Real-Time Counter (RTC/Calendar)
The Real-time Counter (RTC) modules provide a generic, low-power timer running on a low-frequency clock source. Since the RTC modules are in AON domain, the timer can keep running when the MCU is off. The modules can also wake up the system from Deep Sleep.
There are two identical RTC modules: one for calendar and the other for RTOS.
The RTC tick event interrupt module enables low power "tick-less" RTOS implementation as it optionally provides a regular interrupt source for an RTOS without the need to use the ARM® SysTick feature. Using the RTC tick event rather than the SysTick allows the CPU to be powered down while still keeping RTOS scheduling active.
- One ordinary compare interrupt
- One tick event, supporting one-time counting and auto loading mode
- 32-bit up-counter register, supporting reading and writing
- 32-bit compare register, supporting reading and writing
- 32-bit down-tick register, supporting reading and writing
- One clock divider, supporting NO_DIV, DIV_2, DIV_4, DIV_8, DIV_16, DIV_32, DIV_64, and DIV_128
- Flexible clock source selections from LFRC_32K or LFXO_32K
- An independent interrupt entry
- The software has to enable RTC PMU LPD (RTC_EN) before using the RTC.
- The CLK_DIV/CLK_SEL register is a read/write register when the RTC is disabled and is read only when the RTC is enabled. Writing to the CLK_DIV/CLK_SEL register when the RTC is started has no effect.
- The OVERFLOW, COMPARE, and tick event interrupts are enabled by default.
- When RTC is enabled, the TIMER_RD register starts to count. When users set the values of the TIMER_SET register and TIME_SET bit to 1, the calendar module synchronizes the count value to the TIMER_RD register and starts timing.
- When RTC is disabled, all register values must be cleared to the default values.
- When the value of the TIMER_RD register is equal to that of the CMP_RD register, the ordinary compare interrupt is triggered.
- RTC tick event interrupt register is a value-decreasing register. When the auto reloading mode is set (TICK_TYPE), the value of the counter (TICK_SET) is automatically reloaded (TICK_RD) when the interrupt is triggered.
- When the count value of the TIMER_RD register overflows, the overflow interrupt is triggered, and the TIMER_RD register continues counting from 0.
CTRL
- Name: CTRL Register
- Description: This register sets RTC configurations.
- Base Address: 0x4000A600 + x*0x80
- Offset: 0x00
31:25 |
Reserved bits |
24 |
CFG |
Writing 1 to this register triggers the calendar timer configuration. |
23:11 |
0x |
Reserved bits |
10 |
TICK_TYPE |
Sets the RTC tick event mode.
9 |
TICK_SET |
Sets the RTC tick event timer value. |
8 |
TICK_EN |
Enables RTC tick event. |
7:5 |
Reserved bits |
4 |
WRAP_CLR |
Clears wrap counter. |
3 |
CMP_SET |
Sets the RTC COMPARE timer value. |
2 |
COMPARE_EN |
Enables RTC COMPARE timer. |
1 |
TIME_SET |
Sets the RTC initial timer value. |
0 |
EN |
Enables RTC timer. |
CLK_DIV
- Name: CLK_DIV Register
- Description: This register is used to set the frequency division coefficient
- Offset: 0x4
31:3 |
Reserved bits |
2:0 |
CLK_DIV |
IRQ_EN
- Name: IRQ_EN Register
- Description: This register is used to enable RTC interrupts.
- Offset: 0x14
- Reset Value: 0x00000007
31:3 |
Reserved bits |
2 |
TICK_EVT |
0x1 |
RTC tick event interrupt. Write 1 to enable the interrupt. |
1 |
OVERFLOW |
0x1 |
RTC overflow interrupt. Write 1 to enable the interrupt. |
0 |
COMPARE |
0x1 |
RTC COMPARE interrupt. Write 1 to enable the interrupt. |
IRQ_STAT
- Name: IRQ_STAT Register
- Description: This register is used to get interrupt status of the RTC.
- Offset: 0x18
31:3 |
Reserved bits |
2 |
TICK_EVT |
RTC tick event interrupt. Write 1 to clear the interrupt. |
1 |
OVERFLOW |
RTC overflow interrupt. Write 1 to clear the interrupt. |
0 |
COMPARE |
RTC COMPARE interrupt. Write 1 to clear the interrupt. |
STAT
- Name: STAT Register
- Description: This register is used to get the RTC status.
- Offset: 0x38
31:12 |
Reserved bits |
11:8 |
WRAP_CNT |
Calendar timer wrap-around counter |
7:5 |
Reserved bits |
4 |
BUSY |
Calendar timer is busy. The application layer can perform other operations until this bit is set is 0. |
3:1 |
Reserved bits |
0 |
STAT |
RTC timer is running. |
CLK_SEL
- Name: CLK_SEL Register
- Description: This register is used to select a clock source.
- Offset: 0x3C
31:2 |
Reserved bits |
1:0 |
CLK_SEL |
CMP_SET
- Name: CMP_SET Register
- Description: This register is used to set the COMPARE timer value.
- Offset: 0x40
31:0 |
CMP_SET |
TIMER_SET
- Name: TIMER_SET Register
- Description: This register is used to set the RTC timer value.
- Offset: 0x44
31:0 |
TIMER_SET |
TICK_SET
- Name: TICK_SET Register
- Description: This register is used to set the tick event timer value
- Offset: 0x48
31:0 |
TICK_SET |
TIMER_RD
- Name: TIMER_RD Register
- Description: This register is used to get the internal value of the RTC timer.
- Offset: 0x50
31:0 |
TIMER_RD |
Current internal value of the RTC timer |
CMP_RD
- Name: CMP_RD Register
- Description: This register is used to get the value of the RTC COMPARE timer.
- Offset: 0x54
31:0 |
CMP_RD |
Current internal value of the RTC COMPARE timer |
TICK_RD
- Name: TICK_RD Register
- Description: This register used to get the value of the RTC tick event timer.
- Offset: 0x58
31:0 |
TICK_RD |
Current internal value of the RTC tick event timer. |
