0
Automatic Destination Reload.
The DARx register can be automatically reloaded from its initial value at the end of every block for multi-block transfers. A new block transfer is then initiated.
  • 0x0: Destination reload disabled.
  • 0x1: Destination reload disabled.
30 RELOAD_SRC RW 0x0
Automatic Source Reload.
The SARx register can be automatically reloaded from its initial value at the end of every block for multi-block transfers. A new block transfer is then initiated.
  • 0x0: Source reload disabled.
  • 0x1: Source reload enabled.
29:20 RSVD R Reserved bits
19 SRC_HS_POL RW 0x0
Source handshaking interface polarity.
  • 0x0: Source handshaking interface polarity is active high.
  • 0x1: Source handshaking interface polarity is active low.
18 DST_HS_POL RW 0x0
Destination handshaking interface polarity.
  • 0x0: Destination handshaking interface polarity is active high.
  • 0x1: Destination handshaking interface polarity is active low.
17:12 RSVD R Reserved bits
11 HSG_SEL_SRC RW 0x1
Selects software or hardware handshaking interface for source.
This register selects which of the handshaking interfaces - hardware or software - is active for source requests on this channel. If the source peripheral is memory, this bit is ignored.
  • 0x0: Hardware handshaking interface. Software initiated transaction requests are ignored.
  • 0x1: Software handshaking interface. Hardware initiated transaction requests are ignored.
10 HSG_SEL_DEST RW 0x1
Selects a software or hardware handshaking interface for destination.
This register selects which of the handshaking interfaces - hardware or software - is active for destination requests on this channel. If the destination peripheral is memory, this bit is ignored.
9 FIFO_EMPTY R 0x1
Channel FIFO status.
Indicates if there is data left in the channel FIFO. It can be used in conjunction with CFGx to cleanly disable a channel.
  • 0x0: Channel FIFO is not empty.
  • 0x1: Channel FIFO is empty.
8 CH_SUSP RW 0x0
Channel suspend.
Suspends all DMA data transfers from the source until this bit is cleared. There is no guarantee that the current transaction will complete. It can also be used in conjunction with CFGx to cleanly disable a channel without losing any data.
  • 0x0: DMA transfer from the source is not suspended.
  • 0x1: Suspend DMA transfer from the source.
7:5 CH_PRIOR RW 0x0
Channel priority.
A priority of 7 is the highest priority and 0 is the lowest. This field must be programmed within the range of 0 to 3. A programmed value beyond this range will cause erroneous behavior.
  • 0x0: Channel priority is 0.
  • 0x1: Channel priority is 1.
  • 0x2: Channel priority is 2.
  • 0x3: Channel priority is 3.
4:0 RSVD R Reserved bits
CFG_HIx
  • Name: Configuration Register High for Channel x
  • Offset: 0x44 + x*0x58
  • Reset Value: 0x00000004 + (x*0x20)
Table 683 Configuration Register High for Channel x
31:15 RSVD R Reserved bits
14:11 DEST_PER RW 0x0
Destination hardware interface.
Assigns a hardware handshaking interface to the destination of channel x if the CFG_LOx.HSG_SEL_DEST field is 0; otherwise, this field is ignored. The channel can communicate with the destination peripheral connected to that interface through the assigned hardware handshaking interface.
For correct DMA operation, only one peripheral (source or destination) should be assigned to the same handshaking interface.
10:7 SRC_PER RW 0x0
Source hardware interface.
Assigns a hardware handshaking interface to the source of channel x if the CFG_LOx.HSG_SEL_SRC field is 0; otherwise, this field is ignored. The channel can then communicate with the source peripheral connected to that interface through the assigned hardware handshaking interface.
6 SS_UPD_EN RW 0x0
Source status update enable.
Source status information is fetched only from the location pointed to by the SSTATARx register, stored in the SSTATx register and written out to the SSTATx location of the LLI, if SS_UPD_EN is high.
  • 0x0 (DISABLED):Source status update is disabled.
  • 0x1 (ENABLED):Source status update is enabled.
5 DS_UPD_EN RW 0x0
Destination status update enable.
Destination status information is fetched only from the location pointed to by the DSTATARx register, stored in the DSTATx register and written out to the DSTATx location of the LLI, if DS_UPD_EN is high.
  • 0x0 (DISABLED):Destination status update is disabled.
  • 0x1 (ENABLED):Destination status update is enabled.
4:2 PROTCTL RW 0x1
Protection control bits used to drive the AHB HPROT[3:1] bus.
The AMBA specification recommends that the default of HPROT indicate a non-cached, non-buffered, and privileged data access. The reset value is used to indicate such an access.
HPROT[0] is tied high because all transfers are data accesses, as there are no opcode fetches.
There is a one-to-one mapping of these register bits to the HPROT[3:1] master interface signals.
Mapping of HPROT bus is as follows:
  • 0x1 to HPROT[0]
  • CFG_HIx. PROTCT [1] to HPROT[1]
  • CFG_HI x. PROTCT[2] to HPROT[2]
  • CFG_HI x. PROTCT [3] to HPROT[3]
1 FIFO_MODE RW 0x0
FIFO mode select.
Determines how much space or data needs to be available in the FIFO before a burst transaction request is serviced.
  • 0x0: Space/Data available for a single AHB transfer of the specified transfer width
  • 0x1: Data available is greater than or equal to half the FIFO depth for destination transfers, and space available is greater than half the FIFO depth for source transfers. The exceptions are at the end of a burst transaction request or at the end of a block transfer.
0 FCMODE RW 0x0
Flow control mode.
Determines when source transaction requests are serviced when the destination peripheral is the flow controller.
  • 0x0: Source transaction requests are serviced when they occur. Data pre-fetching is enabled.
  • 0x1: Source transaction requests are not serviced until a destination transaction request occurs. In this mode, the amount of data transferred from the source is limited so that it is guaranteed to be transferred to the destination prior to block termination by the destination. Data pre-fetching is disabled.
SGRx
  • Name: Source Gather Register for Channel x
  • Description: The Source Gather Register contains two fields.
    • Source gather count field (SGRx.SGC): Specifies the number of contiguous source transfers of CTL_LOx.SRC_TR_WIDTH between successive gather intervals. This is defined as a gather boundary.
    • Source gather interval field (SGRx.SGI): Specifies the source address increment/decrement in multiples of CTL_LOx.SRC_TR_WIDTH on a gather boundary when gather mode is enabled for the source transfer.
  • Offset: 0x48 + x*0x58
  • Reset Value: 0x0
Table 684 Source Gather Register for Channel x
63:32
31:20
SGC
Source gather count.
19:0
SGI
Source gather interval.
DSRx
  • Name: Destination Scatter Register for Channel x
  • Description: The Destination Status Register contains two fields.
    • Destination scatter count field (DSRx.DSC): Specifies the number of contiguous destination transfers of CTL_LOx.DST_TR_WIDTH between successive scatter boundaries.
    • Destination scatter interval field (DSRx.DSI): Specifies the destination address increment/decrement in multiples of CTL_LOx.DST_TR_WIDTH on a scatter boundary when scatter mode is enabled for the destination transfer.
  • Offset: 0x50 + x*0x58
  • Reset Value: 0x0
Table 685 Destination Scatter Register for Channel x
63:32
31:20
DSC
Destination scatter count.
19:0
DSI
Destination scatter interval.
Interrupt_Registers
INT_RSTAT_TC
  • Name: Raw Status for Transfer Complete Interrupt
  • Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_TC[2] is the Channel 2 raw transfer complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_TC register.
Write access is available to this register or software for testing purposes only. Under normal operation, writes to this register are not recommended.
  • Offset: 0x2c0
  • Reset Value: 0x0
Table 686 Raw Status for Transfer Complete Interrupt
63:8
Rsvd_INT_RSTAT_TC
7:0
RAW
Raw status for transfer complete interrupt
  • 0x0: Inactive raw interrupt status
  • 0x1: Active raw interrupt status
INT_RSTAT_BTC
  • Name: Raw Status for Block Transfer Complete Interrupt
  • Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_BTC[2] is the Channel 2 raw block complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the CLR_BLK register.
  • Offset: 0x2c8
  • Reset Value: 0x0
Table 687 Raw Status for Block Transfer Complete Interrupt
63:8
RSVD_INT_RSTAT_BTC
7:0
RAW
INT_RSTAT_STC
  • Name: Raw Status for Source Transaction Complete Interrupt
  • Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_STC[2] is the Channel 2 raw source transaction complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_STC register.
Write access is available to this register or software testing purposes only. Under normal operation, writes to this register are not recommended.
  • Offset: 0x2D0
  • Reset Value: 0x0
Table 688 Raw Status for Source Transaction Complete Interrupt
63:8
RSVD_INT_RSTAT_STC
7:0
RAW
Raw status for source transaction complete interrupt
INT_RSTAT_DTC
  • Name: Raw Status for Destination Transaction Complete Interrupt
  • Description: Interrupt events are stored in this Raw Interrupt Status register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_DTC[2] is the Channel 2 raw destination transaction complete interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_DTC register.
  • Offset: 0x2d8
  • Reset Value: 0x0
Table 689 Raw Status for Destination Transaction Complete Interrupt
63:8
RSVD_INT_RSTAT_DTC
7:0
RAW
Raw status for destination transaction complete interrupt
INT_RSTAT_ERR
  • Name: Raw Status for Error Interrupt
  • Description: Interrupt events are stored in this Raw Interrupt Status Register before masking. This register has a bit allocated to each channel; for example, INT_RSTAT_ERR[2] is the Channel 2 raw error interrupt. Each bit in this register is cleared by writing a 1 to the corresponding location in the INT_CLR_ERR register.
  • Offset: 0x2E0
  • Reset Value: 0x0
Table 690 Raw Status for Error Interrupt
63:8
RSVD_INT_RSTAT_ERR
7:0
RAW
INT_STAT_TC
  • Name: Status for Transfer Complete Interrupt
  • Description: Channel DMA transfer complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_TC [2] is the Channel 2 source DMA transfer complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
  • Offset: 0x2E8
  • Reset Value: 0x0
Table 691 Status for Transfer Complete Interrupt
63:8
RSVD_INT_STAT_TC
7:0
STAT
Status for transfer complete interrupt
  • 0x0: Inactive interrupt status
  • 0x1: Active interrupt status
INT_STAT_BTC
  • Name: Status for Block Transfer Complete Interrupt
  • Description: Channel block complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_BTC[2] is the Channel 2 block complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
  • Offset: 0x2F0
  • Reset Value: 0x0
Table 692 Status for Block Transfer Complete Interrupt
63:8
RSVD_INT_STAT_BTC
7:0
STAT
Status for block transfer complete interrupt
INT_STAT_STC
  • Name: Status for Source Transaction Complete Interrupt
  • Description: Channel source transaction complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_STC[2] is the Channel 2 source transaction complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
  • Offset: 0x2F8
  • Reset Value: 0x0
Table 693 Status for Source Transaction Complete Interrupt
63:8
RSVD_INT_STAT_STC
7:0
STAT
Status for source transaction complete interrupt
INT_STAT_DTC
  • Name: Status for Destination Transaction Complete Interrupt
  • Description: Channel destination transaction complete interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_DTC[2] is the Channel 2 status destination transaction complete interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
  • Offset: 0x300
  • Reset Value: 0x0
Table 694 Status for Destination Transaction Complete Interrupt
63:8
RSVD_INT_STAT_DTC
7:0
STAT
Status for destination transaction complete interrupt
INT_STAT_ERR
  • Name: Status for Error Interrupt
  • Description: Channel error interrupt events from all channels are stored in this interrupt status register after masking. This register has a bit allocated to each channel; for example, INT_STAT_ERR[2] is the Channel 2 status error interrupt. The contents of this register are used to generate the interrupt signals (int or int_n bus, depending on interrupt polarity) leaving the DMA.
  • Offset: 0x308
  • Reset Value: 0x0
Table 695 Status for Error Interrupt
63:8
RSVD_INT_STAT_ERR
7:0
STAT
Status for error interrupt
INT_MASK_TC
  • Name: MASK for Transfer Complete Interrupt
  • Description: The contents of the raw status register INT_RSTAT_TC are masked with the contents of the mask register INT_MASK_TC. This register has a bit allocated to each channel; for example, INT_MASK_TC[2] is the mask bit for the Channel 2 transfer complete interrupt. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_TC register writes a 1 into INT_MASK_TC[0], while INT_MASK_TC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_TC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
  • Offset: 0x310
  • Reset Value: 0x0
Table 696 MASK for Transfer Complete Interrupt
63:16
RSVD_INT_MASK_TC
15:8
INT_MASK_WE
W
Interrupt Mask Write Enable
  • 0x0: Interrupt mask write disabled
  • 0x1: Interrupt mask write enabled
7:0
INT_MASK
Mask for Transfer Complete Interrupt
  • 0x0: Mask the interrupts.
  • 0x1: Unmask the interrupts.
INT_MASK_BTC
  • Name: Mask for Block Transfer Complete Interrupt
  • Description: The contents of the raw status register INT_RSTAT_BTC are masked with the contents of the mask register INT_MASK_BTC. This register has a bit allocated to each channel; for example, INT_MASK_BTC[2] is the mask bit for the Channel 2 block complete interrupt. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_BTC register writes a 1 into INT_MASK_BTC[0], while INT_MASK_BTC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_BTC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
  • Offset: 0x318
  • Reset Value: 0x0
Table 697 Mask for Block Transfer Complete Interrupt
63:16
RSVD_INT_MASK_BTC
15:8
INT_MASK_WE
W
7:0
INT_MASK
INT_MASK_STC
  • Name: MASK for Source Transaction Complete Interrupt
  • Description: The contents of the raw status register INT_RSTAT_STC are masked with the contents of the mask register INT_MASK_STC. This register has a bit allocated to each channel; for example, INT_MASK_STC[2] is the mask bit for the Channel 2 source transaction complete interrupt. When the source peripheral of DMA channel i is memory, then the source transaction complete interrupt, INT_MASK_STC[i], must be masked to prevent an erroneous triggering of an interrupt on the int_combined signal. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_STC register writes a 1 into INT_MASK_STC[0], while INT_MASK_STC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_STC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
  • Offset: 0x320
  • Reset Value: 0x0
Table 698 MASK for Source Transaction Complete Interrupt
63:16
RSVD_INT_MASK_STC
15:8
INT_MASK_WE
W
7:0
INT_MASK
Mask for Source Transaction Complete Interrupt
INT_MASK_DTC
  • Name: Mask for Destination Transaction Complete Interrupt
  • Description: The contents of the raw status register INT_RSTAT_DTC are masked with the contents of the mask register INT_MASK_DTC. This register has a bit allocated to each channel; for example, INT_MASK_DTC[2] is the mask bit for the Channel 2 destination transaction complete interrupt. When the destination peripheral of DMA channel i is memory, then the destination transaction complete interrupt, INT_MASK_DTC[i], must be masked to prevent an erroneous triggering of an interrupt on the int_combined(_n) signal. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_DTC register writes a 1 into INT_MASK_DTC[0], while INT_MASK_DTC[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_DTC[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the status registers and int_port signals.
  • Offset: 0x328
  • Reset Value: 0x0
Table 699 Mask for Destination Transaction Complete Interrupt
63:16
RSVD_INT_MASK_DTC
15:8
INT_MASK_WE
W
7:0
INT_MASK
INT_MASK_ERR
  • Name: Mask for Error Interrupt
  • Description: The contents of the raw status register INT_RSTAT_ERR are masked with the contents of the mask register INT_MASK_ERR. This register has a bit allocated to each channel; for example, INT_MASK_ERR[2] is the mask bit for the Channel 2 error interrupt. A channel INT_MASK bit will be written only if the corresponding mask write enable bit in the INT_MASK_WE field is asserted on the same AHB write transfer. This allows software to set a mask bit without performing a read-modified write operation. For example, writing hex 01x1 to the INT_MASK_ERR register writes a 1 into INT_MASK_ERR[0], while INT_MASK_ERR[7:1] remains unchanged. Writing hex 00xx leaves INT_MASK_ERR[7:0] unchanged. Writing a 1 to any bit in this register unmasks the corresponding interrupt, thus allowing the DMA to set the appropriate bit in the Status registers and int_port signals.
  • Offset: 0x330
  • Reset Value: 0x0
Table 700 Mask for Error Interrupt
63:16
RSVD_INT_MASK_ERR
15:8
INT_MASK_WE
W
7:0
INT_MASK
INT_CLR_TC
  • Name: Clear for Transfer Complete Interrupt
  • Description: Each bit in the INT_RSTAT_TC and INT_STAT_TC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_TC[2] is the clear bit for the Channel 2 transfer done interrupt. Writing a 0 has no effect. This register is not readable.
  • Offset: 0x338
  • Reset Value: 0x0
Table 701 Clear for Transfer Complete Interrupt
63:8
RSVD_INT_CLR_TC
W
7:0
CLR
W
  • 0x0: No effect
  • 0x1: Clears interrupts.
INT_CLR_BTC
  • Name: Clear for Block Transfer Complete Interrupt
  • Description: Each bit in the INT_RSTAT_BTC and INT_STAT_BTC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_BTC[2] is the clear bit for the Channel 2 block done interrupt. Writing a 0 has no effect. This register is not readable.
  • Offset: 0x340
  • Reset Value: 0x0
Table 702 Clear for Block Transfer Complete Interrupt
63:8
RSVD_INT_CLR_BTC
W
7:0
CLR
W
INT_CLR_STC
  • Name: Clear for Source Transaction Complete Interrupt
  • Description: Each bit in the INT_RSTAT_STC and INT_STAT_STC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_STC[2] is the clear bit for the Channel 2 source transaction done interrupt. Writing a 0 has no effect. This register is not readable.
  • Offset: 0x348
  • Reset Value: 0x0
Table 703 Clear for Source Transaction Complete Interrupt
63:8
RSVD_INT_CLR_STC
W
7:0
CLR
W
  • 0x0: No effect
INT_CLR_DTC
  • Name: Clear for Destination Transaction Complete Interrupt
  • Description: Each bit in the INT_RSTAT_DTC and INT_STAT_DTC is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_DTC[2] is the clear bit for the Channel 2 destination transaction done interrupt. Writing a 0 has no effect. This register is not readable.
  • Offset: 0x350
  • Reset Value: 0x0
Table 704 Clear for Destination Transaction Complete Interrupt
63:8
RSVD_INT_CLR_DTC
W
7:0
CLR
W
  • 0x0: No effect
INT_CLR_ERR
  • Name: Clear for Error Interrupt
  • Description: Each bit in the INT_RSTAT_ERR and INT_STAT_ERR is cleared on the same cycle by writing a 1 to the corresponding location in the registers. This register has a bit allocated to each channel; for example, INT_CLR_ERR[2] is the clear bit for the Channel 2 error interrupt. Writing a 0 has no effect. This register is not readable.
  • Offset: 0x358
  • Reset Value: 0x0
Table 705 Clear for Error Interrupt
63:8
RSVD_INT_CLR_ERR
W
7:0
CLR
W
  • 0x0: No effect
INT_STAT_ET
  • Name: Status for Each Interrupt Type
  • Description: The contents of each of the five status registers INT_STAT_TC, INT_STAT_BTC, INT_STAT_STC, INT_STAT_DTC, and INT_STAT_ERR are ORed to produce a single bit for each interrupt type in the combined status register (INT_STAT_ET). This register is read-only.
  • Offset: 0x360
  • Reset Value: 0x0
Table 706 Status for Each Interrupt Type
63:5
RSVD_INT_STAT_ET
4
ERR
OR of the contents of INT_STAT_ERR
  • 0x0: OR of the contents of INT_STAT_ERR register is 0.
  • 0x1: OR of the contents of INT_STAT_ERR register is 1.
3
DEST_XFE_CPLT
OR of the contents of INT_STAT_DTC
  • 0x0: OR of the contents of INT_STAT_DTC register is 0.
  • 0x1: OR of the contents of INT_STAT_DTC register is 1.
2
SRC_XFE_CPLT
OR of the contents of INT_STAT_STC
  • 0x0: OR of the contents of INT_STAT_STC register is 0.
  • 0x1: OR of the contents of INT_STAT_STC register is 1.
BLK_XFE_CPLT
OR of the contents of INT_STAT_BTC register
  • 0x0: OR of the contents of INT_STAT_BTC register is 0.
  • 0x1: OR of the contents of INT_STAT_BTC register is 1.
XFE_CPLT
OR of the contents of INT_STAT_TC register
  • 0x0: OR of the contents of INT_STAT_TC register is 0.
  • 0x1: OR of the contents of INT_STAT_TC register is 1.
Software_Handshake_Registers
REQ_SST
  • Name: Source Software Transaction Request Register
  • Description: A bit is assigned for each channel in this register. REQ_SST[n] is ignored when software handshaking is not enabled for the source of channel n. A channel SRC_REQ bit is written only if the corresponding channel write enable bit in the SRC_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register. For example, writing hex 0101 writes a 1 into REQ_SST[0], while REQ_SST[7:1] remains unchanged. Writing hex 00xx leaves REQ_SST[7:0] unchanged. This allows software to set a bit in the REQ_SST register without performing a read-modified write operation.
  • Offset: 0x368
  • Reset Value: 0x0
Table 707 Source Software Transaction Request Register
63:16
Rsvd_1_REQ_SST
15:8
SRC_REQ_WE
Source Software Transaction Request write enable
  • 0x0: Source request write disabled
  • 0x1: Source request write enabled
7:0
SRC_REQ
  • 0x0: Source request is not active.
  • 0x1: Source request is active.
REQ_DST
  • Name: Destination Software Transaction Request Register
  • Description: A bit is assigned for each channel in this register. REQ_DST[n] is ignored when software handshaking is not enabled for the source of channel n. A channel DEST bit is written only if the corresponding channel write enable bit in the DEST_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
  • Offset: 0x370
  • Reset Value: 0x0
Table 708 Destination Software Transaction Request Register
63:16
Rsvd_1_REQ_DST
15:8
DEST_REQ_WE
Destination Software Transaction Request write enable
  • 0x0: Destination request write disabled
  • 0x1: Destination request write enabled
7:0
DEST_REQ
  • 0x0: Destination request is not active.
  • 0x1: Destination request is active.
REQ_SGL_ST
  • Name: Source Single Transaction Request Register
  • Description: A bit is assigned for each channel in this register. REQ_SGL_ST is ignored when software handshaking is not enabled for the source of channel n. A channel SRC_SGL_REQ bit is written only if the corresponding channel write enable bit in the SRC_SGL_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
  • Offset: 0x378
  • Reset Value: 0x0
Table 709 Source Single Transaction Request Register
63:16
Rsvd_1_REQ_SGL_ST
15:8
SRC_SGL_REQ_WE
Source Single Transaction Request write enable
  • 0x0: Single write disabled
  • 0x1: Single write enabled
7:0
SRC_SGL_REQ
REQ_SGL_DT
  • Name: Destination Single Transaction Request Register
  • Description: A bit is assigned for each channel in this register. REQ_SGL_DT is ignored when software handshaking is not enabled for the destination of channel n. A channel DEST_SGL_REQ bit is written only if the corresponding channel write enable bit in the DST_SGL_REQ_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
  • Offset: 0x380
  • Reset Value: 0x0
Table 710 Destination Single Transaction Request Register
63:16
Rsvd_1_REQ_SGL_DT
11:8
DST_SGL_REQ_WE
Destination Single Transaction Request write enable
  • 0x0: Destination write disabled
  • 0x1: Destination write enabled
7:0
DEST_SGL_REQ
  • 0x0: Destination single or burst request is not active.
  • 0x1: Destination single or burst request is active.
REQ_LST_ST
  • Name: Source Last Transaction Request Register
  • Description: A bit is assigned for each channel in this register. REQ_LST_ST is ignored when software handshaking is not enabled for the source of channel n, or when the source of channel n is not a flow controller. A channel LST_SRC bit is written only if the corresponding channel write enable bit in the LST_SRC_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
  • Offset: 0x388
  • Reset Value: 0x0
Table 711 Source Last Transaction Request Register
63:16
Rsvd_1_REQ_LST_ST
15:8
LST_SRC_WE
Source Last Transaction Request write enable
  • 0x0: Source last transaction request write disabled
  • 0x1: Source last transaction request write enabled
7:0
LST_SRC
Source Last Transaction Request register
  • 0x0: Not last transaction in current block
  • 0x1: Last transaction in current block
REQ_LST_DT
  • Name: Destination Last Transaction Request Register
  • Description: A bit is assigned for each channel in this register. REQ_LST_DT is ignored when software handshaking is not enabled for the destination of channel n or when the destination of channel n is not a flow controller. A channel LST_DEST bit is written only if the corresponding channel write enable bit in the LST_DEST_WE field is asserted on the same AHB write transfer, and if the channel is enabled in the CH_EN register.
  • Offset: 0x390
  • Reset Value: 0x0
Table 712 Destination Last Transaction Request Register
63:16
Rsvd_1_REQ_LST_DT
15:8
LST_DEST_WE
Destination Last Transaction Request write enable
  • 0x0: Destination last transaction request write disabled
  • 0x1: Destination last transaction request write enabled
7:0
LST_DEST
Miscellaneous_Registers
CFG
  • Name: DMA Configuration Register
  • Description: This register is used to enable the DMA, which must be done before any channel activity. If the global channel enable bit is cleared while any channel is still active, CFG.DMA_EN still returns 1 to indicate that there are channels still active until hardware has terminated all activities on all channels, at which point the CFG.DMA_EN bit returns 0.
  • Offset: 0x398
  • Reset Value: 0x0
Table 713 DMA Configuration Register
63:1
RSVD_CFG
DMA_EN
DMA Enable bit.
  • 0x0: DMA disabled
  • 0x1: DMA enabled
CH_EN
  • Name: DMA Channel Enable Register
  • Description: This is the DMA Channel Enable Register. If software needs to set up a new channel, it can read this register in order to find out which channels are currently inactive; it can then enable an inactive channel with the required priority. All bits of this register are cleared to 0 when the global DMA channel enable bit, CFG[0], is 0. When the global channel enable bit is 0, a write to the CH_EN register is ignored and a read will always read back 0. The channel enable bit, CH_EN.CH_EN, is written only if the corresponding channel write enable bit, CH_EN.CH_EN_WE, is asserted on the same AHB write transfer. For example, writing hex 01x1 writes a 1 into CH_EN[0], while CH_EN[7:1] remains unchanged. Writing hex 00xx leaves CH_EN[7:0] unchanged. Note that a read-modified write is not required.
  • Offset: 0x3a0
  • Reset Value: 0x0
Table 714 DMA Channel Enable Register
63:16
Rsvd_1_CH_EN
15:8
CH_EN_WE
W
Channel enable register
7:0
CH_EN
Channel Enable.
The CH_EN.CH_EN bit is automatically cleared by hardware to disable the channel after the last AMBA transfer of the DMA transfer to the destination has completed. Software can therefore poll this bit to determine when this channel is free for a new DMA transfer.
  • 0x0: Disable the channel.
  • 0x1: Enable the channel.
